[geos-commits] r2552 - in trunk/source:
headers/geos/operation/overlay operation/overlay
svn_geos at osgeo.org
Fri Jun 5 14:18:35 EDT 2009
Author: strk
Date: 2009-06-05 14:18:35 -0400 (Fri, 05 Jun 2009)
New Revision: 2552
trunk/source/headers/geos/operation/overlay/OverlayOp.h
trunk/source/operation/overlay/OverlayOp.cpp
JTS-1.10 OverlayOp
Modified: trunk/source/headers/geos/operation/overlay/OverlayOp.h
--- trunk/source/headers/geos/operation/overlay/OverlayOp.h 2009-06-05 18:12:30 UTC (rev 2551)
+++ trunk/source/headers/geos/operation/overlay/OverlayOp.h 2009-06-05 18:18:35 UTC (rev 2552)
@@ -11,6 +11,12 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: operation/overlay/OverlayOp.java rev. 1.31 (JTS-1.10)
+ * EXPOSED GEOS HEADER
#ifndef GEOS_OP_OVERLAY_OVERLAYOP_H
Modified: trunk/source/operation/overlay/OverlayOp.cpp
--- trunk/source/operation/overlay/OverlayOp.cpp 2009-06-05 18:12:30 UTC (rev 2551)
+++ trunk/source/operation/overlay/OverlayOp.cpp 2009-06-05 18:18:35 UTC (rev 2552)
@@ -14,8 +14,10 @@
- * Last port: operation/overlay/OverlayOp.java rev. 1.23
+ * NOTE: Use of EdgeNodingValidator is not strictly the same
#include <geos/operation/overlay/OverlayOp.h>
@@ -680,14 +682,28 @@
//Debug.println(edgeList);
#ifdef ENABLE_EDGE_NODING_VALIDATOR // {
- if ( resultPrecisionModel->isFloating() )
+ * Check that the noding completed correctly.
+ * This test is slow, but necessary in order to catch
+ * robustness failure situations.
+ * If an exception is thrown because of a noding failure,
+ * then snapping will be performed, which will hopefully avoid
+ * the problem.
+ * In the future hopefully a faster check can be developed.
+ if ( resultPrecisionModel->isFloating() ) // NOTE: this is not in JTS
- // Will throw TopologyException if noding is found to be invalid
- EdgeNodingValidator nv(edgeList.getEdges());
- try {
- nv.checkValid();
- } catch (const util::TopologyException& ex) {
+ try
+ // Will throw TopologyException if noding is
+ // found to be invalid
+ EdgeNodingValidator::checkValid(edgeList.getEdges());
+ catch (const util::TopologyException& ex)
#ifdef GEOS_DEBUG_VALIDATION // {
cout << "EdgeNodingValidator found noding invalid: " << ex.what() << endl;
#endif // }
More information about the geos-commits
