[geos-commits] r2602 - trunk
svn_geos at osgeo.org
Wed Jun 24 17:21:11 EDT 2009
Author: pramsey
Date: 2009-06-24 17:21:11 -0400 (Wed, 24 Jun 2009)
New Revision: 2602
trunk/configure.in
Remove old logging noise.
Modified: trunk/configure.in
--- trunk/configure.in 2009-06-24 21:19:53 UTC (rev 2601)
+++ trunk/configure.in 2009-06-24 21:21:11 UTC (rev 2602)
@@ -116,11 +116,6 @@
dnl
AC_LIBTOOL_LANG_CXX_CONFIG
-echo "NOTE ---- CXX=${CXX}"
-echo "NOTE ---- compiler=${compiler}"
-echo "NOTE ---- ac_compile=${ac_compiler}"
-echo "NOTE ---- lt_simple_compile_test_code=${lt_simple_compile_test_code}"
# Set default CXXFLAGS and CFLAGS if not set by the user
# -pedantic: ISO does not support long long
# we add -Wno-long-long to avoid those messages
More information about the geos-commits
