[geos-commits] r2547 - in trunk/source: geomgraph
headers/geos/geomgraph headers/geos/operation/relate
headers/geos/operation/valid operation/relate operation/valid
svn_geos at osgeo.org
Fri Jun 5 09:41:50 EDT 2009
Author: strk
Date: 2009-06-05 09:41:50 -0400 (Fri, 05 Jun 2009)
New Revision: 2547
trunk/source/geomgraph/EdgeEnd.cpp
trunk/source/geomgraph/EdgeEndStar.cpp
trunk/source/headers/geos/geomgraph/EdgeEnd.h
trunk/source/headers/geos/geomgraph/EdgeEndStar.h
trunk/source/headers/geos/operation/relate/EdgeEndBundle.h
trunk/source/headers/geos/operation/valid/ConsistentAreaTester.h
trunk/source/operation/relate/EdgeEndBundle.cpp
trunk/source/operation/valid/ConsistentAreaTester.cpp
added BoundaryNodeRule capability to EdgeEnds
Modified: trunk/source/geomgraph/EdgeEnd.cpp
--- trunk/source/geomgraph/EdgeEnd.cpp 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/geomgraph/EdgeEnd.cpp 2009-06-05 13:41:50 UTC (rev 2547)
@@ -14,7 +14,7 @@
- * Last port: geomgraph/EdgeEnd.java rev. 1.5 (JTS-1.7)
+ * Last port: geomgraph/EdgeEnd.java rev. 1.6 (JTS-1.10)
@@ -182,7 +182,7 @@
/*public*/
void
-EdgeEnd::computeLabel()
+EdgeEnd::computeLabel(const algorithm::BoundaryNodeRule& boundaryNodeRule)
// subclasses should override this if they are using labels
Modified: trunk/source/geomgraph/EdgeEndStar.cpp
--- trunk/source/geomgraph/EdgeEndStar.cpp 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/geomgraph/EdgeEndStar.cpp 2009-06-05 13:41:50 UTC (rev 2547)
@@ -14,7 +14,7 @@
- * Last port: geomgraph/EdgeEndStar.java rev. 1.4 (JTS-1.7)
+ * Last port: geomgraph/EdgeEndStar.java rev. 1.8 (JTS-1.10)
@@ -76,10 +76,10 @@
/*public*/
void
-EdgeEndStar::computeLabelling(std::vector<GeometryGraph*> *geom)
+EdgeEndStar::computeLabelling(std::vector<GeometryGraph*> *geomGraph)
//throw(TopologyException *)
- computeEdgeEndLabels();
+ computeEdgeEndLabels((*geomGraph)[0]->getBoundaryNodeRule());
// Propagate side labels around the edges in the star
// for each parent Geometry
@@ -156,7 +156,7 @@
loc=Location::EXTERIOR;
}else {
Coordinate& p=e->getCoordinate();
- loc=getLocation(geomi,p,geom);
+ loc = getLocation(geomi, p, geomGraph);
label->setAllLocationsIfNull(geomi,loc);
@@ -166,14 +166,15 @@
/*private*/
void
-EdgeEndStar::computeEdgeEndLabels()
+EdgeEndStar::computeEdgeEndLabels(
+ const algorithm::BoundaryNodeRule& boundaryNodeRule)
// Compute edge label for each EdgeEnd
for (EdgeEndStar::iterator it=begin(); it!=end(); ++it)
- EdgeEnd *e=*it;
- assert(e);
- e->computeLabel();
+ EdgeEnd *ee=*it;
+ assert(ee);
+ ee->computeLabel(boundaryNodeRule);
@@ -193,9 +194,9 @@
/*public*/
bool
-EdgeEndStar::isAreaLabelsConsistent()
+EdgeEndStar::isAreaLabelsConsistent(const GeometryGraph& geomGraph)
+ computeEdgeEndLabels(geomGraph.getBoundaryNodeRule());
return checkAreaLabelsConsistent(0);
Modified: trunk/source/headers/geos/geomgraph/EdgeEnd.h
--- trunk/source/headers/geos/geomgraph/EdgeEnd.h 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/headers/geos/geomgraph/EdgeEnd.h 2009-06-05 13:41:50 UTC (rev 2547)
@@ -14,9 +14,9 @@
- * EXPOSED GEOS HEADER
+ * EXPOSED GEOS HEADER, but direct use NOT reccommended
@@ -31,6 +31,9 @@
// Forward declarations
namespace geos {
+ namespace algorithm {
+ class BoundaryNodeRule;
namespace geomgraph {
class Label;
class Edge;
@@ -111,7 +114,7 @@
virtual int compareDirection(const EdgeEnd *e) const;
- virtual void computeLabel();
+ virtual void computeLabel(const algorithm::BoundaryNodeRule& bnr);
virtual std::string print();
Modified: trunk/source/headers/geos/geomgraph/EdgeEndStar.h
--- trunk/source/headers/geos/geomgraph/EdgeEndStar.h 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/headers/geos/geomgraph/EdgeEndStar.h 2009-06-05 13:41:50 UTC (rev 2547)
@@ -14,7 +14,7 @@
@@ -36,6 +36,9 @@
namespace geos {
class GeometryGraph;
@@ -94,15 +97,11 @@
virtual EdgeEnd* getNextCW(EdgeEnd *ee);
- virtual void computeLabelling(std::vector<GeometryGraph*> *geom);
+ virtual void computeLabelling(std::vector<GeometryGraph*> *geomGraph);
// throw(TopologyException *);
- virtual int getLocation(int geomIndex,
- const geom::Coordinate& p,
- std::vector<GeometryGraph*> *geom);
+ virtual bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
- virtual bool isAreaLabelsConsistent();
virtual void propagateSideLabels(int geomIndex);
@@ -126,13 +125,17 @@
private:
+ virtual int getLocation(int geomIndex,
+ const geom::Coordinate& p,
+ std::vector<GeometryGraph*> *geom);
/** \brief
* The location of the point for this star in
* Geometry i Areas
int ptInAreaLocation[2];
- virtual void computeEdgeEndLabels();
+ virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
virtual bool checkAreaLabelsConsistent(int geomIndex);
Modified: trunk/source/headers/geos/operation/relate/EdgeEndBundle.h
--- trunk/source/headers/geos/operation/relate/EdgeEndBundle.h 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/headers/geos/operation/relate/EdgeEndBundle.h 2009-06-05 13:41:50 UTC (rev 2547)
@@ -13,7 +13,7 @@
- * Last port: operation/relate/EdgeEndBundle.java rev. 1.15 (JTS-1.7)
+ * Last port: operation/relate/EdgeEndBundle.java rev. 1.17 (JTS-1.10)
* NON-EXPOSED GEOS HEADER
@@ -28,6 +28,9 @@
namespace geos {
namespace geom {
class IntersectionMatrix;
@@ -39,23 +42,57 @@
namespace relate { // geos::operation::relate
/** \brief
- * Contains all geomgraph::EdgeEnd objectss which start at the same point
- * and are parallel.
+ * A collection of geomgraph::EdgeEnd objects which
+ * originate at the same point and have the same direction.
-class EdgeEndBundle: public geomgraph::EdgeEnd {
+class EdgeEndBundle: public geomgraph::EdgeEnd
public:
EdgeEndBundle(geomgraph::EdgeEnd *e);
virtual ~EdgeEndBundle();
geomgraph::Label *getLabel();
-//Iterator iterator() //Not needed
std::vector<geomgraph::EdgeEnd*>* getEdgeEnds();
void insert(geomgraph::EdgeEnd *e);
- void computeLabel() ;
+ void computeLabel(const algorithm::BoundaryNodeRule& bnr);
void updateIM(geom::IntersectionMatrix *im);
protected:
std::vector<geomgraph::EdgeEnd*> *edgeEnds;
- void computeLabelOn(int geomIndex);
+ * Compute the overall ON location for the list of EdgeStubs.
+ * (This is essentially equivalent to computing the self-overlay of
+ * a single Geometry)
+ * edgeStubs can be either on the boundary (eg Polygon edge)
+ * OR in the interior (e.g. segment of a LineString)
+ * of their parent Geometry.
+ * In addition, GeometryCollections use a algorithm::BoundaryNodeRule
+ * to determine whether a segment is on the boundary or not.
+ * Finally, in GeometryCollections it can occur that an edge
+ * is both
+ * on the boundary and in the interior (e.g. a LineString segment
+ * lying on
+ * top of a Polygon edge.) In this case the Boundary is
+ * given precendence.
+ * These observations result in the following rules for computing
+ * the ON location:
+ * - if there are an odd number of Bdy edges, the attribute is Bdy
+ * - if there are an even number >= 2 of Bdy edges, the attribute
+ * is Int
+ * - if there are any Int edges, the attribute is Int
+ * - otherwise, the attribute is NULL.
+ void computeLabelOn(int geomIndex,
+ const algorithm::BoundaryNodeRule& boundaryNodeRule);
void computeLabelSides(int geomIndex);
void computeLabelSide(int geomIndex,int side);
Modified: trunk/source/headers/geos/operation/valid/ConsistentAreaTester.h
--- trunk/source/headers/geos/operation/valid/ConsistentAreaTester.h 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/headers/geos/operation/valid/ConsistentAreaTester.h 2009-06-05 13:41:50 UTC (rev 2547)
@@ -12,6 +12,12 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: operation/valid/ConsistentAreaTester.java rev. 1.14 (JTS-1.10)
+ * NON-EXPOSED GEOS HEADER
#ifndef GEOS_OP_CONSISTENTAREATESTER_H
@@ -43,7 +49,7 @@
/** \brief
* Checks that a {@link geomgraph::GeometryGraph} representing an area
* (a {@link Polygon} or {@link MultiPolygon} )
- * is consistent with the SFS semantics for area geometries.
+ * is consistent with the OGC-SFS semantics for area geometries.
* Checks include:
@@ -54,6 +60,27 @@
* If an inconsistency if found the location of the problem
* is recorded.
+/** \brief
+ * Checks that a geomgraph::GeometryGraph representing an area
+ * (a geom::Polygon or geom::MultiPolygon)
+ * has consistent semantics for area geometries.
+ * This check is required for any reasonable polygonal model
+ * (including the OGC-SFS model, as well as models which allow ring
+ * self-intersection at single points)
+ * Checks include:
+ * - test for rings which properly intersect
+ * (but not for ring self-intersection, or intersections at vertices)
+ * - test for consistent labelling at all node points
+ * (this detects vertex intersections with invalid topology,
+ * i.e. where the exterior side of an edge lies in the interior of the area)
+ * - test for duplicate rings
+ * If an inconsistency is found the location of the problem
+ * is recorded and is available to the caller.
class ConsistentAreaTester {
private:
@@ -75,16 +102,29 @@
public:
- /// Caller keeps responsibility for GeometryGraph deletion
+ * Creates a new tester for consistent areas.
+ * @param geomGraph the topology graph of the area geometry.
+ * Caller keeps responsibility for its deletion
ConsistentAreaTester(geomgraph::GeometryGraph *newGeomGraph);
~ConsistentAreaTester();
- * @return the intersection point, or <code>null</code> if none was found
+ * @return the intersection point, or <code>null</code>
+ * if none was found
geom::Coordinate& getInvalidPoint();
+ /** \brief
+ * Check all nodes to see if their labels are consistent with
+ * area topology.
+ * @return <code>true</code> if this area has a consistent node
+ * labelling
bool isNodeConsistentArea();
Modified: trunk/source/operation/relate/EdgeEndBundle.cpp
--- trunk/source/operation/relate/EdgeEndBundle.cpp 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/operation/relate/EdgeEndBundle.cpp 2009-06-05 13:41:50 UTC (rev 2547)
@@ -14,7 +14,7 @@
@@ -75,7 +75,9 @@
* edges in this EdgeStubBundle. It essentially merges
* the ON and side labels for each edge. These labels must be compatible
-void EdgeEndBundle::computeLabel() {
+void EdgeEndBundle::computeLabel(
// create the label. If any of the edges belong to areas,
// the label must be an area label
bool isArea=false;
@@ -95,34 +97,16 @@
// compute the On label, and the side labels if present
for(int i=0;i<2;i++) {
- computeLabelOn(i);
+ computeLabelOn(i, boundaryNodeRule);
if (isArea)
computeLabelSides(i);
-* Compute the overall ON location for the list of EdgeStubs.
-* (This is essentially equivalent to computing the self-overlay of a single Geometry)
-* edgeStubs can be either on the boundary (eg Polygon edge)
-* OR in the interior (e.g. segment of a LineString)
-* of their parent Geometry.
-* In addition, GeometryCollections use the mod-2 rule to determine
-* whether a segment is on the boundary or not.
-* Finally, in GeometryCollections it can still occur that an edge is both
-* on the boundary and in the interior (e.g. a LineString segment lying on
-* top of a Polygon edge.) In this case as usual the Boundary is given precendence.
-* <br>
-* These observations result in the following rules for computing the ON location:
-* <ul>
-* <li> if there are an odd number of Bdy edges, the attribute is Bdy
-* <li> if there are an even number >= 2 of Bdy edges, the attribute is Int
-* <li> if there are any Int edges, the attribute is Int
-* <li> otherwise, the attribute is NULL.
-* </ul>
-void EdgeEndBundle::computeLabelOn(int geomIndex) {
+void
+EdgeEndBundle::computeLabelOn(int geomIndex, const algorithm::BoundaryNodeRule& boundaryNodeRule)
// compute the ON location value
int boundaryCount=0;
bool foundInterior=false;
@@ -136,7 +120,8 @@
int loc=Location::UNDEF;
if (foundInterior) loc=Location::INTERIOR;
if (boundaryCount>0) {
- loc=GeometryGraph::determineBoundary(boundaryCount);
+ loc = GeometryGraph::determineBoundary(boundaryNodeRule,
+ boundaryCount);
label->setLocation(geomIndex,loc);
Modified: trunk/source/operation/valid/ConsistentAreaTester.cpp
--- trunk/source/operation/valid/ConsistentAreaTester.cpp 2009-06-05 12:42:14 UTC (rev 2546)
+++ trunk/source/operation/valid/ConsistentAreaTester.cpp 2009-06-05 13:41:50 UTC (rev 2547)
@@ -12,6 +12,10 @@
#include <geos/operation/valid/ConsistentAreaTester.h>
@@ -79,11 +83,13 @@
bool
ConsistentAreaTester::isNodeEdgeAreaLabelsConsistent()
+ assert(geomGraph);
map<Coordinate*,Node*,CoordinateLessThen>& nMap=nodeGraph.getNodeMap();
map<Coordinate*,Node*,CoordinateLessThen>::iterator nodeIt;
for(nodeIt=nMap.begin();nodeIt!=nMap.end();nodeIt++) {
relate::RelateNode *node=static_cast<relate::RelateNode*>(nodeIt->second);
- if (!node->getEdges()->isAreaLabelsConsistent()) {
+ if (!node->getEdges()->isAreaLabelsConsistent(*geomGraph)) {
invalidPoint=node->getCoordinate();
return false;
More information about the geos-commits
