[geos-commits] r2591 - in trunk/source: algorithm
headers/geos/algorithm
svn_geos at osgeo.org
Tue Jun 16 11:46:11 EDT 2009
Author: strk
Date: 2009-06-16 11:46:10 -0400 (Tue, 16 Jun 2009)
New Revision: 2591
trunk/source/algorithm/RobustDeterminant.cpp
trunk/source/headers/geos/algorithm/RobustDeterminant.h
Sync RobustDeterminant to revision 1.14
Modified: trunk/source/algorithm/RobustDeterminant.cpp
--- trunk/source/algorithm/RobustDeterminant.cpp 2009-06-16 15:43:14 UTC (rev 2590)
+++ trunk/source/algorithm/RobustDeterminant.cpp 2009-06-16 15:46:10 UTC (rev 2591)
@@ -15,7 +15,7 @@
- * Last port: algorithm/RobustDeterminant.java 1.13 (JTS-1.7)
+ * Last port: algorithm/RobustDeterminant.java 1.14 (JTS-1.7)
Modified: trunk/source/headers/geos/algorithm/RobustDeterminant.h
--- trunk/source/headers/geos/algorithm/RobustDeterminant.h 2009-06-16 15:43:14 UTC (rev 2590)
+++ trunk/source/headers/geos/algorithm/RobustDeterminant.h 2009-06-16 15:46:10 UTC (rev 2591)
@@ -14,7 +14,7 @@
@@ -51,6 +51,15 @@
class GEOS_DLL RobustDeterminant {
public:
+ /** \brief
+ * Computes the sign of the determinant of the 2x2 matrix
+ * with the given entries, in a robust way.
+ * @return -1 if the determinant is negative,
+ * @return 1 if the determinant is positive,
+ * @return 0 if the determinant is 0.
static int signOfDet2x2(double x1,double y1,double x2,double y2);
More information about the geos-commits
