[geos-commits] r2579 - in trunk/source: headers/geos/io io
svn_geos at osgeo.org
Mon Jun 15 10:03:52 EDT 2009
Author: strk
Date: 2009-06-15 10:03:52 -0400 (Mon, 15 Jun 2009)
New Revision: 2579
trunk/source/headers/geos/io/ByteOrderDataInStream.h
trunk/source/headers/geos/io/ByteOrderDataInStream.inl
trunk/source/headers/geos/io/ByteOrderValues.h
trunk/source/headers/geos/io/CLocalizer.h
trunk/source/headers/geos/io/ParseException.h
trunk/source/headers/geos/io/StringTokenizer.h
trunk/source/headers/geos/io/WKBConstants.h
trunk/source/headers/geos/io/WKBReader.h
trunk/source/headers/geos/io/WKBWriter.h
trunk/source/headers/geos/io/WKTReader.h
trunk/source/headers/geos/io/WKTReader.inl
trunk/source/headers/geos/io/WKTWriter.h
trunk/source/headers/geos/io/Writer.h
trunk/source/io/ByteOrderDataInStream.cpp
trunk/source/io/ByteOrderValues.cpp
trunk/source/io/CLocalizer.cpp
trunk/source/io/ParseException.cpp
trunk/source/io/StringTokenizer.cpp
trunk/source/io/WKBReader.cpp
trunk/source/io/WKBWriter.cpp
trunk/source/io/WKTReader.cpp
trunk/source/io/WKTWriter.cpp
trunk/source/io/Writer.cpp
Port info in the geos::io namespace
Modified: trunk/source/headers/geos/io/ByteOrderDataInStream.h
--- trunk/source/headers/geos/io/ByteOrderDataInStream.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/ByteOrderDataInStream.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: io/ByteOrderDataInStream.java rev. 1.1 (JTS-1.10)
#ifndef GEOS_IO_BYTEORDERDATAINSTREAM_H
Modified: trunk/source/headers/geos/io/ByteOrderDataInStream.inl
--- trunk/source/headers/geos/io/ByteOrderDataInStream.inl 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/ByteOrderDataInStream.inl 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#ifndef GEOS_IO_BYTEORDERDATAINSTREAM_INL
Modified: trunk/source/headers/geos/io/ByteOrderValues.h
--- trunk/source/headers/geos/io/ByteOrderValues.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/ByteOrderValues.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/ByteOrderValues.java rev. 1.3 (JTS-1.10)
#ifndef GEOS_IO_BYTEORDERVALUES_H
Modified: trunk/source/headers/geos/io/CLocalizer.h
--- trunk/source/headers/geos/io/CLocalizer.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/CLocalizer.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -1,3 +1,22 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2008 Sean Gillies
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: ORIGINAL WORK
#include <geos/export.h>
#include <string>
Modified: trunk/source/headers/geos/io/ParseException.h
--- trunk/source/headers/geos/io/ParseException.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/ParseException.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/ParseException.java rev. 1.13 (JTS-1.10)
#ifndef GEOS_IO_PARSEEXCEPTION_H
Modified: trunk/source/headers/geos/io/StringTokenizer.h
--- trunk/source/headers/geos/io/StringTokenizer.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/StringTokenizer.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#ifndef GEOS_IO_STRINGTOKENIZER_H
Modified: trunk/source/headers/geos/io/WKBConstants.h
--- trunk/source/headers/geos/io/WKBConstants.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKBConstants.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/WKBConstants.java rev. 1.1 (JTS-1.10)
#ifndef GEOS_IO_WKBCONSTANTS_H
Modified: trunk/source/headers/geos/io/WKBReader.h
--- trunk/source/headers/geos/io/WKBReader.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKBReader.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/WKBReader.java rev. 1.1 (JTS-1.7)
#ifndef GEOS_IO_WKBREADER_H
Modified: trunk/source/headers/geos/io/WKBWriter.h
--- trunk/source/headers/geos/io/WKBWriter.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKBWriter.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/WKBWriter.java rev. 1.1 (JTS-1.7)
#ifndef GEOS_IO_WKBWRITER_H
Modified: trunk/source/headers/geos/io/WKTReader.h
--- trunk/source/headers/geos/io/WKTReader.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKTReader.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/WKTReader.java rev. 1.1 (JTS-1.7)
#ifndef GEOS_IO_WKTREADER_H
Modified: trunk/source/headers/geos/io/WKTReader.inl
--- trunk/source/headers/geos/io/WKTReader.inl 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKTReader.inl 2009-06-15 14:03:52 UTC (rev 2579)
@@ -11,6 +11,10 @@
#ifndef GEOS_IO_WKTREADER_INL
Modified: trunk/source/headers/geos/io/WKTWriter.h
--- trunk/source/headers/geos/io/WKTWriter.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/WKTWriter.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: io/WKTWriter.java rev. 1.34 (JTS-1.7)
#ifndef GEOS_IO_WKTWRITER_H
Modified: trunk/source/headers/geos/io/Writer.h
--- trunk/source/headers/geos/io/Writer.h 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/headers/geos/io/Writer.h 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
+ * Last port: ORIGINAL WORK to be used like java.io.Writer
#ifndef GEOS_IO_WRITER_H
Modified: trunk/source/io/ByteOrderDataInStream.cpp
--- trunk/source/io/ByteOrderDataInStream.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/ByteOrderDataInStream.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -13,7 +13,7 @@
- * Last port:
Modified: trunk/source/io/ByteOrderValues.cpp
--- trunk/source/io/ByteOrderValues.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/ByteOrderValues.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -13,7 +13,7 @@
- * Last port: io/ByteOrderValues.java rev. 1.3 (JTS-1.7)
Modified: trunk/source/io/CLocalizer.cpp
--- trunk/source/io/CLocalizer.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/CLocalizer.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -1,3 +1,22 @@
+ * $Id$
#include <geos/io/CLocalizer.h>
#include <string>
Modified: trunk/source/io/ParseException.cpp
--- trunk/source/io/ParseException.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/ParseException.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#include <geos/io/ParseException.h>
Modified: trunk/source/io/StringTokenizer.cpp
--- trunk/source/io/StringTokenizer.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/StringTokenizer.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#include <geos/io/StringTokenizer.h>
Modified: trunk/source/io/WKBReader.cpp
--- trunk/source/io/WKBReader.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/WKBReader.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -11,6 +11,10 @@
#include <geos/io/WKBReader.h>
Modified: trunk/source/io/WKBWriter.cpp
--- trunk/source/io/WKBWriter.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/WKBWriter.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -11,6 +11,10 @@
#include <geos/io/WKBWriter.h>
Modified: trunk/source/io/WKTReader.cpp
--- trunk/source/io/WKTReader.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/WKTReader.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#include <geos/io/WKTReader.h>
Modified: trunk/source/io/WKTWriter.cpp
--- trunk/source/io/WKTWriter.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/WKTWriter.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#include <geos/io/WKTWriter.h>
Modified: trunk/source/io/Writer.cpp
--- trunk/source/io/Writer.cpp 2009-06-15 13:19:35 UTC (rev 2578)
+++ trunk/source/io/Writer.cpp 2009-06-15 14:03:52 UTC (rev 2579)
@@ -12,6 +12,10 @@
#include <geos/io/Writer.h>
More information about the geos-commits
