[geos-commits] r2264 - trunk
svn_geos at osgeo.org
Thu Jan 29 14:02:10 EST 2009
Author: pramsey
Date: 2009-01-29 14:02:09 -0500 (Thu, 29 Jan 2009)
New Revision: 2264
trunk/README
update autogen.bat ref
Modified: trunk/README
--- trunk/README 2009-01-29 18:56:00 UTC (rev 2263)
+++ trunk/README 2009-01-29 19:02:09 UTC (rev 2264)
@@ -13,9 +13,11 @@
If you use Microsoft Visual C++ (7.1 or later) compiler, you can build
-GEOS using NMAKE program and provided makefile.vc files:
+GEOS using NMAKE program and provided makefile.vc files.
- bootstrap.bat
+If you are building from SVN checkout, first run: autogen.bat
+Then:
nmake /f makefile.vc MSVC_VER=1400
where 1400 is version number of Visual C++ compiler, here Visual C++ 8.0
More information about the geos-commits
