[geos-commits] r2561 - in trunk/source:
headers/geos/operation/distance operation/distance
svn_geos at osgeo.org
Mon Jun 8 06:37:11 EDT 2009
Author: strk
Date: 2009-06-08 06:37:11 -0400 (Mon, 08 Jun 2009)
New Revision: 2561
trunk/source/headers/geos/operation/distance/GeometryLocation.h
trunk/source/operation/distance/GeometryLocation.cpp
GeometryLocation sync to JTS-1.10 (docs)
Modified: trunk/source/headers/geos/operation/distance/GeometryLocation.h
--- trunk/source/headers/geos/operation/distance/GeometryLocation.h 2009-06-08 10:29:54 UTC (rev 2560)
+++ trunk/source/headers/geos/operation/distance/GeometryLocation.h 2009-06-08 10:37:11 UTC (rev 2561)
@@ -13,7 +13,7 @@
- * Last port: operation/distance/GeometryLocation.java rev. 1.4 (JTS-1.7)
+ * Last port: operation/distance/GeometryLocation.java rev. 1.7 (JTS-1.10)
@@ -40,8 +40,9 @@
/** \brief
* Represents the location of a point on a Geometry.
- * Maintains both the actual point location (which of course
- * may not be exact) as well as information about the component
+ * Maintains both the actual point location
+ * (which may not be exact, if the point is not a vertex)
+ * as well as information about the component
* and segment index where the point occurs.
* Locations inside area Geometrys will not have an associated segment index,
* so in this case the segment index will have the sentinel value of
@@ -53,31 +54,46 @@
int segIndex;
geom::Coordinate pt;
public:
- * Special value of segment-index for locations inside area geometries.
- * These locations do not have an associated segment index.
+ /** \brief
+ * A Special value of segmentIndex used for locations
+ * inside area geometries.
+ * These locations are not located on a segment,
+ * and thus do not have an associated segment index.
static const int INSIDE_AREA = -1;
- * Constructs a GeometryLocation specifying a point on a geometry, as well as the
- * segment that the point is on (or INSIDE_AREA if the point is not on a segment).
+ /** \brief
+ * Constructs a GeometryLocation specifying a point on a geometry,
+ * as well as the segment that the point is on (or INSIDE_AREA if
+ * the point is not on a segment).
+ * @param component the component of the geometry containing the point
+ * @param segIndex the segment index of the location, or INSIDE_AREA
+ * @param pt the coordinate of the location
- GeometryLocation(const geom::Geometry *newComponent,
- int newSegIndex, const geom::Coordinate &newPt);
+ GeometryLocation(const geom::Geometry *component,
+ int segIndex, const geom::Coordinate &pt);
- * Constructs a GeometryLocation specifying a point inside an area geometry.
+ /** \brief
+ * Constructs a GeometryLocation specifying a point inside an
+ * area geometry.
- GeometryLocation(const geom::Geometry *newComponent, const geom::Coordinate &newPt);
+ const geom::Coordinate &pt);
- * Returns the geometry associated with this location.
+ * Returns the geometry component on (or in) which this location occurs.
const geom::Geometry* getGeometryComponent();
- * Returns the segment index for this location. If the location is inside an
+ * Returns the segment index for this location.
+ * If the location is inside an
* area, the index will have the value INSIDE_AREA;
* @return the segment index for the location, or INSIDE_AREA
@@ -85,12 +101,13 @@
int getSegmentIndex();
- * Returns the location.
+ * Returns the geom::Coordinate of this location.
geom::Coordinate& getCoordinate();
- * Returns whether this GeometryLocation represents a point inside an area geometry.
+ /** \brief
+ * Tests whether this location represents a point
+ * inside an area geometry.
bool isInsideArea();
Modified: trunk/source/operation/distance/GeometryLocation.cpp
--- trunk/source/operation/distance/GeometryLocation.cpp 2009-06-08 10:29:54 UTC (rev 2560)
+++ trunk/source/operation/distance/GeometryLocation.cpp 2009-06-08 10:37:11 UTC (rev 2561)
@@ -14,7 +14,7 @@
More information about the geos-commits
