[geos-commits] r2297 - trunk/capi
svn_geos at osgeo.org
Mon Mar 23 18:19:44 EDT 2009
Author: mloskot
Date: 2009-03-23 18:19:44 -0400 (Mon, 23 Mar 2009)
New Revision: 2297
trunk/capi/geos_ts_c.cpp
capi/geos_ts_c.cpp: refactoring, use single return expression per function, added assert() to test against nullptr where it is forbidden, addd some comments.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-03-23 21:07:56 UTC (rev 2296)
+++ trunk/capi/geos_ts_c.cpp 2009-03-23 22:19:44 UTC (rev 2297)
@@ -1609,13 +1609,13 @@
catch (const std::exception &e)
handle->ERROR_MESSAGE("%s", e.what());
- return -1;
catch (...)
handle->ERROR_MESSAGE("Unknown exception thrown");
- return -1;
+ return -1;
@@ -1637,21 +1637,21 @@
return -1;
- try{
+ try
g1->normalize();
+ return 0; // SUCCESS
- return -1;
catch (...)
- return -1;
- return 0;
+ return -1;
int
@@ -1669,26 +1669,26 @@
return -1;
- try{
+ try
const Polygon *p = dynamic_cast<const Polygon *>(g1);
- if ( ! p )
- handle->ERROR_MESSAGE("Argument is not a Polygon");
- return -1;
+ if ( ! p )
+ handle->ERROR_MESSAGE("Argument is not a Polygon");
+ return -1;
return static_cast<int>(p->getNumInteriorRing());
- return -1;
catch (...)
- return -1;
+ return -1;
@@ -1715,13 +1715,13 @@
- return -1;
catch (...)
- return -1;
+ return -1;
@@ -1744,9 +1744,9 @@
return NULL;
- using geos::geom::GeometryCollection;
try
+ using geos::geom::GeometryCollection;
const GeometryCollection *gc = dynamic_cast<const GeometryCollection *>(g1);
if ( ! gc )
@@ -1758,13 +1758,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
@@ -1800,13 +1800,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
@@ -1841,17 +1841,15 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
Geometry *
GEOSGetCentroid_r(GEOSContextHandle_t extHandle, const Geometry *g)
@@ -1880,13 +1878,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
Geometry *
@@ -1913,11 +1911,10 @@
try
- Geometry *g;
- const GeometryFactory *gf;
- gf=handle->geomFactory;
- std::vector<Geometry *> *vgeoms = new std::vector<Geometry *>(geoms, geoms+ngeoms);
+ const GeometryFactory* gf = handle->geomFactory;
+ std::vector<Geometry*>* vgeoms = new std::vector<Geometry*>(geoms, geoms + ngeoms);
+ Geometry *g = 0;
switch (type)
case GEOS_GEOMETRYCOLLECTION:
@@ -1934,23 +1931,22 @@
break;
default:
handle->ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
- g = NULL;
+ g = 0;
- if (g==NULL) return NULL;
return g;
- return NULL;
catch (...)
- return NULL;
+ return 0;
Geometry *
@@ -1958,60 +1954,69 @@
if ( 0 == extHandle )
- return NULL;
+ return 0;
GEOSContextHandleInternal_t *handle = 0;
handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if ( 0 == handle->initialized )
- return NULL;
+ return 0;
- using geos::operation::polygonize::Polygonizer;
- unsigned int i;
- Geometry *out = NULL;
+ Geometry *out = 0;
- try{
+ try
// Polygonize
+ using geos::operation::polygonize::Polygonizer;
Polygonizer plgnzr;
- for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
+ for (std::size_t i = 0; i < ngeoms; ++i)
+ plgnzr.add(g[i]);
#if GEOS_DEBUG
- handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
+ handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
#endif
- std::vector<Polygon *>*polys = plgnzr.getPolygons();
+ std::vector<Polygon*> *polys = plgnzr.getPolygons();
+ assert(0 != polys);
#if GEOS_DEBUG
- handle->NOTICE_MESSAGE("output polygons got");
+ handle->NOTICE_MESSAGE("output polygons got");
#endif
- // We need a vector of Geometry pointers, not
- // Polygon pointers.
+ // We need a vector of Geometry pointers, not Polygon pointers.
// STL vector doesn't allow transparent upcast of this
// nature, so we explicitly convert.
// (it's just a waste of processor and memory, btw)
- std::vector<Geometry*> *polyvec =
- new std::vector<Geometry *>(polys->size());
- for (i=0; i<polys->size(); i++) (*polyvec)[i] = (*polys)[i];
+ // XXX mloskot: Why not to extent GeometryFactory to accept
+ // vector of polygons or extend Polygonizer to return list of Geometry*
+ // or add a wrapper which semantic is similar to:
+ // std::vector<as_polygon<Geometry*> >
+ std::vector<Geometry*> *polyvec = new std::vector<Geometry *>(polys->size());
+ for (std::size_t i = 0; i < polys->size(); ++i)
+ (*polyvec)[i] = (*polys)[i];
delete polys;
+ const GeometryFactory *gf = handle->geomFactory;
+ // The below takes ownership of the passed vector,
+ // so we must *not* delete it
out = gf->createGeometryCollection(polyvec);
- // the above method takes ownership of the passed
- // vector, so we must *not* delete it
- return NULL;
catch (...)
- return NULL;
return out;
@@ -2032,49 +2037,55 @@
return NULL;
- unsigned int i;
- try{
+ try
// Polygonize
Polygonizer plgnzr;
+ plgnzr.add(g[i]);
#if GEOS_DEBUG
#endif
- std::vector<const LineString *>*lines = plgnzr.getCutEdges();
+ std::vector<const LineString *>* lines = plgnzr.getCutEdges();
+ assert(0 != lines);
#if GEOS_DEBUG
#endif
- std::vector<Geometry*> *linevec =
- new std::vector<Geometry *>(lines->size());
- for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
+ // XXX mloskot: See comment for GEOSPolygonize_r
+ std::vector<Geometry*> *linevec = new std::vector<Geometry *>(lines->size());
+ for (std::size_t i = 0; i < lines->size(); ++i)
+ (*linevec)[i] = (*lines)[i]->clone();
+ // FIXME mloskot: Who deallocates vector pointed by lines* ?
out = gf->createGeometryCollection(linevec);
- return NULL;
catch (...)
- return NULL;
return out;
More information about the geos-commits
