[geos-commits] r2616 - in trunk/source: headers/geos/io io
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Jul 17 18:23:41 EDT 2009
Author: pramsey
Date: 2009-07-17 18:23:41 -0400 (Fri, 17 Jul 2009)
New Revision: 2616
   trunk/source/headers/geos/io/WKBReader.h
   trunk/source/io/WKBReader.cpp
Remove static string in WKB reader (#232)
Modified: trunk/source/headers/geos/io/WKBReader.h
--- trunk/source/headers/geos/io/WKBReader.h	2009-07-17 22:23:03 UTC (rev 2615)
+++ trunk/source/headers/geos/io/WKBReader.h	2009-07-17 22:23:41 UTC (rev 2616)
@@ -30,6 +30,9 @@
 #include <vector>
 #include <string>
+#define BAD_GEOM_TYPE_MSG "Bad geometry type encountered in"
 // Forward declarations
 namespace geos {
 	namespace geom {
@@ -111,8 +114,6 @@
 private:
-	static std::string BAD_GEOM_TYPE_MSG;
 	const geom::GeometryFactory &factory;
 	// for now support the WKB standard only - may be generalized later
Modified: trunk/source/io/WKBReader.cpp
--- trunk/source/io/WKBReader.cpp	2009-07-17 22:23:03 UTC (rev 2615)
+++ trunk/source/io/WKBReader.cpp	2009-07-17 22:23:41 UTC (rev 2616)
@@ -47,8 +47,6 @@
 namespace geos {
 namespace io { // geos.io
-string WKBReader::BAD_GEOM_TYPE_MSG = "bad geometry type encountered in ";
 WKBReader::WKBReader()
 	factory(*(GeometryFactory::getDefaultInstance()))
More information about the geos-commits mailing list
