[geos-commits] r2594 - in trunk/tests/unit: . capi
svn_geos at osgeo.org
Sat Jun 20 04:53:05 EDT 2009
Author: strk
Date: 2009-06-20 04:53:05 -0400 (Sat, 20 Jun 2009)
New Revision: 2594
Added:
trunk/tests/unit/capi/GEOSBufferTest.cpp
trunk/tests/unit/Makefile.am
Add tests for GEOSBufferWithStyle
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2009-06-19 22:32:10 UTC (rev 2593)
+++ trunk/tests/unit/Makefile.am 2009-06-20 08:53:05 UTC (rev 2594)
@@ -86,7 +86,8 @@
capi/GEOSWithinTest.cpp \
capi/GEOSSimplifyTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
- capi/GEOSPolygonizer_getCutEdgesTest.cpp
+ capi/GEOSPolygonizer_getCutEdgesTest.cpp \
+ capi/GEOSBufferTest.cpp
noinst_HEADERS = \
utility.h
Added: trunk/tests/unit/capi/GEOSBufferTest.cpp
--- trunk/tests/unit/capi/GEOSBufferTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSBufferTest.cpp 2009-06-20 08:53:05 UTC (rev 2594)
@@ -0,0 +1,380 @@
+// $Id: GEOSWithinTest.cpp 2424 2009-04-29 23:52:36Z mloskot $
+// Test Suite for C-API GEOSBuffer and GEOSBufferWithStyle
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeosbuffer_data
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ char* wkt_;
+ double area_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeosbuffer_data()
+ : geom1_(0), geom2_(0), wkt_(0)
+ initGEOS(notice, notice);
+ ~test_capigeosbuffer_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ GEOSFree(wkt_);
+ geom1_ = 0;
+ geom2_ = 0;
+ wkt_ = 0;
+ finishGEOS();
+ typedef test_group<test_capigeosbuffer_data> group;
+ typedef group::object object;
+ group test_capigeosbuffer_group("capi::GEOSBuffer");
+ // Test Cases
+ // Buffer against empty point
+ template<>
+ template<>
+ void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("POINT EMPTY");
+ ensure( 0 != geom1_ );
+ geom2_ = GEOSBufferWithStyle(geom1_, 1, 8,
+ GEOSBUF_CAP_ROUND,
+ GEOSBUF_JOIN_BEVEL,
+ 5.0);
+ ensure( 0 != geom2_ );
+ wkt_ = GEOSGeomToWKT(geom2_);
+ ensure_equals(std::string(wkt_), std::string("POLYGON EMPTY"));
+ // Buffer against empty linestring
+ template<>
+ template<>
+ void object::test<2>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+ 5.0);
+ // Buffer against empty polygon
+ template<>
+ template<>
+ void object::test<3>()
+ geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ 5.0);
+ // Simple Buffer on a 2-vertices line (quadSegs: 1)
+ template<>
+ template<>
+ void object::test<4>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 20)");
+ geom2_ = GEOSBuffer(geom1_, 5, 1);
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 7);
+ ensure(GEOSArea(geom2_, &area_));
+ ensure_distance(area_, 161.803, 0.001);
+ // Simple Buffer on a 2-vertices line (quadSegs: 2)
+ template<>
+ template<>
+ void object::test<5>()
+ geom2_ = GEOSBuffer(geom1_, 5, 2);
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 11);
+ ensure_distance(area_, 182.514, 0.001);
+ // Buffer with square end caps on a 2-vertices line (no matter quadSegs)
+ template<>
+ template<>
+ void object::test<6>()
+ geom2_ = GEOSBufferWithStyle(geom1_, 5, 20, GEOSBUF_CAP_SQUARE,
+ GEOSBUF_JOIN_ROUND, 5.0);
+ ensure_distance(area_, 211.803, 0.001);
+ // Buffer with flat end caps on a 2-vertices line (no matter quadSegs)
+ template<>
+ template<>
+ void object::test<7>()
+ geom2_ = GEOSBufferWithStyle(geom1_, 5, 20, GEOSBUF_CAP_FLAT,
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 5);
+ ensure_distance(area_, 111.803, 0.001);
+ // Buffer with flat end cap on a 2-vertices horizontal line
+ template<>
+ template<>
+ void object::test<8>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 10)");
+ ensure_distance(area_, 50.0, 0.001);
+"POLYGON ((10.0000000000000000 15.0000000000000000, 10.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 5.0000000000000000 15.0000000000000000, 10.0000000000000000 15.0000000000000000))"
+ // Buffer with square end cap on a 2-vertices horizontal line
+ template<>
+ template<>
+ void object::test<9>()
+ ensure_distance(area_, 150.0, 0.001);
+"POLYGON ((10.0000000000000000 15.0000000000000000, 15.0000000000000000 15.0000000000000000, 15.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 10.0000000000000000 15.0000000000000000))"
+ // Buffer with flat end cap and round join style
+ // on an L-shaped simple line
+ template<>
+ template<>
+ void object::test<10>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(5 10, 10 10, 10 20)");
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 29);
+ ensure_distance(area_, 244.615, 0.001);
+ // Buffer with flat end cap and mitre join style
+ template<>
+ template<>
+ void object::test<11>()
+ GEOSBUF_JOIN_MITRE, 5.0);
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 9);
+ ensure_distance(area_, 250.0, 0.001);
+"POLYGON ((5.0000000000000000 15.0000000000000000, 5.0000000000000000 20.0000000000000000, 5.0000000000000000 25.0000000000000000, 15.0000000000000000 25.0000000000000000, 15.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 5.0000000000000000 15.0000000000000000))"
+ // Buffer with flat end cap and bevel join style
+ template<>
+ template<>
+ void object::test<12>()
+ GEOSBUF_JOIN_BEVEL, 5.0);
+ ensure_equals(GEOSGetNumCoordinates(geom2_), 10);
+ ensure_distance(area_, 237.5, 0.001);
+"POLYGON ((5.0000000000000000 15.0000000000000000, 5.0000000000000000 20.0000000000000000, 5.0000000000000000 25.0000000000000000, 15.0000000000000000 25.0000000000000000, 15.0000000000000000 10.0000000000000000, 10.0000000000000000 5.0000000000000000, 5.0000000000000000 5.0000000000000000, 0.0000000000000000 5.0000000000000009, 0.0000000000000000 15.0000000000000000, 5.0000000000000000 15.0000000000000000))"
+ // on an L-shaped simple line with different quadSegs and mitreLimit
+ // (result unaffected)
+ template<>
+ template<>
+ void object::test<13>()
+ geom2_ = GEOSBufferWithStyle(geom1_, 5, 200, GEOSBUF_CAP_SQUARE,
+ GEOSBUF_JOIN_BEVEL, 10.0);
+} // namespace tut
More information about the geos-commits
