[geos-commits] r2589 - in trunk:
source/headers/geos/operation/buffer source/operation/buffer
tests/xmltester
svn_geos at osgeo.org
Tue Jun 16 11:33:47 EDT 2009
Author: strk
Date: 2009-06-16 11:33:47 -0400 (Tue, 16 Jun 2009)
New Revision: 2589
trunk/source/headers/geos/operation/buffer/BufferBuilder.h
trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
trunk/source/operation/buffer/BufferBuilder.cpp
trunk/source/operation/buffer/OffsetCurveBuilder.cpp
trunk/source/operation/buffer/OffsetCurveVertexList.h
trunk/tests/xmltester/XMLTester.cpp
Revert single-sided patch. Martin Davis is workin on it from the JTS side
Modified: trunk/source/headers/geos/operation/buffer/BufferBuilder.h
--- trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/source/headers/geos/operation/buffer/BufferBuilder.h 2009-06-16 15:33:47 UTC (rev 2589)
@@ -206,11 +206,6 @@
geom::Geometry* buffer(const geom::Geometry *g, double distance);
// throw (GEOSException);
- /// Not in JTS: this is a GEOS extension
- geom::Geometry* bufferLineSingleSided( const geom::Geometry* g,
- double distance, bool leftSide ) ;
- // throw (GEOSException);
} // namespace geos::operation::buffer
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-06-16 15:33:47 UTC (rev 2589)
@@ -91,25 +91,6 @@
std::vector<geom::CoordinateSequence*>& lineList);
- * This method handles single points as well as lines.
- * Lines are assumed to <b>not</b> be closed (the function will not
- * fail for closed lines, but will generate superfluous line caps).
- * @param lineList the std::vector to which CoordinateSequences will
- * be pushed_back
- * @param leftSide indicates that the left side buffer will be
- * obtained/skipped
- * @param rightSide indicates that the right side buffer will
- * be obtained/skipped
- * NOTE: this is a GEOS extension
- void getSingleSidedLineCurve(const geom::CoordinateSequence* inputPts,
- double distance, std::vector<geom::CoordinateSequence*>& lineList,
- bool leftSide, bool rightSide ) ;
* This method handles the degenerate cases of single points and lines,
* as well as rings.
@@ -248,9 +229,6 @@
int side;
- // Not in JTS, used for single-sided buffers
- int endCapIndex;
void init(double newDistance);
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/source/operation/buffer/BufferBuilder.cpp 2009-06-16 15:33:47 UTC (rev 2589)
@@ -26,15 +26,11 @@
#include <geos/geom/Geometry.h>
#include <geos/geom/Polygon.h>
#include <geos/geom/GeometryCollection.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/MultiLineString.h>
#include <geos/operation/buffer/BufferBuilder.h>
#include <geos/operation/buffer/OffsetCurveBuilder.h>
#include <geos/operation/buffer/OffsetCurveSetBuilder.h>
#include <geos/operation/buffer/BufferSubgraph.h>
#include <geos/operation/buffer/SubgraphDepthLocater.h>
-#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/operation/linemerge/LineMerger.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/noding/IntersectionAdder.h>
#include <geos/noding/SegmentString.h>
@@ -68,7 +64,6 @@
using namespace geos::noding;
using namespace geos::algorithm;
using namespace geos::operation::overlay;
-using namespace geos::operation::linemerge;
namespace geos {
namespace operation { // geos.operation
@@ -107,166 +102,6 @@
/*public*/
Geometry*
-BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
- bool leftSide )
- // Returns the line used to create a single-sided buffer.
- // Input requirement: Must be a LineString.
- const LineString* l = dynamic_cast< const LineString* >( g );
- if ( !l ) return NULL;
- // Get geometry factory and precision model.
- const PrecisionModel* precisionModel = workingPrecisionModel;
- if ( !precisionModel ) precisionModel = l->getPrecisionModel();
- assert( precisionModel );
- assert( l );
- geomFact = l->getFactory();
- // First, generate the two-sided buffer using a butt-cap.
- BufferParameters modParams = bufParams;
- modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
- Geometry* buf = buffer( l, distance );
- // Create MultiLineStrings from this polygon.
- Geometry* bufLineString = buf->getBoundary();
- // Then, get the raw (i.e. unnoded) single sided offset curve.
- OffsetCurveBuilder curveBuilder( precisionModel, modParams );
- std::vector< CoordinateSequence* > lineList;
- curveBuilder.getSingleSidedLineCurve( g->getCoordinates(), distance,
- lineList, leftSide, !leftSide );
- // Create a SegmentString from these coordinates.
- SegmentString::NonConstVect curveList;
- for ( unsigned int i = 0; i < lineList.size(); ++i )
- CoordinateSequence* seq = lineList[i];
- curveList.push_back( new NodedSegmentString( seq, NULL ) );
- // Node these SegmentStrings.
- Noder* noder = getNoder( precisionModel );
- noder->computeNodes( &curveList );
- SegmentString::NonConstVect* nodedEdges = noder->getNodedSubstrings();
- // Create a geometry out of the noded substrings.
- std::vector< Geometry* >* singleSidedNodedEdges =
- new std::vector< Geometry * >();
- for ( unsigned int i = 0; i < nodedEdges->size(); ++i )
- singleSidedNodedEdges->push_back( geomFact->createLineString(
- ( *nodedEdges )[i]->getCoordinates() ) );
- Geometry* singleSided = geomFact->createMultiLineString(
- singleSidedNodedEdges );
- // Use the boolean operation intersect to obtain the line segments lying
- // on both the butt-cap buffer and this multi-line.
- Geometry* intersectedLines = singleSided->intersection( bufLineString );
- // Merge result lines together.
- LineMerger lineMerge;
- lineMerge.add( intersectedLines );
- std::vector< LineString* >* mergedLines = lineMerge.getMergedLineStrings();
- // Convert the result into a std::vector< Geometry* >.
- std::vector< Geometry* >* mergedLinesGeom = new std::vector< Geometry* >();
- const Coordinate& startPoint = l->getCoordinatesRO()->front();
- const Coordinate& endPoint = l->getCoordinatesRO()->back();
- while( !mergedLines->empty() )
- // Remove end points if they are a part of the original line to be
- // buffered.
- CoordinateSequence::AutoPtr coords(mergedLines->back()->getCoordinates());
- if ( NULL != coords.get() )
- // Use 98% of the buffer width as the point-distance requirement - this
- // is to ensure that the point that is "distance" +/- epsilon is not
- // included.
- const double ptDistAllowance = 0.98 * distance;
- // Use 102% of the buffer width as the line-length requirement - this
- // is to ensure that line segments that is length "distance" +/-
- // epsilon is removed.
- const double segLengthAllowance = 1.02 * distance;
- // Clean up the front of the list.
- // Loop until the line's end is not inside the buffer width from
- // the startPoint.
- while ( coords->size() > 1 &&
- coords->front().distance( startPoint ) < ptDistAllowance )
- // Record the end segment length.
- double segLength = coords->front().distance( ( *coords )[1] );
- // Stop looping if there are no more points, or if the segment
- // length is larger than the buffer width.
- if ( coords->size() <= 1 || segLength > segLengthAllowance )
- break;
- // If the first point is less than buffer width away from the
- // reference point, then delete the point.
- coords->deleteAt( 0 );
- coords->front().distance( endPoint ) < ptDistAllowance )
- break;
- // Clean up the back of the list.
- coords->back().distance( startPoint ) < ptDistAllowance )
- double segLength = coords->back().distance(
- ( *coords )[coords->size()-2] );
- break;
- coords->deleteAt( coords->size()-1 );
- coords->back().distance( endPoint ) < ptDistAllowance )
- break;
- // Add the coordinates to the resultant line string.
- if ( coords->size() > 1 )
- mergedLinesGeom->push_back( geomFact->createLineString( coords.release() ) );
- geomFact->destroyGeometry( mergedLines->back() );
- mergedLines->pop_back();
- // Clean up.
- if ( noder != workingNoder ) delete noder;
- geomFact->destroyGeometry( buf );
- geomFact->destroyGeometry( bufLineString );
- geomFact->destroyGeometry( singleSided );
- geomFact->destroyGeometry( intersectedLines );
- return geomFact->createMultiLineString( mergedLinesGeom );
-/*public*/
-Geometry*
BufferBuilder::buffer(const Geometry *g, double distance)
// throw(GEOSException *)
Modified: trunk/source/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/source/operation/buffer/OffsetCurveBuilder.cpp 2009-06-16 15:33:47 UTC (rev 2589)
@@ -82,7 +82,6 @@
offset0(),
offset1(),
side(0),
- endCapIndex(0),
vertexLists()
// compute intersections in full precision, to provide accuracy
@@ -145,62 +144,6 @@
/*public*/
void
-OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
- double distance, vector<CoordinateSequence*>& lineList, bool leftSide,
- bool rightSide)
- // A zero or negative width buffer of a line/point is empty.
- if ( distance <= 0.0 ) return ;
- init( distance ) ;
- if ( inputPts->getSize() < 2 )
- // No cap, so just return.
- return ;
- else
- computeLineBufferCurve( *inputPts ) ;
- // NOTE: we take ownership of lineCoord here ...
- CoordinateSequence* lineCoord = vertexList->getCoordinates() ;
- // [swong] April 24, 2008
- // Left side: index [n-2] to [endCapIndex]
- // Right side: index [endCapIndex] to [n-2]
- // Where n is the last index (size-1).
- int n = lineCoord->size() - 1 ;
- // Add the left side curve to the line list.
- if ( leftSide )
- CoordinateArraySequence* coordSeq = new CoordinateArraySequence() ;
- coordSeq->add( ( *lineCoord )[n-2] ) ;
- coordSeq->add( ( *lineCoord )[n-1] ) ;
- for ( int i = 0 ; i <= endCapIndex ; ++i )
- coordSeq->add( ( *lineCoord )[i] ) ;
- lineList.push_back( coordSeq ) ;
- // Add the right side curve to the line list.
- if ( rightSide )
- for ( int i = endCapIndex ; i <= n-2 ; ++i )
-/*public*/
-void
OffsetCurveBuilder::getRingCurve(const CoordinateSequence *inputPts,
int side, double distance,
vector<CoordinateSequence*>& lineList)
@@ -283,10 +226,6 @@
// add line cap for end of line
addLineEndCap(simp1[n1-1], simp1[n1]);
- // Record the index of the end of line cap.
- endCapIndex = vertexList->size() - 2 ;
//---------- compute points for right side of line
#ifndef SKIP_INPUT_SIMPLIFICATION
// Simplify the appropriate side of the line before generating
Modified: trunk/source/operation/buffer/OffsetCurveVertexList.h
--- trunk/source/operation/buffer/OffsetCurveVertexList.h 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/source/operation/buffer/OffsetCurveVertexList.h 2009-06-16 15:33:47 UTC (rev 2589)
@@ -157,8 +157,6 @@
return ret;
- inline int size() const { return ptList ? ptList->size() : 0 ; }
std::ostream& operator<< (std::ostream& os, const OffsetCurveVertexList& lst)
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-06-16 00:40:20 UTC (rev 2588)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-06-16 15:33:47 UTC (rev 2589)
@@ -852,6 +852,9 @@
expected_result=printGeom(gRes.get());
+// disabled till we have an actual api exposed for that
+// (and probably a different name)
+#if 0
else if (opName=="buffersinglesided")
using namespace operation::buffer;
@@ -918,6 +921,7 @@
actual_result=printGeom(gRealRes.get());
+#endif
else if (opName=="buffermitredjoin")
More information about the geos-commits
