[geos-commits] r2255 - trunk/capi
svn_geos at osgeo.org
Fri Jan 23 20:33:09 EST 2009
Author: mloskot
Date: 2009-01-23 20:33:09 -0500 (Fri, 23 Jan 2009)
New Revision: 2255
trunk/capi/geos_ts_c.cpp
Fixed mixed signed/unsigned integral types in geos_ts_c.cpp, so no compilers should flood with warnings now.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-01-24 01:30:36 UTC (rev 2254)
+++ trunk/capi/geos_ts_c.cpp 2009-01-24 01:33:09 UTC (rev 2255)
@@ -47,6 +47,7 @@
#include <geos/version.h>
// This should go away
+#include <cstddef>
#include <cstdio>
#include <cstdlib>
#include <cstring>
@@ -564,17 +565,15 @@
try {
char *result = NULL;
char *validstr = "Valid Geometry";
- int validstrlen = std::strlen(validstr) + 1;
+ const std::size_t validstrlen = std::strlen(validstr) + 1;
bool isvalid = ivo.isValid();
if ( ! isvalid )
- int msglen = 0;
- int loclen = 0;
TopologyValidationError *err = ivo.getValidationError();
std::string errmsg = err->getMessage();
std::string errloc = err->getCoordinate().toString();
- msglen = errmsg.length();
- loclen = errloc.length();
+ const std::size_t msglen = errmsg.length();
+ const std::size_t loclen = errloc.length();
result = (char*)std::malloc(msglen + loclen + 3);
sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
@@ -1651,7 +1650,7 @@
try{
- return g1->getNumPoints();
+ return static_cast<int>(g1->getNumPoints());
catch (const std::exception &e)
@@ -1726,7 +1725,7 @@
handle->ERROR_MESSAGE("Argument is not a Polygon");
return -1;
- return p->getNumInteriorRing();
+ return static_cast<int>(p->getNumInteriorRing());
@@ -1760,7 +1759,7 @@
try{
- return g1->getNumGeometries();
+ return static_cast<int>(g1->getNumGeometries());
@@ -2265,7 +2264,7 @@
if ( g->isEmpty() ) return false;
double az = g->getCoordinate()->z;
//handle->ERROR_MESSAGE("ZCoord: %g", az);
- return FINITE(az);
+ return static_cast<char>(FINITE(az));
int
@@ -2539,7 +2538,7 @@
try {
- int sz = s->getSize();
+ std::size_t sz = s->getSize();
*size = static_cast<unsigned int>(sz);
return 1;
@@ -2573,8 +2572,8 @@
try {
- unsigned int dm = s->getDimension();
- *dims = dm;
+ std::size_t dim = s->getDimension();
+ *dims = static_cast<unsigned int>(dim);
return 1;
@@ -2874,17 +2873,21 @@
using geos::geom::GeometryCollection;
using geos::geom::Point;
+ std::size_t dim = 0;
try {
const LineString *ls = dynamic_cast<const LineString *>(g);
if ( ls )
- return ls->getCoordinatesRO()->getDimension();
+ dim = ls->getCoordinatesRO()->getDimension();
+ return static_cast<int>(dim);
const Point *p = dynamic_cast<const Point *>(g);
if ( p )
- return p->getCoordinatesRO()->getDimension();
+ dim = p->getCoordinatesRO()->getDimension();
const Polygon *poly = dynamic_cast<const Polygon *>(g);
@@ -2893,7 +2896,6 @@
return GEOSGeom_getDimensions_r(extHandle, poly->getExteriorRing());
const GeometryCollection *coll =
dynamic_cast<const GeometryCollection *>(g);
if ( coll )
@@ -3664,7 +3666,8 @@
try
- return writer->getIncludeSRID();
+ int srid = writer->getIncludeSRID();
+ return static_cast<char>(srid);
catch (...)
More information about the geos-commits
