[geos-commits] r2275 - trunk/source/geom
svn_geos at osgeo.org
Wed Mar 11 08:18:47 EDT 2009
Author: mloskot
Date: 2009-03-11 08:18:47 -0400 (Wed, 11 Mar 2009)
New Revision: 2275
trunk/source/geom/CoordinateArraySequence.cpp
Number of assertions in CoordinateArraySequence class.
Modified: trunk/source/geom/CoordinateArraySequence.cpp
--- trunk/source/geom/CoordinateArraySequence.cpp 2009-03-10 17:29:50 UTC (rev 2274)
+++ trunk/source/geom/CoordinateArraySequence.cpp 2009-03-11 12:18:47 UTC (rev 2275)
@@ -61,30 +61,35 @@
void
CoordinateArraySequence::setPoints(const vector<Coordinate> &v)
+ assert(0 != vect);
vect->assign(v.begin(), v.end());
const vector<Coordinate>*
CoordinateArraySequence::toVector() const
return vect; //new vector<Coordinate>(vect->begin(),vect->end());
bool
CoordinateArraySequence::isEmpty() const
return vect->empty();
void
CoordinateArraySequence::add(const Coordinate& c)
vect->push_back(c);
void
CoordinateArraySequence::add(const Coordinate& c, bool allowRepeated)
if (!allowRepeated && ! vect->empty() )
const Coordinate& last=vect->back();
@@ -102,13 +107,15 @@
const Coordinate &
CoordinateArraySequence::getAt(size_t pos) const
- assert(pos<vect->size());
+ assert(pos < vect->size());
return (*vect)[pos];
void
CoordinateArraySequence::getAt(size_t pos, Coordinate &c) const
c=(*vect)[pos];
@@ -116,6 +123,7 @@
void
CoordinateArraySequence::setAt(const Coordinate& c, size_t pos)
(*vect)[pos]=c;
@@ -123,6 +131,7 @@
void
CoordinateArraySequence::deleteAt(size_t pos)
vect->erase(vect->begin()+pos);
@@ -153,6 +162,7 @@
void
CoordinateArraySequence::expandEnvelope(Envelope &env) const
size_t size = vect->size();
for (size_t i=0; i<size; i++) env.expandToInclude((*vect)[i]);
@@ -160,7 +170,7 @@
double
CoordinateArraySequence::getOrdinate(size_t index, size_t ordinateIndex) const
assert(index<vect->size());
switch (ordinateIndex)
@@ -181,6 +191,7 @@
double value)
assert(ordinateIndex == CoordinateSequence::X
@@ -206,6 +217,7 @@
void
CoordinateArraySequence::apply_rw(const CoordinateFilter *filter)
for (vector<Coordinate>::iterator i=vect->begin(), e=vect->end(); i!=e; ++i)
filter->filter_rw(&(*i));
@@ -215,6 +227,7 @@
void
CoordinateArraySequence::apply_ro(CoordinateFilter *filter) const
for (vector<Coordinate>::const_iterator i=vect->begin(), e=vect->end(); i!=e; ++i)
filter->filter_ro(&(*i));
@@ -224,6 +237,7 @@
CoordinateSequence&
CoordinateArraySequence::removeRepeatedPoints()
// We use == operator, which is 2D only
vector<Coordinate>::iterator new_end = \
std::unique(vect->begin(), vect->end());
More information about the geos-commits
