[geos-commits] r2261 - trunk
svn_geos at osgeo.org
Tue Jan 27 20:06:46 EST 2009
Author: pramsey
Date: 2009-01-27 20:06:46 -0500 (Tue, 27 Jan 2009)
New Revision: 2261
trunk/README
Add to win32 instructions
Modified: trunk/README
--- trunk/README 2009-01-27 18:10:06 UTC (rev 2260)
+++ trunk/README 2009-01-28 01:06:46 UTC (rev 2261)
@@ -12,10 +12,22 @@
Win32
-Win32 Visual Studio Builds:
- source\makefile.vc
+If you use Microsoft Visual C++ (7.1 or later) compiler, you can build
+GEOS using NMAKE program and provided makefile.vc files:
+ bootstrap.bat
+ nmake /f makefile.vc MSVC_VER=1400
+where 1400 is version number of Visual C++ compiler, here Visual C++ 8.0
+from Visual Studio 2005 (supported versions are 1300, 1310, 1400 and 1500).
+The bootstrap.bat step is required to generate a couple of header files.
+In order to build debug configuration of GEOS, additional flag DEBUG=1
+is required:
+ nmake /f makefile.vc MSVC_VER=1400 DEBUG=1
CLIENT APPLICATIONS
@@ -53,5 +65,5 @@
# cd doc; make doxygen-html
- http://geos.refractions.net
+ http://trac.osgeo.org/geos
More information about the geos-commits
