[geos-commits] r2539 - trunk
svn_geos at osgeo.org
Fri Jun 5 05:15:57 EDT 2009
Author: strk
Date: 2009-06-05 05:15:57 -0400 (Fri, 05 Jun 2009)
New Revision: 2539
trunk/ChangeLog.svn
trunk/Makefile.am
Allow generating ChangeLog from external build tree
Modified: trunk/ChangeLog.svn
--- trunk/ChangeLog.svn 2009-06-04 15:01:08 UTC (rev 2538)
+++ trunk/ChangeLog.svn 2009-06-05 09:15:57 UTC (rev 2539)
@@ -1,3 +1,61 @@
+2009-06-04 15:01 Mateusz Loskot <mateusz at loskot.net>
+ * [r2538] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
+ build/msvc90/geos_lib/geos_lib.vcproj,
+ build/msvc90/geos_unit/geos_unit.vcproj, source/Makefile.vc,
+ source/geom/LinearRing.cpp,
+ source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h,
+ source/index/chain/MonotoneChainBuilder.cpp,
+ tests/unit/operation/valid/IsValidTest.cpp: * Applied patch for
+ ticket #257.
+ * Noticed that unit tests fail:
+ 1>geos::util::UniqueCoordinateArrayFilter: .
+ 1>---> group: geos::operation::valid::IsValidOp, test: test<1>
+ 1> problem: assertion failed
+2009-06-04 14:59 Mateusz Loskot <mateusz at loskot.net>
+ * [r2537] source/operation/buffer/BufferBuilder.cpp: Fixed bug of
+ inaccessible constructor of incomplete type NodedSegmentString -
+ header missing.
+2009-06-04 13:59 Sandro Santilli <strk at keybit.net>
+ * [r2536] tests/xmltester/XMLTester.cpp: Add support for testing
+ single sided buffers
+2009-06-01 03:34 hobu
+ * [r2534] capi/geos_c.cpp: #256 finishGEOS called multiple times
+ will segfault
+2009-05-28 14:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r2533] configure.in, tests/bigtest: Fixed aclocal warnings for
+ mixing cache-id's in configure.in.
+2009-05-27 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r2516] NEWS: remove error
+ * [r2515] NEWS: Add single-sided item
+2009-05-21 10:08 Sandro Santilli <strk at keybit.net>
+ * [r2514] ChangeLog.svn, Makefile.am, authors.svn: Add Mat's and
+ Paul's entries, make ChangeLog.svn rule phony
+2009-05-21 09:56 Sandro Santilli <strk at keybit.net>
+ * [r2513] ChangeLog.svn, Makefile.am, authors.svn: Add a rule to
+ generate a ChangeLog using svn2cl. The authors.svn file will be
+ used to map usernames and full names: please expand your own
+ nick. The generated ChangeLog is added to repository to show you
+ how it looks. If everybody agree we could rename this to
+ ChangeLog and stop requiring manual edits (+1 from me:)
2009-05-13 11:29 Frank Warmerdam <warmerdam at pobox.com>
* [r2508] capi/geos_c.h.in: refer to GEOSFree() instead of free()
Modified: trunk/Makefile.am
--- trunk/Makefile.am 2009-06-04 15:01:08 UTC (rev 2538)
+++ trunk/Makefile.am 2009-06-05 09:15:57 UTC (rev 2539)
@@ -20,6 +20,6 @@
ACLOCAL_AMFLAGS = -I macros
ChangeLog.svn:
- svn2cl --authors=authors.svn -i -o ChangeLog.svn
+ cd $(srcdir) && svn2cl --authors=authors.svn -i -o ChangeLog.svn
.PHONY: ChangeLog.svn
More information about the geos-commits
