[geos-commits] r2554 - in trunk: . build/msvc90/geos_lib capi
source/algorithm source/geom source/headers/geos
source/headers/geos/geom source/headers/geos/index/intervalrtree
source/headers/geos/noding source/operation/buffer
source/operation/distance source/util tests/unit/geom
tests/unit/operation/distance
svn_geos at osgeo.org
Sat Jun 6 17:14:51 EDT 2009
Author: strk
Date: 2009-06-06 17:14:51 -0400 (Sat, 06 Jun 2009)
New Revision: 2554
trunk/build/msvc90/geos_lib/geos_lib.vcproj
trunk/capi/geos_ts_c.cpp
trunk/configure.in
trunk/source/algorithm/InteriorPointLine.cpp
trunk/source/algorithm/InteriorPointPoint.cpp
trunk/source/algorithm/MinimumDiameter.cpp
trunk/source/geom/Geometry.cpp
trunk/source/geom/GeometryFactory.cpp
trunk/source/geom/LineSegment.cpp
trunk/source/headers/geos/geom/Coordinate.h
trunk/source/headers/geos/geom/Coordinate.inl
trunk/source/headers/geos/index/intervalrtree/IntervalRTreeNode.h
trunk/source/headers/geos/noding/SingleInteriorIntersectionFinder.h
trunk/source/headers/geos/platform.h.in
trunk/source/headers/geos/platform.h.vc
trunk/source/operation/buffer/RightmostEdgeFinder.cpp
trunk/source/operation/distance/DistanceOp.cpp
trunk/source/util/GeometricShapeFactory.cpp
trunk/tests/unit/geom/CoordinateTest.cpp
trunk/tests/unit/geom/TriangleTest.cpp
trunk/tests/unit/operation/distance/DistanceOpTest.cpp
Use real NaNs rather than fake them. Applies patch in ticket #259. Adds autoconf checks for finite() and isfinite() and makes use of them for unix systems (platform.h)
Modified: trunk/build/msvc90/geos_lib/geos_lib.vcproj
--- trunk/build/msvc90/geos_lib/geos_lib.vcproj 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/build/msvc90/geos_lib/geos_lib.vcproj 2009-06-06 21:14:51 UTC (rev 2554)
@@ -21,7 +21,7 @@
OutputDirectory="$(SolutionDir)$(ConfigurationName)"
IntermediateDirectory="$(ConfigurationName)\$(ProjectName)\"
ConfigurationType="4"
- CharacterSet="2"
+ CharacterSet="1"
<Tool
Name="VCPreBuildEventTool"
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/capi/geos_ts_c.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -45,6 +45,7 @@
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/geom/BinaryOp.h>
#include <geos/version.h>
+#include <geos/platform.h> // for FINITE
// This should go away
#include <cstddef>
Modified: trunk/configure.in
--- trunk/configure.in 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/configure.in 2009-06-06 21:14:51 UTC (rev 2554)
@@ -140,6 +140,35 @@
CFLAGS="${CFLAGS} ${DEFAULTFLAGS}"
dnl --------------------------------------------------------------------
+dnl - Look for finite and/or isfinite macros/functions
+dnl --------------------------------------------------------------------
+dnl These two tests need the math library or they won't link
+dnl on OpenBSD, even if the functions exist.
+save_LIBS=$LIBS
+LIBS="$LIBS -lm"
+AC_CACHE_CHECK([for finite], ac_cv_finite,
+ [AC_TRY_LINK([#include <math.h>],
+ [double x; int y; y = finite(x);],
+ ac_cv_finite=yes,
+ ac_cv_finite=no
+if test x"$ac_cv_finite" = x"yes"; then
+ AC_DEFINE(HAVE_FINITE, [1], [Has finite])
+fi
+AC_CACHE_CHECK([for isfinite], ac_cv_isfinite,
+ [double x; int y; y = isfinite(x);],
+ ac_cv_isfinite=yes,
+ ac_cv_isfinite=no
+if test x"$ac_cv_isfinite" = x"yes"; then
+ AC_DEFINE(HAVE_ISFINITE, [1], [Has isfinite])
+fi
+LIBS=$save_LIBS
dnl - Look for a 64bit integer (do after CFLAGS is set)
Modified: trunk/source/algorithm/InteriorPointLine.cpp
--- trunk/source/algorithm/InteriorPointLine.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/algorithm/InteriorPointLine.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -38,7 +38,7 @@
InteriorPointLine::InteriorPointLine(const Geometry *g)
- minDistance=DoubleInfinity;
+ minDistance=DoubleMax;
hasInterior=false;
if ( g->getCentroid(centroid) )
Modified: trunk/source/algorithm/InteriorPointPoint.cpp
--- trunk/source/algorithm/InteriorPointPoint.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/algorithm/InteriorPointPoint.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -14,6 +14,7 @@
#include <geos/algorithm/InteriorPointPoint.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/Geometry.h>
@@ -33,7 +34,7 @@
/*public*/
InteriorPointPoint::InteriorPointPoint(const Geometry *g)
if ( ! g->getCentroid(centroid) ) {
hasInterior=false;
} else {
Modified: trunk/source/algorithm/MinimumDiameter.cpp
--- trunk/source/algorithm/MinimumDiameter.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/algorithm/MinimumDiameter.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -220,7 +220,7 @@
void
MinimumDiameter::computeConvexRingMinDiameter(const CoordinateSequence* pts)
- minWidth=DoubleInfinity;
+ minWidth=DoubleMax;
unsigned int currMaxIndex=1;
LineSegment seg;
Modified: trunk/source/geom/Geometry.cpp
--- trunk/source/geom/Geometry.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/geom/Geometry.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -149,7 +149,7 @@
size_t npts=list->getSize();
for (size_t i=0; i<npts; ++i) {
- if (list->getAt(i)==Coordinate::getNull()) {
+ if (list->getAt(i).isNull()) {
return true;
Modified: trunk/source/geom/GeometryFactory.cpp
--- trunk/source/geom/GeometryFactory.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/geom/GeometryFactory.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -232,7 +232,7 @@
Point*
GeometryFactory::createPoint(const Coordinate& coordinate) const
- if (coordinate==Coordinate::getNull()) {
+ if (coordinate.isNull()) {
return createPoint();
} else {
CoordinateSequence *cl=coordinateListFactory->create(new vector<Coordinate>(1, coordinate));
Modified: trunk/source/geom/LineSegment.cpp
--- trunk/source/geom/LineSegment.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/geom/LineSegment.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -194,7 +194,7 @@
CoordinateSequence *closestPt=new CoordinateArraySequence(2);
//vector<Coordinate> *cv = new vector<Coordinate>(2);
- double minDistance=DoubleInfinity;
+ double minDistance=DoubleMax;
double dist;
Coordinate close00;
Modified: trunk/source/headers/geos/geom/Coordinate.h
--- trunk/source/headers/geos/geom/Coordinate.h 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/geom/Coordinate.h 2009-06-06 21:14:51 UTC (rev 2554)
@@ -23,6 +23,7 @@
#include <stack>
#include <vector> // for typedefs
#include <string>
+#include <limits>
namespace geos {
namespace geom { // geos.geom
@@ -84,6 +85,8 @@
static Coordinate& getNull();
+ bool isNull() const;
~Coordinate();
Coordinate(double xNew=0.0, double yNew=0.0, double zNew=DoubleNotANumber);
Modified: trunk/source/headers/geos/geom/Coordinate.inl
--- trunk/source/headers/geos/geom/Coordinate.inl 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/geom/Coordinate.inl 2009-06-06 21:14:51 UTC (rev 2554)
@@ -40,6 +40,12 @@
return nullCoord;
+INLINE bool
+Coordinate::isNull() const
+ return (ISNAN(x) && ISNAN(y) && ISNAN(z));
INLINE
Coordinate::~Coordinate()
Modified: trunk/source/headers/geos/index/intervalrtree/IntervalRTreeNode.h
--- trunk/source/headers/geos/index/intervalrtree/IntervalRTreeNode.h 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/index/intervalrtree/IntervalRTreeNode.h 2009-06-06 21:14:51 UTC (rev 2554)
@@ -17,6 +17,7 @@
#ifndef GEOS_INDEX_INTERVALRTREE_INTERVALRTREENODE_H
#define GEOS_INDEX_INTERVALRTREE_INTERVALRTREENODE_H
#include <vector>
#include <limits>
@@ -51,8 +52,8 @@
typedef std::vector<const IntervalRTreeNode *> ConstVect;
IntervalRTreeNode()
- : min( std::numeric_limits<double>::min() ),
- max( std::numeric_limits<double>::max() )
+ : min( DoubleInfinity ),
+ max( DoubleNegInfinity )
IntervalRTreeNode( double min, double max)
Modified: trunk/source/headers/geos/noding/SingleInteriorIntersectionFinder.h
--- trunk/source/headers/geos/noding/SingleInteriorIntersectionFinder.h 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/noding/SingleInteriorIntersectionFinder.h 2009-06-06 21:14:51 UTC (rev 2554)
@@ -71,7 +71,7 @@
bool hasIntersection() const
- return interiorIntersection != geom::Coordinate::getNull();
+ return !interiorIntersection.isNull();
/** \brief
@@ -110,8 +110,7 @@
bool isDone() const
- // TODO: add Coordinate::isNull()
Modified: trunk/source/headers/geos/platform.h.in
--- trunk/source/headers/geos/platform.h.in 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/platform.h.in 2009-06-06 21:14:51 UTC (rev 2554)
@@ -13,6 +13,12 @@
/* Set to 1 if you have ieeefp.h */
#undef HAVE_IEEEFP_H
+/* Has finite */
+#undef HAVE_FINITE
+/* Has isfinite */
+#undef HAVE_ISFINITE
#ifdef HAVE_IEEEFP_H
extern "C"
@@ -36,16 +42,36 @@
#include <float.h>
#endif
+#include <cmath> // for finite()/isfinite() and isnan()
+#include <limits> // for std::numeric_limits
//Defines NaN for intel platforms
+#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
//Don't forget to define infinities
-#define DoubleNotANumber 1.7e-308
-#define DoubleInfinity 1.7e+308
-#define DoubleNegInfinity -1.7e+308
+#define DoubleInfinity std::numeric_limits<double>::infinity()
+#define DoubleNegInfinity -std::numeric_limits<double>::infinity()
-#define FINITE(x) ( (x) != DoubleNotANumber && (x) != DoubleInfinity && (x) != DoubleNegInfinity )
-#define ISNAN(x) ( (x) == DoubleNotANumber )
+#define DoubleMax std::numeric_limits<double>::max()
+inline bool
+isFinite(double d)
+#if defined(HAVE_FINITE) && !defined(HAVE_ISFINITE)
+ return (finite(d));
+#else
+ // Put using namespace std; here if you have to
+ // put it anywhere.
+ using namespace std;
+ return (isfinite(d));
+#endif
+#define FINITE(x) ( isFinite(x) )
+#define ISNAN(x) ( isnan(x) )
#ifdef HAVE_INT64_T_64
typedef int64_t int64;
#else
Modified: trunk/source/headers/geos/platform.h.vc
--- trunk/source/headers/geos/platform.h.vc 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/headers/geos/platform.h.vc 2009-06-06 21:14:51 UTC (rev 2554)
@@ -39,14 +39,16 @@
#endif
#define ISNAN(x) _isnan(x)
#define FINITE(x) _finite(x)
#define finite(x) _finite(x)
Modified: trunk/source/operation/buffer/RightmostEdgeFinder.cpp
--- trunk/source/operation/buffer/RightmostEdgeFinder.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/operation/buffer/RightmostEdgeFinder.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -202,7 +202,7 @@
// of a non-horizontal segment
// <FIX> MD 19 Sep 03 - NO! we can test all vertices,
// since the rightmost must have a non-horiz segment adjacent to it
- if (minCoord==Coordinate::getNull() ||
+ if (minCoord.isNull() ||
coord->getAt(i).x > minCoord.x )
minDe = de;
Modified: trunk/source/operation/distance/DistanceOp.cpp
--- trunk/source/operation/distance/DistanceOp.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/operation/distance/DistanceOp.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -83,7 +83,7 @@
geom(2),
terminateDistance(0.0),
minDistanceLocation(0),
- minDistance(DoubleInfinity)
+ minDistance(DoubleMax)
geom[0] = g0;
geom[1] = g1;
@@ -93,7 +93,7 @@
geom(2),
geom[0] = &g0;
geom[1] = &g1;
@@ -104,7 +104,7 @@
geom(2),
terminateDistance(tdist),
geom[0] = &g0;
geom[1] = &g1;
Modified: trunk/source/util/GeometricShapeFactory.cpp
--- trunk/source/util/GeometricShapeFactory.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/source/util/GeometricShapeFactory.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -257,10 +257,10 @@
Envelope*
GeometricShapeFactory::Dimensions::getEnvelope()
- if (base!=Coordinate::getNull()) {
+ if (!base.isNull()) {
return new Envelope(base.x, base.x + width, base.y, base.y + height);
- if (centre!=Coordinate::getNull()) {
+ if (!centre.isNull()) {
return new Envelope(centre.x - width/2, centre.x + width/2,centre.y - height/2, centre.y + height/2);
return new Envelope(0, width, 0, height);
Modified: trunk/tests/unit/geom/CoordinateTest.cpp
--- trunk/tests/unit/geom/CoordinateTest.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/tests/unit/geom/CoordinateTest.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -50,7 +50,7 @@
geos::geom::Coordinate coord;
ensure_equals( coord.x, 0.0 );
ensure_equals( coord.y, 0.0 );
- ensure_equals( coord.z, DoubleNotANumber );
+ ensure( ISNAN( coord.z ) );
// Test of copy constructor and assignment operator
@@ -172,16 +172,16 @@
// Make it null and check
not_null_coord.setNull();
- ensure_equals( not_null_coord.x, DoubleNotANumber );
- ensure_equals( not_null_coord.y, DoubleNotANumber );
- ensure_equals( not_null_coord.z, DoubleNotANumber );
+ ensure( ISNAN( not_null_coord.x ) );
+ ensure( ISNAN( not_null_coord.y ) );
+ ensure( ISNAN( not_null_coord.z ) );
// Build in static null instance
geos::geom::Coordinate null_coord;
null_coord = geos::geom::Coordinate::getNull();
- ensure_equals( null_coord.x, DoubleNotANumber );
- ensure_equals( null_coord.y, DoubleNotANumber );
- ensure_equals( null_coord.z, DoubleNotANumber );
+ ensure( ISNAN( null_coord.x ) );
+ ensure( ISNAN( null_coord.y ) );
+ ensure( ISNAN( null_coord.z ) );
} // namespace tut
Modified: trunk/tests/unit/geom/TriangleTest.cpp
--- trunk/tests/unit/geom/TriangleTest.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/tests/unit/geom/TriangleTest.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -113,6 +113,6 @@
ensure( fabs(center.x - 6.0) < 1e-15 );
ensure( center.y > 4.2 );
ensure( center.y < 4.3 );
- ensure_equals( center.z, DoubleNotANumber );
+ ensure( ISNAN( center.z ) );
} // namespace tut
Modified: trunk/tests/unit/operation/distance/DistanceOpTest.cpp
--- trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2009-06-06 00:55:55 UTC (rev 2553)
+++ trunk/tests/unit/operation/distance/DistanceOpTest.cpp 2009-06-06 21:14:51 UTC (rev 2554)
@@ -218,7 +218,7 @@
DistanceOp dist(g0.get(), g1.get());
- ensure_equals(dist.distance(), DoubleInfinity);
+ ensure_equals(dist.distance(), DoubleMax);
ensure_equals(dist.closestPoints(), (void*)0);
@@ -396,7 +396,7 @@
More information about the geos-commits
