[geos-commits] r2309 - in trunk: . source
svn_geos at osgeo.org
Thu Mar 26 22:38:54 EDT 2009
Author: mloskot
Date: 2009-03-26 22:38:54 -0400 (Thu, 26 Mar 2009)
New Revision: 2309
Added:
trunk/nmake.opt
trunk/source/Makefile.vc
Forgotten nmake.opt in last commit.
Added: trunk/nmake.opt
--- trunk/nmake.opt (rev 0)
+++ trunk/nmake.opt 2009-03-27 02:38:54 UTC (rev 2309)
@@ -0,0 +1,153 @@
+# $Id$
+# nmake.opt - main configuration file for NMAKE makefiles
+!MESSAGE **********************************************************************
+!MESSAGE *** GEOS Build Configuration ***
+!INCLUDE <ntwin32.mak>
+# For convenience, user may put custom settings to private mynmake.opt
+# and use EXT_NMAKE_OPT option while calling nmake.exe, as follows:
+# nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt
+!IFDEF EXT_NMAKE_OPT
+!MESSAGE *** Setting EXT_NMAKE_OPT $(EXT_NMAKE_OPT)
+!INCLUDE $(EXT_NMAKE_OPT)
+!ENDIF
+# Set BUILD_DEBUG to YES if you want to make debug build
+# and to prepare not optimized binaries.
+!IFNDEF BUILD_DEBUG
+BUILD_DEBUG = NO
+!ENDIF
+!MESSAGE *** Setting BUILD_DEBUG $(BUILD_DEBUG)
+# Set BUILD_BATCH to YES if you want feed compiler with all
+# source .c and .cpp files in single batch.
+!IFNDEF BUILD_BATCH
+BUILD_BATCH = NO
+!ENDIF
+# Derive version of Visual C++ being used from NMAKE if not specified
+# WARNING:
+# If we should expect variety of NMAKE build versions, tests below may fail
+# and we will need to fall back to setting GEOS_MSVC as command line parameter.
+!IF "$(_NMAKE_VER)" == ""
+GEOS_MSVC = 4.0
+!ERROR *** Failed to determine version of Visual C++
+!ELSEIF "$(_NMAKE_VER)" == "162"
+GEOS_MSVC = 5.0
+!ERROR *** Detected Visual C++ 5.0 - NOT SUPPORTED
+!ELSEIF "$(_NMAKE_VER)" == "6.00.8168.0"
+GEOS_MSVC = 6.0
+GEOS_MSC = 1200
+!ERROR *** Detected Visual C++ 6.0 - NOT SUPPORTED
+!ELSEIF "$(_NMAKE_VER)" == "7.00.9466"
+GEOS_MSVC = 7.0
+GEOS_MSC = 1300
+!ELSEIF "$(_NMAKE_VER)" == "7.10.3077"
+GEOS_MSVC = 7.1
+GEOS_MSC = 1310
+!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.42"
+GEOS_MSVC = 8.0
+GEOS_MSC = 1400
+!ELSEIF "$(_NMAKE_VER)" == "8.00.50727.762"
+GEOS_MSVC = 8.0
+GEOS_MSC = 1400
+!ELSEIF "$(_NMAKE_VER)" == "9.00.30729.01"
+GEOS_MSVC = 9.0
+GEOS_MSC = 1500
+!ELSE
+GEOS_MSVC = 0.0
+GEOS_MSC = 0
+!ENDIF
+!IF "$(GEOS_MSVC)" == "0.0" && "$(GEOS_MSC)" == "0"
+!MESSAGE *** Cannot determined Visual C++ version
+!ERROR *** Aborting make job
+!ELSE
+!MESSAGE *** Using Microsoft NMAKE version $(_NMAKE_VER)
+!MESSAGE *** Using Microsoft Visual C++ version $(GEOS_MSVC)
+!MESSAGE *** Using Microsoft C/C++ version $(GEOS_MSC)
+!ENDIF
+# Include directories
+GEOS_INCLUDE = -Iheaders
+!MESSAGE *** Setting GEOS_INCLUDE $(GEOS_INCLUDE)
+!MESSAGE *** Setting INCLUDE $(INCLUDE)
+# Compilation flags for Release and Debug modes
+GEOS_CPPFLAGS = /D "NOMINMAX" /D "WIN32_LEAN_AND_MEAN" /D "NOGDI"
+!IF "$(BUILD_DEBUG)" == "YES"
+BUILD_PREFIX=_d
+GEOS_CFLAGS = /nologo /MDd /GR /Od /W4 /Zi
+GEOS_CPPFLAGS = /D "NDEBUG" $(GEOS_CPPFLAGS)
+!ELSE
+GEOS_CFLAGS = /nologo /MD /GR /O2 /W3
+!ENDIF
+# Compiler version specific flags
+!IF $(GEOS_MSC) >= 1400
+GEOS_CFLAGS = $(GEOS_CFLAGS) /EHs
+GEOS_CPPFLAGS = $(GEOS_CPPFLAGS) /D "_CRT_SECURE_NO_DEPRECATE" /D "_CRT_NONSTDC_NO_DEPRECATE" /D "_SCL_SECURE_NO_DEPRECATE"
+!ELSE
+GEOS_CFLAGS = $(GEOS_CFLAGS) /GX
+!ENDIF
+# For Visual C++ 9.0+ use multiple process build
+!IF $(GEOS_MSC) > 1400
+MPFLAGS = /MP
+BUILD_BATCH = YES
+!MESSAGE *** Setting /MP flag to number of effective processors
+!ENDIF
+!MESSAGE *** Using CFLAGS $(GEOS_CFLAGS)
+!MESSAGE *** Using CPPFLAGS $(GEOS_CPPFLAGS)
+CFLAGS= $(MPFLAGS) $(GEOS_CFLAGS) $(GEOS_CPPFLAGS) $(GEOS_INCLUDE)
+# Output location
+LIBNAME = geos$(BUILD_PREFIX).lib
+DLLNAME = geos$(BUILD_PREFIX).dll
+SLIBNAME = geos_i$(BUILD_PREFIX).lib
+CDLLNAME = geos_c$(BUILD_PREFIX).dll
+CLIBNAME = geos_c_i$(BUILD_PREFIX).lib
+# Building toolset programs
+MAKE = nmake
+CC = cl
+RM = del
+CP = copy
+# Linker executable
+# - Dynamic-Linked Libraries
+# $(LINK) /dll
+# - Static Libraries (use of lib.exe wrapper is not portable, see VC++ Toolkit 2003)
+# $(LINK) /lib
+LINK = link.exe
+# EOF
\ No newline at end of file
Modified: trunk/source/Makefile.vc
--- trunk/source/Makefile.vc 2009-03-26 21:52:01 UTC (rev 2308)
+++ trunk/source/Makefile.vc 2009-03-27 02:38:54 UTC (rev 2309)
@@ -20,252 +20,257 @@
!INCLUDE dirlist.mk
+# Output location
+# TODO: not yet supported
+#OUT_DIR = $(GEOS_ROOT)\bin\$(BUILD_DIR)
# List of objects
-# .obj
-INCEXT = obj
-INEXT = obj
+OBJ_EXT = obj
+EXT = $(OBJ_EXT)
OBJ = \
- algorithm\CentroidArea.$(INEXT) \
- algorithm\CentroidLine.$(INEXT) \
- algorithm\CentroidPoint.$(INEXT) \
- algorithm\CGAlgorithms.$(INEXT) \
- algorithm\ConvexHull.$(INEXT) \
- algorithm\HCoordinate.$(INEXT) \
- algorithm\InteriorPointArea.$(INEXT) \
- algorithm\InteriorPointLine.$(INEXT) \
- algorithm\InteriorPointPoint.$(INEXT) \
- algorithm\LineIntersector.$(INEXT) \
- algorithm\MCPointInRing.$(INEXT) \
- algorithm\MinimumDiameter.$(INEXT) \
- algorithm\NotRepresentableException.$(INEXT) \
- algorithm\PointLocator.$(INEXT) \
- algorithm\RayCrossingCounter.$(INEXT) \
- algorithm\RobustDeterminant.$(INEXT) \
- algorithm\SimplePointInRing.$(INEXT) \
- algorithm\SIRtreePointInRing.$(INEXT) \
- algorithm\locate\IndexedPointInAreaLocator.$(INEXT) \
- algorithm\locate\PointOnGeometryLocator.$(INEXT) \
- algorithm\locate\SimplePointInAreaLocator.$(INEXT) \
- geom\Coordinate.$(INEXT) \
- geom\CoordinateArraySequence.$(INEXT) \
- geom\CoordinateArraySequenceFactory.$(INEXT) \
- geom\CoordinateSequence.$(INEXT) \
- geom\Dimension.$(INEXT) \
- geom\Envelope.$(INEXT) \
- geom\Geometry.$(INEXT) \
- geom\GeometryCollection.$(INEXT) \
- geom\GeometryComponentFilter.$(INEXT) \
- geom\GeometryFactory.$(INEXT) \
- geom\IntersectionMatrix.$(INEXT) \
- geom\LinearRing.$(INEXT) \
- geom\LineSegment.$(INEXT) \
- geom\LineString.$(INEXT) \
- geom\Location.$(INEXT) \
- geom\MultiLineString.$(INEXT) \
- geom\MultiPoint.$(INEXT) \
- geom\MultiPolygon.$(INEXT) \
- geom\Point.$(INEXT) \
- geom\Polygon.$(INEXT) \
- geom\PrecisionModel.$(INEXT) \
- geom\Triangle.$(INEXT) \
- geom\util\CoordinateOperation.$(INEXT) \
- geom\util\GeometryEditor.$(INEXT) \
- geom\util\GeometryTransformer.$(INEXT) \
- geom\util\GeometryCombiner.$(INEXT) \
- geom\util\ShortCircuitedGeometryVisitor.$(INEXT) \
- geom\prep\AbstractPreparedPolygonContains.$(INEXT) \
- geom\prep\BasicPreparedGeometry.$(INEXT) \
- geom\prep\PreparedGeometry.$(INEXT) \
- geom\prep\PreparedGeometryFactory.$(INEXT) \
- geom\prep\PreparedLineString.$(INEXT) \
- geom\prep\PreparedLineStringIntersects.$(INEXT) \
- geom\prep\PreparedPoint.$(INEXT) \
- geom\prep\PreparedPolygon.$(INEXT) \
- geom\prep\PreparedPolygonContains.$(INEXT) \
- geom\prep\PreparedPolygonContainsProperly.$(INEXT) \
- geom\prep\PreparedPolygonCovers.$(INEXT) \
- geom\prep\PreparedPolygonIntersects.$(INEXT) \
- geom\prep\PreparedPolygonPredicate.$(INEXT) \
- geomgraph\Depth.$(INEXT) \
- geomgraph\DirectedEdge.$(INEXT) \
- geomgraph\DirectedEdgeStar.$(INEXT) \
- geomgraph\Edge.$(INEXT) \
- geomgraph\EdgeEnd.$(INEXT) \
- geomgraph\EdgeEndStar.$(INEXT) \
- geomgraph\EdgeIntersection.$(INEXT) \
- geomgraph\EdgeIntersectionList.$(INEXT) \
- geomgraph\EdgeList.$(INEXT) \
- geomgraph\EdgeNodingValidator.$(INEXT) \
- geomgraph\EdgeRing.$(INEXT) \
- geomgraph\GeometryGraph.$(INEXT) \
- geomgraph\GraphComponent.$(INEXT) \
- geomgraph\Label.$(INEXT) \
- geomgraph\Node.$(INEXT) \
- geomgraph\NodeFactory.$(INEXT) \
- geomgraph\NodeMap.$(INEXT) \
- geomgraph\PlanarGraph.$(INEXT) \
- geomgraph\Position.$(INEXT) \
- geomgraph\Quadrant.$(INEXT) \
- geomgraph\TopologyLocation.$(INEXT) \
- geomgraph\index\MonotoneChainEdge.$(INEXT) \
- geomgraph\index\MonotoneChainIndexer.$(INEXT) \
- geomgraph\index\SegmentIntersector.$(INEXT) \
- geomgraph\index\SimpleEdgeSetIntersector.$(INEXT) \
- geomgraph\index\SimpleMCSweepLineIntersector.$(INEXT) \
- geomgraph\index\SimpleSweepLineIntersector.$(INEXT) \
- geomgraph\index\SweepLineEvent.$(INEXT) \
- geomgraph\index\SweepLineSegment.$(INEXT) \
- index\bintree\Bintree.$(INEXT) \
- index\bintree\Interval.$(INEXT) \
- index\bintree\Key.$(INEXT) \
- index\bintree\Node.$(INEXT) \
- index\bintree\NodeBase.$(INEXT) \
- index\bintree\Root.$(INEXT) \
- index\chain\MonotoneChain.$(INEXT) \
- index\chain\MonotoneChainBuilder.$(INEXT) \
- index\chain\MonotoneChainOverlapAction.$(INEXT) \
- index\chain\MonotoneChainSelectAction.$(INEXT) \
- index\intervalrtree\IntervalRTreeBranchNode.$(INEXT) \
- index\intervalrtree\IntervalRTreeLeafNode.$(INEXT) \
- index\intervalrtree\IntervalRTreeNode.$(INEXT) \
- index\intervalrtree\SortedPackedIntervalRTree.$(INEXT) \
- index\quadtree\DoubleBits.$(INEXT) \
- index\quadtree\IntervalSize.$(INEXT) \
- index\quadtree\Key.$(INEXT) \
- index\quadtree\Node.$(INEXT) \
- index\quadtree\NodeBase.$(INEXT) \
- index\quadtree\Root.$(INEXT) \
- index\quadtree\Quadtree.$(INEXT) \
- index\strtree\AbstractNode.$(INEXT) \
- index\strtree\AbstractSTRtree.$(INEXT) \
- index\strtree\Interval.$(INEXT) \
- index\strtree\ItemBoundable.$(INEXT) \
- index\strtree\SIRtree.$(INEXT) \
- index\strtree\STRtree.$(INEXT) \
- index\sweepline\SweepLineEvent.$(INEXT) \
- index\sweepline\SweepLineIndex.$(INEXT) \
- index\sweepline\SweepLineInterval.$(INEXT) \
- io\ByteOrderDataInStream.$(INEXT) \
- io\ByteOrderValues.$(INEXT) \
- io\CLocalizer.$(INEXT) \
- io\ParseException.$(INEXT) \
- io\StringTokenizer.$(INEXT) \
- io\Unload.$(INEXT) \
- io\WKBReader.$(INEXT) \
- io\WKBWriter.$(INEXT) \
- io\WKTReader.$(INEXT) \
- io\WKTWriter.$(INEXT) \
- io\Writer.$(INEXT) \
- noding\FastNodingValidator.$(INEXT) \
- noding\FastSegmentSetIntersectionFinder.$(INEXT) \
- noding\IntersectionAdder.$(INEXT) \
- noding\IntersectionFinderAdder.$(INEXT) \
- noding\IteratedNoder.$(INEXT) \
- noding\MCIndexNoder.$(INEXT) \
- noding\MCIndexSegmentSetMutualIntersector.$(INEXT) \
- noding\NodedSegmentString.$(INEXT) \
- noding\NodingValidator.$(INEXT) \
- noding\Octant.$(INEXT) \
- noding\ScaledNoder.$(INEXT) \
- noding\SegmentIntersectionDetector.$(INEXT) \
- noding\SegmentNode.$(INEXT) \
- noding\SegmentNodeList.$(INEXT) \
- noding\SegmentString.$(INEXT) \
- noding\SegmentStringUtil.$(INEXT) \
- noding\SimpleNoder.$(INEXT) \
- noding\SingleInteriorIntersectionFinder.$(INEXT) \
- noding\snapround\HotPixel.$(INEXT) \
- noding\snapround\MCIndexPointSnapper.$(INEXT) \
- noding\snapround\MCIndexSnapRounder.$(INEXT) \
- noding\snapround\SimpleSnapRounder.$(INEXT) \
- operation\GeometryGraphOperation.$(INEXT) \
- operation\IsSimpleOp.$(INEXT) \
- operation\buffer\BufferBuilder.$(INEXT) \
- operation\buffer\BufferOp.$(INEXT) \
- operation\buffer\BufferSubgraph.$(INEXT) \
- operation\buffer\OffsetCurveBuilder.$(INEXT) \
- operation\buffer\OffsetCurveSetBuilder.$(INEXT) \
- operation\buffer\RightmostEdgeFinder.$(INEXT) \
- operation\buffer\SubgraphDepthLocater.$(INEXT) \
- operation\distance\ConnectedElementLocationFilter.$(INEXT) \
- operation\distance\ConnectedElementPointFilter.$(INEXT) \
- operation\distance\DistanceOp.$(INEXT) \
- operation\distance\GeometryLocation.$(INEXT) \
- operation\linemerge\EdgeString.$(INEXT) \
- operation\linemerge\LineMergeDirectedEdge.$(INEXT) \
- operation\linemerge\LineMergeEdge.$(INEXT) \
- operation\linemerge\LineMergeGraph.$(INEXT) \
- operation\linemerge\LineMerger.$(INEXT) \
- operation\linemerge\LineSequencer.$(INEXT) \
- operation\overlay\EdgeSetNoder.$(INEXT) \
- operation\overlay\ElevationMatrix.$(INEXT) \
- operation\overlay\ElevationMatrixCell.$(INEXT) \
- operation\overlay\FuzzyPointLocator.$(INEXT) \
- operation\overlay\LineBuilder.$(INEXT) \
- operation\overlay\MaximalEdgeRing.$(INEXT) \
- operation\overlay\MinimalEdgeRing.$(INEXT) \
- operation\overlay\OffsetPointGenerator.$(INEXT) \
- operation\overlay\OverlayNodeFactory.$(INEXT) \
- operation\overlay\OverlayOp.$(INEXT) \
- operation\overlay\OverlayResultValidator.$(INEXT) \
- operation\overlay\PointBuilder.$(INEXT) \
- operation\overlay\PolygonBuilder.$(INEXT) \
- operation\polygonize\PolygonizeDirectedEdge.$(INEXT) \
- operation\polygonize\PolygonizeEdge.$(INEXT) \
- operation\polygonize\EdgeRing.$(INEXT) \
- operation\polygonize\PolygonizeGraph.$(INEXT) \
- operation\polygonize\Polygonizer.$(INEXT) \
- operation\predicate\RectangleContains.$(INEXT) \
- operation\predicate\RectangleIntersects.$(INEXT) \
- operation\predicate\SegmentIntersectionTester.$(INEXT) \
- operation\relate\EdgeEndBuilder.$(INEXT) \
- operation\relate\EdgeEndBundle.$(INEXT) \
- operation\relate\EdgeEndBundleStar.$(INEXT) \
- operation\relate\RelateComputer.$(INEXT) \
- operation\relate\RelateNode.$(INEXT) \
- operation\relate\RelateNodeFactory.$(INEXT) \
- operation\relate\RelateNodeGraph.$(INEXT) \
- operation\relate\RelateOp.$(INEXT) \
- operation\union\CascadedPolygonUnion.$(INEXT) \
- operation\valid\ConnectedInteriorTester.$(INEXT) \
- operation\valid\ConsistentAreaTester.$(INEXT) \
- operation\valid\IsValidOp.$(INEXT) \
- operation\valid\QuadtreeNestedRingTester.$(INEXT) \
- operation\valid\RepeatedPointTester.$(INEXT) \
- operation\valid\SimpleNestedRingTester.$(INEXT) \
- operation\valid\SweeplineNestedRingTester.$(INEXT) \
- operation\valid\TopologyValidationError.$(INEXT) \
- planargraph\DirectedEdge.$(INEXT) \
- planargraph\DirectedEdgeStar.$(INEXT) \
- planargraph\Edge.$(INEXT) \
- planargraph\Node.$(INEXT) \
- planargraph\NodeMap.$(INEXT) \
- planargraph\PlanarGraph.$(INEXT) \
- planargraph\Subgraph.$(INEXT) \
- planargraph\algorithm\ConnectedSubgraphFinder.$(INEXT) \
- precision\CommonBits.$(INEXT) \
- precision\CommonBitsOp.$(INEXT) \
- precision\CommonBitsRemover.$(INEXT) \
- precision\EnhancedPrecisionOp.$(INEXT) \
- precision\GeometrySnapper.$(INEXT) \
- precision\LineStringSnapper.$(INEXT) \
- precision\SimpleGeometryPrecisionReducer.$(INEXT) \
- simplify\DouglasPeuckerLineSimplifier.$(INEXT) \
- simplify\DouglasPeuckerSimplifier.$(INEXT) \
- simplify\LineSegmentIndex.$(INEXT) \
- simplify\TaggedLineSegment.$(INEXT) \
- simplify\TaggedLinesSimplifier.$(INEXT) \
- simplify\TaggedLineString.$(INEXT) \
- simplify\TaggedLineStringSimplifier.$(INEXT) \
- simplify\TopologyPreservingSimplifier.$(INEXT) \
- util\Assert.$(INEXT) \
- util\GeometricShapeFactory.$(INEXT) \
- util\math.$(INEXT) \
- util\Profiler.$(INEXT) \
- ..\capi\geos_c.$(INEXT) \
- ..\capi\geos_ts_c.$(INEXT) \
- inlines.$(INEXT)
+ algorithm\CentroidArea.$(EXT) \
+ algorithm\CentroidLine.$(EXT) \
+ algorithm\CentroidPoint.$(EXT) \
+ algorithm\CGAlgorithms.$(EXT) \
+ algorithm\ConvexHull.$(EXT) \
+ algorithm\HCoordinate.$(EXT) \
+ algorithm\InteriorPointArea.$(EXT) \
+ algorithm\InteriorPointLine.$(EXT) \
+ algorithm\InteriorPointPoint.$(EXT) \
+ algorithm\LineIntersector.$(EXT) \
+ algorithm\MCPointInRing.$(EXT) \
+ algorithm\MinimumDiameter.$(EXT) \
+ algorithm\NotRepresentableException.$(EXT) \
+ algorithm\PointLocator.$(EXT) \
+ algorithm\RayCrossingCounter.$(EXT) \
+ algorithm\RobustDeterminant.$(EXT) \
+ algorithm\SimplePointInRing.$(EXT) \
+ algorithm\SIRtreePointInRing.$(EXT) \
+ algorithm\locate\IndexedPointInAreaLocator.$(EXT) \
+ algorithm\locate\PointOnGeometryLocator.$(EXT) \
+ algorithm\locate\SimplePointInAreaLocator.$(EXT) \
+ geom\Coordinate.$(EXT) \
+ geom\CoordinateArraySequence.$(EXT) \
+ geom\CoordinateArraySequenceFactory.$(EXT) \
+ geom\CoordinateSequence.$(EXT) \
+ geom\Dimension.$(EXT) \
+ geom\Envelope.$(EXT) \
+ geom\Geometry.$(EXT) \
+ geom\GeometryCollection.$(EXT) \
+ geom\GeometryComponentFilter.$(EXT) \
+ geom\GeometryFactory.$(EXT) \
+ geom\IntersectionMatrix.$(EXT) \
+ geom\LinearRing.$(EXT) \
+ geom\LineSegment.$(EXT) \
+ geom\LineString.$(EXT) \
+ geom\Location.$(EXT) \
+ geom\MultiLineString.$(EXT) \
+ geom\MultiPoint.$(EXT) \
+ geom\MultiPolygon.$(EXT) \
+ geom\Point.$(EXT) \
+ geom\Polygon.$(EXT) \
+ geom\PrecisionModel.$(EXT) \
+ geom\Triangle.$(EXT) \
+ geom\util\CoordinateOperation.$(EXT) \
+ geom\util\GeometryEditor.$(EXT) \
+ geom\util\GeometryTransformer.$(EXT) \
+ geom\util\GeometryCombiner.$(EXT) \
+ geom\util\ShortCircuitedGeometryVisitor.$(EXT) \
+ geom\prep\AbstractPreparedPolygonContains.$(EXT) \
+ geom\prep\BasicPreparedGeometry.$(EXT) \
+ geom\prep\PreparedGeometry.$(EXT) \
+ geom\prep\PreparedGeometryFactory.$(EXT) \
+ geom\prep\PreparedLineString.$(EXT) \
+ geom\prep\PreparedLineStringIntersects.$(EXT) \
+ geom\prep\PreparedPoint.$(EXT) \
+ geom\prep\PreparedPolygon.$(EXT) \
+ geom\prep\PreparedPolygonContains.$(EXT) \
+ geom\prep\PreparedPolygonContainsProperly.$(EXT) \
+ geom\prep\PreparedPolygonCovers.$(EXT) \
+ geom\prep\PreparedPolygonIntersects.$(EXT) \
+ geom\prep\PreparedPolygonPredicate.$(EXT) \
+ geomgraph\Depth.$(EXT) \
+ geomgraph\DirectedEdge.$(EXT) \
+ geomgraph\DirectedEdgeStar.$(EXT) \
+ geomgraph\Edge.$(EXT) \
+ geomgraph\EdgeEnd.$(EXT) \
+ geomgraph\EdgeEndStar.$(EXT) \
+ geomgraph\EdgeIntersection.$(EXT) \
+ geomgraph\EdgeIntersectionList.$(EXT) \
+ geomgraph\EdgeList.$(EXT) \
+ geomgraph\EdgeNodingValidator.$(EXT) \
+ geomgraph\EdgeRing.$(EXT) \
+ geomgraph\GeometryGraph.$(EXT) \
+ geomgraph\GraphComponent.$(EXT) \
+ geomgraph\Label.$(EXT) \
+ geomgraph\Node.$(EXT) \
+ geomgraph\NodeFactory.$(EXT) \
+ geomgraph\NodeMap.$(EXT) \
+ geomgraph\PlanarGraph.$(EXT) \
+ geomgraph\Position.$(EXT) \
+ geomgraph\Quadrant.$(EXT) \
+ geomgraph\TopologyLocation.$(EXT) \
+ geomgraph\index\MonotoneChainEdge.$(EXT) \
+ geomgraph\index\MonotoneChainIndexer.$(EXT) \
+ geomgraph\index\SegmentIntersector.$(EXT) \
+ geomgraph\index\SimpleEdgeSetIntersector.$(EXT) \
+ geomgraph\index\SimpleMCSweepLineIntersector.$(EXT) \
+ geomgraph\index\SimpleSweepLineIntersector.$(EXT) \
+ geomgraph\index\SweepLineEvent.$(EXT) \
+ geomgraph\index\SweepLineSegment.$(EXT) \
+ index\bintree\Bintree.$(EXT) \
+ index\bintree\Interval.$(EXT) \
+ index\bintree\Key.$(EXT) \
+ index\bintree\Node.$(EXT) \
+ index\bintree\NodeBase.$(EXT) \
+ index\bintree\Root.$(EXT) \
+ index\chain\MonotoneChain.$(EXT) \
+ index\chain\MonotoneChainBuilder.$(EXT) \
+ index\chain\MonotoneChainOverlapAction.$(EXT) \
+ index\chain\MonotoneChainSelectAction.$(EXT) \
+ index\intervalrtree\IntervalRTreeBranchNode.$(EXT) \
+ index\intervalrtree\IntervalRTreeLeafNode.$(EXT) \
+ index\intervalrtree\IntervalRTreeNode.$(EXT) \
+ index\intervalrtree\SortedPackedIntervalRTree.$(EXT) \
+ index\quadtree\DoubleBits.$(EXT) \
+ index\quadtree\IntervalSize.$(EXT) \
+ index\quadtree\Key.$(EXT) \
+ index\quadtree\Node.$(EXT) \
+ index\quadtree\NodeBase.$(EXT) \
+ index\quadtree\Root.$(EXT) \
+ index\quadtree\Quadtree.$(EXT) \
+ index\strtree\AbstractNode.$(EXT) \
+ index\strtree\AbstractSTRtree.$(EXT) \
+ index\strtree\Interval.$(EXT) \
+ index\strtree\ItemBoundable.$(EXT) \
+ index\strtree\SIRtree.$(EXT) \
+ index\strtree\STRtree.$(EXT) \
+ index\sweepline\SweepLineEvent.$(EXT) \
+ index\sweepline\SweepLineIndex.$(EXT) \
+ index\sweepline\SweepLineInterval.$(EXT) \
+ io\ByteOrderDataInStream.$(EXT) \
+ io\ByteOrderValues.$(EXT) \
+ io\CLocalizer.$(EXT) \
+ io\ParseException.$(EXT) \
+ io\StringTokenizer.$(EXT) \
+ io\Unload.$(EXT) \
+ io\WKBReader.$(EXT) \
+ io\WKBWriter.$(EXT) \
+ io\WKTReader.$(EXT) \
+ io\WKTWriter.$(EXT) \
+ io\Writer.$(EXT) \
+ noding\FastNodingValidator.$(EXT) \
+ noding\FastSegmentSetIntersectionFinder.$(EXT) \
+ noding\IntersectionAdder.$(EXT) \
+ noding\IntersectionFinderAdder.$(EXT) \
+ noding\IteratedNoder.$(EXT) \
+ noding\MCIndexNoder.$(EXT) \
+ noding\MCIndexSegmentSetMutualIntersector.$(EXT) \
+ noding\NodedSegmentString.$(EXT) \
+ noding\NodingValidator.$(EXT) \
+ noding\Octant.$(EXT) \
+ noding\ScaledNoder.$(EXT) \
+ noding\SegmentIntersectionDetector.$(EXT) \
+ noding\SegmentNode.$(EXT) \
+ noding\SegmentNodeList.$(EXT) \
+ noding\SegmentString.$(EXT) \
+ noding\SegmentStringUtil.$(EXT) \
+ noding\SimpleNoder.$(EXT) \
+ noding\SingleInteriorIntersectionFinder.$(EXT) \
+ noding\snapround\HotPixel.$(EXT) \
+ noding\snapround\MCIndexPointSnapper.$(EXT) \
+ noding\snapround\MCIndexSnapRounder.$(EXT) \
+ noding\snapround\SimpleSnapRounder.$(EXT) \
+ operation\GeometryGraphOperation.$(EXT) \
+ operation\IsSimpleOp.$(EXT) \
+ operation\buffer\BufferBuilder.$(EXT) \
+ operation\buffer\BufferOp.$(EXT) \
+ operation\buffer\BufferSubgraph.$(EXT) \
+ operation\buffer\OffsetCurveBuilder.$(EXT) \
+ operation\buffer\OffsetCurveSetBuilder.$(EXT) \
+ operation\buffer\RightmostEdgeFinder.$(EXT) \
+ operation\buffer\SubgraphDepthLocater.$(EXT) \
+ operation\distance\ConnectedElementLocationFilter.$(EXT) \
+ operation\distance\ConnectedElementPointFilter.$(EXT) \
+ operation\distance\DistanceOp.$(EXT) \
+ operation\distance\GeometryLocation.$(EXT) \
+ operation\linemerge\EdgeString.$(EXT) \
+ operation\linemerge\LineMergeDirectedEdge.$(EXT) \
+ operation\linemerge\LineMergeEdge.$(EXT) \
+ operation\linemerge\LineMergeGraph.$(EXT) \
+ operation\linemerge\LineMerger.$(EXT) \
+ operation\linemerge\LineSequencer.$(EXT) \
+ operation\overlay\EdgeSetNoder.$(EXT) \
+ operation\overlay\ElevationMatrix.$(EXT) \
+ operation\overlay\ElevationMatrixCell.$(EXT) \
+ operation\overlay\FuzzyPointLocator.$(EXT) \
+ operation\overlay\LineBuilder.$(EXT) \
+ operation\overlay\MaximalEdgeRing.$(EXT) \
+ operation\overlay\MinimalEdgeRing.$(EXT) \
+ operation\overlay\OffsetPointGenerator.$(EXT) \
+ operation\overlay\OverlayNodeFactory.$(EXT) \
+ operation\overlay\OverlayOp.$(EXT) \
+ operation\overlay\OverlayResultValidator.$(EXT) \
+ operation\overlay\PointBuilder.$(EXT) \
+ operation\overlay\PolygonBuilder.$(EXT) \
+ operation\polygonize\PolygonizeDirectedEdge.$(EXT) \
+ operation\polygonize\PolygonizeEdge.$(EXT) \
+ operation\polygonize\EdgeRing.$(EXT) \
+ operation\polygonize\PolygonizeGraph.$(EXT) \
+ operation\polygonize\Polygonizer.$(EXT) \
+ operation\predicate\RectangleContains.$(EXT) \
+ operation\predicate\RectangleIntersects.$(EXT) \
+ operation\predicate\SegmentIntersectionTester.$(EXT) \
+ operation\relate\EdgeEndBuilder.$(EXT) \
+ operation\relate\EdgeEndBundle.$(EXT) \
+ operation\relate\EdgeEndBundleStar.$(EXT) \
+ operation\relate\RelateComputer.$(EXT) \
+ operation\relate\RelateNode.$(EXT) \
+ operation\relate\RelateNodeFactory.$(EXT) \
+ operation\relate\RelateNodeGraph.$(EXT) \
+ operation\relate\RelateOp.$(EXT) \
+ operation\union\CascadedPolygonUnion.$(EXT) \
+ operation\valid\ConnectedInteriorTester.$(EXT) \
+ operation\valid\ConsistentAreaTester.$(EXT) \
+ operation\valid\IsValidOp.$(EXT) \
+ operation\valid\QuadtreeNestedRingTester.$(EXT) \
+ operation\valid\RepeatedPointTester.$(EXT) \
+ operation\valid\SimpleNestedRingTester.$(EXT) \
+ operation\valid\SweeplineNestedRingTester.$(EXT) \
+ operation\valid\TopologyValidationError.$(EXT) \
+ planargraph\DirectedEdge.$(EXT) \
+ planargraph\DirectedEdgeStar.$(EXT) \
+ planargraph\Edge.$(EXT) \
+ planargraph\Node.$(EXT) \
+ planargraph\NodeMap.$(EXT) \
+ planargraph\PlanarGraph.$(EXT) \
+ planargraph\Subgraph.$(EXT) \
+ planargraph\algorithm\ConnectedSubgraphFinder.$(EXT) \
+ precision\CommonBits.$(EXT) \
+ precision\CommonBitsOp.$(EXT) \
+ precision\CommonBitsRemover.$(EXT) \
+ precision\EnhancedPrecisionOp.$(EXT) \
+ precision\GeometrySnapper.$(EXT) \
+ precision\LineStringSnapper.$(EXT) \
+ precision\SimpleGeometryPrecisionReducer.$(EXT) \
+ simplify\DouglasPeuckerLineSimplifier.$(EXT) \
+ simplify\DouglasPeuckerSimplifier.$(EXT) \
+ simplify\LineSegmentIndex.$(EXT) \
+ simplify\TaggedLineSegment.$(EXT) \
+ simplify\TaggedLinesSimplifier.$(EXT) \
+ simplify\TaggedLineString.$(EXT) \
+ simplify\TaggedLineStringSimplifier.$(EXT) \
+ simplify\TopologyPreservingSimplifier.$(EXT) \
+ util\Assert.$(EXT) \
+ util\GeometricShapeFactory.$(EXT) \
+ util\math.$(EXT) \
+ util\Profiler.$(EXT) \
+ ..\capi\geos_c.$(EXT) \
+ ..\capi\geos_ts_c.$(EXT) \
+ inlines.$(EXT)
TEST_EXE = TestSweepLineSpeed.exe
@@ -287,48 +292,48 @@
if exist $(CDLLNAME).manifest mt -manifest $(CDLLNAME).manifest -outputresource:$(CDLLNAME);2
headers/geos/platform.h: headers/geos/platform.h.vc
- copy headers\geos\platform.h.vc headers\geos\platform.h
+ $(CP) headers\geos\platform.h.vc headers\geos\platform.h
headers/geos/version.h: headers/geos/version.h.vc
- if not exist headers\geos\version.h copy headers\geos\version.h.vc headers\geos\version.h
+ if not exist headers\geos\version.h $(CP) headers\geos\version.h.vc headers\geos\version.h
# geos_c.h should already be in distribution, if is not you'll
# have to run ./configure to recreate
../capi/geos_c.h: ../capi/geos_c.h.in.
- copy ..\capi\geos_c.h.in ..\capi\geos_c.h
+ $(CP) ..\capi\geos_c.h.in ..\capi\geos_c.h
.cpp.obj:
- $(CC) $(CFLAGS) /c $*.cpp /Fo$@
+ $(CC) $(CFLAGS) /c $*.cpp /Fo$@
.c.obj:
$(CC) $(CFLAGS) /c $*.c /Fo$@
clean:
- $(RM) $(LIBNAME)
- $(RM) $(SLIBNAME)
- $(RM) $(DLLNAME)
- $(RM) $(SLIBNAME)
- $(RM) $(CLIBNAME)
- $(RM) $(CDLLNAME)
- $(RM) ..\capi\*.obj
- $(RM) *.exe
- $(RM) *.exp
- $(RM) *.ilk
- $(RM) *.manifest
- $(RM) *.obj
- $(RM) *.pdb
- for %d in ( $(GEOS_DIRLIST) ) do \
- del %d\*.obj
+ @ECHO "*** Cleaning GEOS source tree"
+ @IF EXIST $(LIBNAME) $(RM) $(LIBNAME)
+ @IF EXIST $(SLIBNAME) $(RM) $(SLIBNAME)
+ @IF EXIST $(DLLNAME) $(RM) $(DLLNAME)
+ @IF EXIST $(CLIBNAME) $(RM) $(CLIBNAME)
+ @IF EXIST $(CDLLNAME) $(RM) $(CDLLNAME)
+ - at del ..\capi\*.obj
+ - at del $*.exe
+ - at del $*.exp
+ - at del $*.ilk
+ - at del $*.manifest
+ - at del $*.obj
+ - at del $*.pdb
+ - at FOR %d IN ( $(GEOS_DIRLIST) ) DO del %d\*.obj
TestSweepLineSpeed.exe: $(LIBNAME) \
bigtest\GeometryTestFactory.obj \
bigtest\TestSweepLineSpeed.obj
- link /debug /out:TestSweepLineSpeed.exe \
+ $(LINK) /debug /out:TestSweepLineSpeed.exe \
bigtest\TestSweepLineSpeed.obj \
$(LIBNAME)
geostest.exe: $(DLLNAME) ..\capi\geostest.obj
- link /debug ..\capi\geostest.obj $(SLIBNAME)
+ $(LINK) /debug ..\capi\geostest.obj $(SLIBNAME)
# EOF
More information about the geos-commits
