[geos-commits] r2536 - trunk/tests/xmltester
svn_geos at osgeo.org
Thu Jun 4 09:59:32 EDT 2009
Author: strk
Date: 2009-06-04 09:59:31 -0400 (Thu, 04 Jun 2009)
New Revision: 2536
trunk/tests/xmltester/XMLTester.cpp
Add support for testing single sided buffers
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-06-01 17:14:28 UTC (rev 2535)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-06-04 13:59:31 UTC (rev 2536)
@@ -30,6 +30,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/BinaryOp.h>
#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/operation/buffer/BufferBuilder.h>
#include <geos/operation/buffer/BufferParameters.h>
#include <geos/operation/buffer/BufferOp.h>
#include <geos/util.h>
@@ -521,6 +522,7 @@
std::string opArg1;
std::string opArg2;
std::string opArg3;
+ std::string opArg4;
std::string opRes;
//string opSig;
@@ -532,6 +534,7 @@
opArg1=xml.GetChildAttrib("arg1");
opArg2=xml.GetChildAttrib("arg2");
opArg3=xml.GetChildAttrib("arg3");
+ opArg4=xml.GetChildAttrib("arg4");
//opSig=xml.GetChildAttrib("arg3");
opRes=xml.GetChildData();
@@ -551,6 +554,10 @@
if ( opSig != "" ) opSig += ", ";
opSig += opArg3;
+ if ( opArg4 != "" ) {
+ if ( opSig != "" ) opSig += ", ";
+ opSig += opArg4;
opSignature = opName + "(" + opSig + ")";
@@ -828,6 +835,7 @@
if ( opArg3 != "" ) {
params.setQuadrantSegments(std::atoi(opArg3.c_str()));
BufferOp op(gT, params);
gRealRes.reset(op.getResultGeometry(dist));
@@ -844,6 +852,73 @@
expected_result=printGeom(gRes.get());
+ else if (opName=="buffersinglesided")
+ using namespace operation::buffer;
+ geom::Geometry *gT=gA;
+ if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) gT=gB;
+ GeomAutoPtr gRes(parseGeometry(opRes, "expected"));
+ gRes->normalize();
+ profile.start();
+ GeomAutoPtr gRealRes;
+ double dist = std::atof(opArg2.c_str());
+ BufferParameters params ;
+ params.setJoinStyle( BufferParameters::JOIN_ROUND ) ;
+ if ( opArg3 != "" ) {
+ params.setQuadrantSegments( std::atoi(opArg3.c_str()));
+ bool leftSide = true ;
+ if ( opArg4 == "right" )
+ leftSide = false ;
+ BufferBuilder bufBuilder( params ) ;
+ gRealRes.reset( bufBuilder.bufferLineSingleSided(
+ gT, dist, leftSide ) ) ;
+ profile.stop();
+ gRealRes->normalize();
+ // Assume a success and check for obvious failures
+ success=1;
+ do
+ if ( gRes->getGeometryTypeId() !=
+ gRealRes->getGeometryTypeId() )
+ std::cerr << "Expected result is of type "
+ << gRes->getGeometryType()
+ << "; obtained result is of type "
+ << gRealRes->getGeometryType()
+ << std::endl;
+ success=0;
+ break;
+ if ( ! gRes->equals( gRealRes.get() ) )
+std::cerr << "Matching single sided buffer results FAILED" << std::endl;
+ success=0;
+ break;
+ while (0);
+ if ( testValidOutput ) testValid(gRes.get(), "result");
+ actual_result=printGeom(gRealRes.get());
+ expected_result=printGeom(gRes.get());
else if (opName=="buffermitredjoin")
More information about the geos-commits
