[geos-commits] r2575 - in trunk/tests/xmltester: . tests
svn_geos at osgeo.org
Mon Jun 15 02:57:10 EDT 2009
Author: strk
Date: 2009-06-15 02:57:10 -0400 (Mon, 15 Jun 2009)
New Revision: 2575
Added:
trunk/tests/xmltester/tests/bug176.xml
trunk/tests/xmltester/Makefile.am
Add XML version of the testcase provided for bug #176
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-06-10 16:18:01 UTC (rev 2574)
+++ trunk/tests/xmltester/Makefile.am 2009-06-15 06:57:10 UTC (rev 2575)
@@ -15,6 +15,7 @@
$(srcdir)/tests/linemerge.xml \
$(srcdir)/tests/TestIsValid.xml \
$(srcdir)/tests/robustness.xml \
+ $(srcdir)/tests/bug176.xml \
$(srcdir)/tests/bug188.xml \
$(srcdir)/tests/bug244.xml \
$(srcdir)/tests/general/TestBoundary.xml \
Added: trunk/tests/xmltester/tests/bug176.xml
--- trunk/tests/xmltester/tests/bug176.xml (rev 0)
+++ trunk/tests/xmltester/tests/bug176.xml 2009-06-15 06:57:10 UTC (rev 2575)
@@ -0,0 +1,40 @@
+<run>
+ <desc>
+ http://trac.osgeo.org/geos/ticket/176
+ </desc>
+ <precisionModel type="FLOATING" />
+ <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+ Polygon 1
+ </desc>
+ <a>
+POLYGON ((413.3999999999999773 243.0999999999999943, 607.2999999999999545 244.1999999999999886, 607.0000000000000000 294.8999999999999773, 697.8999999999999773 295.3999999999999773, 699.2000000000000455 241.8000000000000114, 416.8999999999999773 240.9000000000000057, 416.6999999999999886 162.3000000000000114, 413.1999999999999886 162.3000000000000114, 413.3999999999999773 243.0999999999999943))
+ </a>
+<test>
+ <op name='buffer' arg1='A' arg2='-2.0'>
+POLYGON ((609.1722610376851890 243.5129929302678704, 609.2638333893902427 243.8213729820575395, 609.2999649881396635 244.2118341123558309, 609.0118040315680901 292.9110357729544489, 695.9481804295313623 293.3892336629322699, 697.1510625643339836 243.7934779510754595, 609.1722610376851890 243.5129929302678704))
+ </op>
+</test>
+</case>
+<case>
+ <desc>
+ Polygon 2
+ </desc>
+ <a>
+POLYGON ((513.3999999999999773 343.1000000000000227, 707.2999999999999545 344.1999999999999886, 707.0000000000000000 394.8999999999999773, 797.8999999999999773 395.3999999999999773, 799.2000000000000455 341.8000000000000114, 516.8999999999999773 340.8999999999999773, 516.7000000000000455 262.3000000000000114, 513.2000000000000455 262.3000000000000114, 513.3999999999999773 343.1000000000000227))
+ </a>
+<test>
+POLYGON ((709.1722610376851890 343.5129929302678988, 709.2638333893902427 343.8213729820575963, 709.2999649881396635 344.2118341123558594, 709.0118040315680901 392.9110357729544489, 795.9481804295313623 393.3892336629322699, 797.1510625643339836 343.7934779510754879, 709.1722610376851890 343.5129929302678988))
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits
