[geos-commits] r2447 - in trunk/tests/xmltester: . tests tests/stmlf
svn_geos at osgeo.org
Sat May 2 04:44:52 EDT 2009
Author: strk
Date: 2009-05-02 04:44:52 -0400 (Sat, 02 May 2009)
New Revision: 2447
Added:
trunk/tests/xmltester/tests/stmlf/
trunk/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml
trunk/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml
Removed:
trunk/tests/xmltester/tests/stmlf-cases-20061020.xml
trunk/tests/xmltester/tests/stmlf-cases-20070119.xml
trunk/tests/xmltester/Makefile.am
Put stml testcases under their own dir (like in JTS)
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-05-02 08:37:08 UTC (rev 2446)
+++ trunk/tests/xmltester/Makefile.am 2009-05-02 08:44:52 UTC (rev 2447)
@@ -21,7 +21,8 @@
$(srcdir)/tests/TestValid2.xml \
$(srcdir)/tests/TestValid2-big.xml \
$(srcdir)/tests/robustness.xml \
- $(srcdir)/tests/stmlf-cases-20061020.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
+ $(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
$(srcdir)/tests/robust/TestRobustRelate.xml \
$(srcdir)/tests/fme.xml \
@@ -30,7 +31,6 @@
$(srcdir)/tests/TestBufferExternal2.xml \
$(srcdir)/tests/TestBufferMitredJoin.xml \
$(srcdir)/tests/heisenbugs.xml \
- $(srcdir)/tests/stmlf-cases-20070119.xml \
$(srcdir)/tests/badguy3.xml \
$(srcdir)/tests/hole_from_shell.xml \
$(srcdir)/tests/hole_red.xml
Copied: trunk/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml (from rev 2417, trunk/tests/xmltester/tests/stmlf-cases-20061020.xml)
--- trunk/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml (rev 0)
+++ trunk/tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml 2009-05-02 08:44:52 UTC (rev 2447)
@@ -0,0 +1,335 @@
+ The test cases have been taken from the robustness improvement project
+ funded by the Bavarian State Ministry of Agriculture and Forestry
+ (StMLF) and the State Survey of Bavaria (LVG). Written permission
+ to use the data for tests has been given by email on the 22 Nov 2006.
+ <run><precisionModel type="FLOATING"/>
+ <case><desc>966094 - 2025063
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -12 </desc>
+<a>
+010600000001000000010300000001000000080000009CF43774FF0951412374234411E95441BF77617BFF095141190A467611E9544188E1D28E040A51410F26D5D00FE95441B63AEC27040A5141850B95540EE954417AE0F580030A51410B25BEB20CE95441F07D6BC4010A5141D66A6B2F05E9544100000010010A5141A4703D5A01E954419CF43774FF0951412374234411E95441
+</a>
+<b>
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
+</b>
+<test><op name="areatest">5</op></test>
+</case>
+ <case><desc>99455 - 3082006
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -9 </desc>
+<a>
+0106000000010000000103000000010000000F000000AAC4C227788350416D0791EFF11B54417780D7447783504110D8543CF11B54411DEDE0BE73835041BC6CD80CF11B5441CDBD952172835041014004ACF01B54410AD7A360718350419A9999C9F01B54417B14AEC7718350419A999939F91B54410AD7A3F07183504133333343FA1B54413333334372835041CDCCCC5CFF1B5441A4703D2A7383504152B81EA5041C5441E17A141E75835041000000E0051C54417B14AE6777835041B81E853B061C54410AD7A3D07783504166666656031C5441A4703D5A7883504133333303FF1B5441A4703D7A78835041333333A3F91B5441AAC4C227788350416D0791EFF11B5441
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>275046 - 3361837
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -7 </desc>
+<a>
+0106000000010000000103000000010000000D000000B81E850BBF2D514152B81E858F3C5441E17A145EBE2D51419A9999295F3C5441CDCCCC4CBA2D5141E17A148E5B3C54410AD7A300B92D5141000000105C3C54417B14AE97B92D51418FC2F5F87B3C5441713D0A17BA2D5141AE47E16A963C5441D7A3704DBA2D5141EC51B84EA23C5441AE47E1DABA2D514148E17A54BD3C5441E17A14DEBA2D51419A9999E9BD3C54418FC2F5D8BA2D51411F85EB81BE3C54410AD7A3C0BE2D5141EC51B8FEC23C5441000000C0BF2D5141000000F0C13C5441B81E850BBF2D514152B81E858F3C5441
+</a>
+<b>
+0106000000010000000103000000010000000D0000008FC2F5D8BA2D51411F85EB81BE3C54410AD7A3C0BE2D5141EC51B8FEC23C5441000000C0BF2D5141000000F0C13C5441B81E850BBF2D514152B81E858F3C5441E17A145EBE2D51419A9999295F3C5441CDCCCC4CBA2D5141E17A148E5B3C54410AD7A300B92D5141000000105C3C54415287AC97B92D514144D9A1F87B3C544136AB1718BA2D5141DA9CC4A5963C54414BDDE007B92D5141DFAC7E33953C5441028739EAB92D514174B3776DBD3C5441D8EE8E24BA2D5141CE1FC8B2BD3C54418FC2F5D8BA2D51411F85EB81BE3C5441
+</b>
+</case>
+ <case><desc>984559 - 984543
+abs( area(A) - difference(A,B) - intersection(A,B) ) = 3 </desc>
+<a>
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
+</a>
+<b>
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
+</b>
+<test><op name="areatest">1</op></test>
+</case>
+ <case><desc>982104 - 1320680
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -4 </desc>
+<a>
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
+</a>
+<b>
+0106000000010000000103000000010000001000000028E1365521FD5041323426C820D2544154C8D3351CFD50415C76C67A29D25441098DFD8011FD5041C9DB59EE3FD254412E3CADFB0CFD50412406A86346D25441FDD9532F05FD5041E83E4A994BD25441F397714AF8FC504181F05F4053D254415C8FC2C5F7FC5041EC51B83E56D25441A4703D2AF9FC5041B81E858B55D25441B81E851B09FD5041E17A14FE4BD25441AE47E1FA0EFD5041295C8FC247D254413D0AD75313FD50411F85EB0142D254417B14AE7716FD5041D7A3706D3BD254419A9999091CFD5041E17A14EE30D25441EC51B83E1FFD5041B81E859B29D25441C3F5280C20FD5041B81E853B28D2544128E1365521FD5041323426C820D25441
+</b>
+</case>
+ <case><desc>720830 - 32827
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -2 </desc>
+<a>
+0106000000010000000103000000010000000900000085EB512855C550419A9999A9703955410000004055C550419A9999196A395541B81E853B43C55041AE47E1AA6D395541000000403DC55041B81E85BB6E395541295C8F022AC55041F6285CAF75395541295C8F722DC55041333333A3843955417B14AEB738C550418FC2F55882395541C3F5284C4DC55041333333137239554185EB512855C550419A9999A970395541
+</a>
+<b>
+0106000000010000000103000000010000000A0000009B74AFA82AC550419DA4F981783955411FF4C0C12AC5504165E17AE178395541DCDE5F772DC55041C7C238A2843955410E087AE22EC55041D3007158843955416AD06EF02DC55041C01F2D6E803955416D85C44F2EC55041C16D7D6B7B39554121826EA22DC55041206F787176395541656754762DC550412108017074395541E0698F022AC55041A0645CAF753955419B74AFA82AC550419DA4F98178395541
+</b>
+</case>
+ <case><desc>11503 - 422581
+<a>
+0106000000010000000103000000010000000600000085EB511885D95041295C8F62F58B54417B14AE8733D9504152B81E85E68B54413333336334D95041D7A3706DEE8B5441CDCCCCEC87D950419A9999A9FD8B54410AD7A32088D9504148E17AF4FB8B544185EB511885D95041295C8F62F58B5441
+</a>
+<b>
+010600000001000000010300000001000000080000000EBCBD6683D95041B3AF66D6FC8B54410CCCE3C083D950419081D7E6FC8B5441B067BACF83D9504133458CE9FC8B54410DDFC4E287D950415DEEFE9CFD8B5441C1AC0C1888D95041315BB61AFC8B54410193290685D9504126B26A64F58B5441FBD8957381D95041F05692B8F48B54410EBCBD6683D95041B3AF66D6FC8B5441
+</b>
+</case>
+ <case><desc>35309 - 21138
+abs( area(A) - difference(A,B) - intersection(A,B) ) = 2 </desc>
+<a>
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
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>189022 - 7822
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -3 </desc>
+<a>
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
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>191097 - 2916437
+<a>
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
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>256271 - 367713
+abs( area(A) - difference(A,B) - intersection(A,B) ) = 5 </desc>
+<a>
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
+</a>
+<b>
+01060000000100000001030000000100000009000000713D0A2757C05041CDCCCCEC512A5441677A56726CC05041AD55058D502A5441146EC3B16BC05041F16159044E2A5441306B52721CC05041453D8A60532A5441088679DB16C05041486A9979542A5441F502C4F513C0504166605F25562A54410AD7A34025C0504152B81E25552A54413D0AD7333EC050418FC2F588532A5441713D0A2757C05041CDCCCCEC512A5441
+</b>
+</case>
+ <case><desc>275129 - 384120
+<a>
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
+</a>
+<b>
+01060000000100000001030000000100000007000000ABEA7DD0B02B5141547E90CE86375441D17118A9B02B514194AF78D586375441899E0EA3B02B5141FBCB70FE893754416B2DEBC4B02B514182FB9C008A375441C3F5283CB92B51419A9999D989375441EC51B82EB92B5141AE47E1BA86375441ABEA7DD0B02B5141547E90CE86375441
+</b>
+</case>
+ <case><desc>275562 - 3361837
+<a>
+0106000000010000000103000000010000000E000000AE47E1DABA2D514148E17A54BD3C5441D7A3704DBA2D5141EC51B84EA23C5441713D0A17BA2D5141AE47E16A963C5441E17A149EB82D5141B81E85EB943C5441CDCCCC8CAB2D51413D0AD7A3873C544166666686A42D514100000080803C5441A4703D8A9B2D5141333333338A3C5441EC51B81E952D51419A9999B9903C5441E17A147E912D51419A999919943C54410AD7A3D0A52D5141F6285C5FAB3C5441EC51B83EB92D5141AE47E1AABC3C54418FC2F5D8BA2D51411F85EB81BE3C5441E17A14DEBA2D51419A9999E9BD3C5441AE47E1DABA2D514148E17A54BD3C5441
+</a>
+<b>
+</b>
+</case>
+ <case><desc>466188 - 3072591
+<a>
+0106000000010000000103000000010000000A000000F6285C8F26A5504114AE47111D1F55419A9999C926A55041295C8FC21B1F5541C3F528AC0BA55041AE47E13AF81E554152B81EF5F6A45041000000C0D61E5541F6285C0FF5A45041EC51B88ED51E5541295C8FE2E7A45041C3F5285CD41E55418FC2F568E6A450417B14AE77D41E55411F85EB2101A5504152B81E55001F5541A4703D1A1CA550415C8FC2A5231F5541F6285C8F26A5504114AE47111D1F5541
+</a>
+<b>
+0106000000010000000103000000010000000800000081649D95F3A4504145CEA078D81E5541D85D39BAF4A45041D8E5536BD81E5541D0D78DD0F6A450412D5F379ED81E5541C5A26F08F7A450418E1238DFD61E5541A77AF94EF5A450419AF7B2B6D51E5541F270E2E5F4A450418941F38AD51E5541FA48048EF3A450417808B26BD51E554181649D95F3A4504145CEA078D81E5541
+</b>
+</case>
+ <case><desc>415163 - 3180189
+abs( area(A) - difference(A,B) - intersection(A,B) ) = -5 </desc>
+<a>
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
+</a>
+<b>
+0106000000010000000103000000010000000600000020B8CE7FE1C15041DA0A7BF1283F5441BD752992DCC150417E633D060C3F5441FCF373D3DBC15041BA5A41B4FA3E5441AE91B8C6DBC15041122208F1F93E544148E17AE4DBC15041000000C0283F544120B8CE7FE1C15041DA0A7BF1283F5441
+</b>
+</case>
+ <case><desc>401167 - 3148390
+<a>
+0106000000010000000103000000010000000C0000003D0AD733E561504152B81EF5B0295541AE47E10AE76150419A9999F9B32955410AD7A360E8615041F6285C3FB42955419A99999908625041EC51B80E9D295541A4703DBA02625041000000E09C29554152B81E3500625041713D0AE79C29554133333393F561504148E17A049D295541C3F5281CF1615041666666B69D29554166666636EC61504148E17AE49E2955419A9999A9E8615041C3F5281CA02955415C8FC255E6615041295C8F72AB2955413D0AD733E561504152B81EF5B0295541
+</a>
+<b>
+0106000000010000000103000000010000000500000013C6A342F86150410B730BFD9C2955411D116A24FA615041396A8855A0295541446AAD4D006250419CA2C5E69C29554152B81E3500625041713D0AE79C29554113C6A342F86150410B730BFD9C295541
+</b>
+</case>
+ <case><desc>164313 - 164648
+<a>
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
+</a>
+<b>
+0106000000010000000103000000010000000E000000EC51B82ECD3751410AD7A3001C09554166666666CC3751411F85EBD119095541EC51B8EECB375141AE47E11A18095541C3F528DCCB3751416666667616095541CDCCCC5CCC375141EC51B8AE1409554166666676CC375141295C8FC21209554148E17A84C937514152B81E751209554152B81E05C937514185EB51681209554133333313C93751419A9999A914095541F6285CAFC83751419A9999D91C095541D7A3708DCD375141F6285C6F1F095541B81E855BCE37514152B81EC51F0955411F85EBD1CD3751417B14AEB71D095541EC51B82ECD3751410AD7A3001C095541
+</b>
+</case>
+ <case><desc>464026 - 6704
+<a>
+0106000000010000000103000000010000000E000000A4703DEAC9F35041000000607AA35441A4703DAAE5F35041EC51B83E76A35441AE47E16AEAF350418FC2F58875A3544100000070E7F35041666666A661A35441C3F5289CE4F35041A4703DCA4EA35441666666A6E0F35041E17A145E34A35441EC51B88EDFF350415C8FC2152DA354415C8FC235CCF350410AD7A3D02FA354415C8FC245CDF35041F6285C7F37A354417B14AE97AEF350413D0AD7733CA3544166666646AEF35041B81E858B3CA3544148E17A04AFF35041295C8F8241A3544114AE47F1B7F35041CDCCCC0C7DA35441A4703DEAC9F35041000000607AA35441
+</a>
+<b>
+010600000001000000010300000001000000050000002957BC1AADF35041CAD27BBD34A3544126CEE97FAEF35041FF981A0C3EA35441DE66C3D9AFF35041923ED48B3DA3544120E0FAE1AEF3504180A4C27B34A354412957BC1AADF35041CAD27BBD34A35441
+</b>
+</case>
+ <case><desc>469351 - 5219716
+<a>
+0106000000010000000103000000010000000A000000295C8FD220AB5041666666D6F52D5541B81E85CB20AB50417B14AE87F52D5541A4703D2AD1AA5041666666D6F42D554114AE4711DAAA50415C8FC2E5FB2D55413D0AD7C3E7AA5041C3F528BC072E554152B81E75F6AA50419A9999B90A2E55416666660603AB5041CDCCCCBC0E2E5541E17A14EE09AB504148E17A04112E5541AE47E19A1BAB5041C3F528FC102E5541295C8FD220AB5041666666D6F52D5541
+</a>
+<b>
+01060000000100000001030000000100000006000000295C8FD220AB5041666666D6F52D5541B81E85CB20AB50417B14AE87F52D5541437244AFFDAA504143908339F52D5541313017541FAB50414293A393FA2D554139DEBAD41FAB504162741EFFFA2D5541295C8FD220AB5041666666D6F52D5541
+</b>
+</case>
+ <case><desc>975328 - 1755529
+<a>
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
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>525923 - 45230
+<a>
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
+</a>
+<b>
+010600000001000000010300000001000000060000002EADC44C73C950417962AD3CFF2E544148A8F87175C95041EF284218FC2E5441934291FB73C9504179222545F82E54418DC0104D6FC95041E26A30C6F52E5441B3C1B42471C95041AA411ECCFA2E54412EADC44C73C950417962AD3CFF2E5441
+</b>
+</case>
+ <case><desc>532351 - 3180577
+<a>
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
+</a>
+<b>
+0106000000010000000103000000010000000D000000665A6437A21E514171778B93AB7A544159DB026DA21E51410F537DD6AB7A5441AB6A7D34AF1E514169C45674AB7A5441F2CD22B5B01E5141035575B6A97A54415139B88CB91E514148BBE42FAA7A5441E6B49FA5C11E514107F7D6E7A87A5441330EEEBAC01E5141ED07BD1DA87A54418E7E8C1FBC1E51417676D7E4A77A5441DA182420B81E51411EF24C47A77A54410B5B86FCB41E514148D230AFA77A54415F0943B7AF1E5141DDA19D40A77A5441C163F0C0A21E51410478C3CFA77A5441665A6437A21E514171778B93AB7A5441
+</b>
+</case>
+ <case><desc>587497 - 409926
+<a>
+0106000000010000000103000000010000000A00000052B81E457B3C51410AD7A3F04967544148E17A047A3C51416666665626675441A4703D8A773C5141A4703D1A2567544152B81E95733C51413D0AD79321675441000000F0743C5141E17A14DE46675441AE47E19A753C5141B81E851B5967544152B81E35783C5141AE47E1DA58675441713D0AC7783C51419A9999A96B67544152B81E857C3C5141AE47E18A6D67544152B81E457B3C51410AD7A3F049675441
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>589978 - 39794
+<a>
+01060000000100000001030000000200000016000000AE47E1EAED9C50411F85EBF1E37B5441B81E85FBF79C5041B81E85DBE17B5441713D0AB7059D50417B14AE47E07B54411F85EB110C9D504148E17A24E07B54418FC2F598209D5041713D0AA7E17B544148E17A44239D50418FC2F5A8DB7B5441C3F528EC259D504185EB5198D77B54413D0AD7C32B9D5041B81E855BD17B544185EB51D8309D5041CDCCCC0CCC7B5441A4703D0A309D50410AD7A320CC7B5441EC51B85E209D5041AE47E1FACE7B5441333333431A9D5041713D0A17D07B54418FC2F538089D5041D7A3705DD27B54415C8FC255FF9C5041A4703D2AD47B54410AD7A380F59C5041C3F5282CD77B544100000090F49C504133333383D77B544133333303E79C5041C3F5281CDC7B5441EC51B83EDD9C5041713D0A67E07B544114AE47C1D69C504185EB51D8E37B544185EB5118DC9C5041713D0AC7EA7B5441D7A3707DE89C5041CDCCCCCCE57B5441AE47E1EAED9C50411F85EBF1E37B54410F000000A4703DAA219D50418FC2F5F8D17B544148E17A542B9D5041AE47E1FACF7B5441666666E62A9D5041EC51B81ED17B544185EB51C80B9D5041295C8FF2D67B5441B81E85FBFD9C50413D0AD713D97B5441295C8FA2F49C504185EB5158DB7B544166666616E99C50419A999939DF7B5441F6285C2FE09C5041A4703D4AE37B5441295C8FF2DF9C5041C3F528DCE27B5441295C8F22EB9C5041713D0A97DD7B544148E17AD4F49C50419A9999A9DA7B544152B81E85FD9C504114AE4741D87B54410AD7A3700C9D504152B81E85D57B5441D7A3709D1A9D5041713D0A97D37B5441A4703DAA219D50418FC2F5F8D17B5441
+</a>
+<b>
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
+</b>
+</case>
+ <case><desc>671968 - 1396084
+<a>
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
+</a>
+<b>
+01060000000100000001030000000200000041000000F8994F264CC35041534848BC8C1555417B14AEE740C35041666666D68B155541AE47E19A38C35041D7A3701D8B1555410AD7A3D038C350410000005086155541713D0AB737C35041CDCCCCFC85155541000000E037C35041713D0A977D1555417B14AEA732C3504114AE47417E155541D7A3709D33C35041666666E67A155541713D0A772FC350413D0AD703791555415C8FC20527C35041AE47E16A77155541CDCCCCAC23C35041D7A3700D8A15554114AE478127C35041E17A142E91155541333333732BC3504114AE47A1971555413333338331C3504185EB51E89A1555415C8FC23533C350413D0AD7A39B15554152B81E5533C3504185EB51E89C155541295C8F8233C35041F6285CFF9D1555413D0AD7B333C35041EC51B8FE9E155541AE47E10A34C35041EC51B81EA0155541E17A14AE35C3504152B81E35A7155541ED003A4236C35041CF08C2A6A91555417B3AEE5C36C35041912DEA16AA15554104B3DB5336C350412E0E5D19AA15554119980D6736C35041EE2F7355AA1555410B864A7936C35041678089A0AA155541C9BE947C36C3504197DEE3AFAA1555414885F57A36C3504166659EB0AA155541155DEE8936C35041344D56EDAA1555411534929A36C35041D8BD9337AB1555418FC2F5A836C3504148E17A74AB155541D7A370BD34C35041713D0A57AF155541295C8F722EC3504152B81E15BC155541A4703D5A23C35041EC51B89ECA1555413D0AD7D31AC35041713D0A97D8155541C3F528DC26C35041F6285C4FE415554148E17AE427C350415C8FC205E71555413333335328C3504185EB5178E5155541EC51B88E28C350419A9999A9E41555413D0AD76329C3504166666676E11555410AD7A3102AC3504185EB5138DF1555418FC2F5E82BC35041EC51B8EED715554148E17A342EC35041F6285C4FCF155541B81E854B31C350415C8FC2A5C4155541A4703D1A39C35041B81E855BC9155541E17A148E35C350419A999919D715554152B81E8530C3504185EB5178EC155541E17A14AE29C3504185EB51B8EB1555410AD7A3E02AC3504114AE4771EF155541AE47E1CA2AC3504114AE4721FF155541F6285C7F2BC3504152B81E850C1655413D0AD72335C35041C3F528BC0E165541713D0A9738C3504114AE477110165541AE47E15A3CC35041E17A144E121655415C8FC2553CC350410AD7A37011165541D7A370ED3EC350418FC2F5D8FD1555415C8FC27540C35041A4703D4AE4155541D7A3709D45C3504148E17A54CD1555410AD7A3E045C35041F6285C7FCB1555417B14AEE748C35041E17A142EAF15554152B81EF549C35041CDCCCCACA9155541A0AC12BB4AC35041F9D9AB01A6155541713D0AA74CC35041EC51B88E9B155541713D0AE752C350419A99995983155541CF9999994FC35041A4703D7A81155541F8994F264CC35041534848BC8C1555410C00000005DEFFC145C35041FA67FF30A915554105DEFFC145C350414278783FA9155541CAF2DA9945C35041EAABC8F7AB155541DE224B4345C35041CBE06426AC155541BF3E5F4D3AC35041550FE03AAC155541E526EA8437C35041A39A2BA5AA1555410027AD6E37C35041FDD0149CAA1555412846D87537C35041C3C1969CAA1555414EB40C6C37C35041D3D50297AA155541D05542C83AC3504141ED9A30AA155541B8B119953DC3504130D6B7B5A915554105DEFFC145C35041FA67FF30A9155541
+</b>
+</case>
+</run>
Copied: trunk/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml (from rev 2417, trunk/tests/xmltester/tests/stmlf-cases-20070119.xml)
--- trunk/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml (rev 0)
+++ trunk/tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml 2009-05-02 08:44:52 UTC (rev 2447)
@@ -0,0 +1,22 @@
+ <case><desc>3440675 - 39440
+<a>
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
+</a>
+<b>
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
+</b>
+</case>
+</run>
Deleted: trunk/tests/xmltester/tests/stmlf-cases-20061020.xml
--- trunk/tests/xmltester/tests/stmlf-cases-20061020.xml 2009-05-02 08:37:08 UTC (rev 2446)
+++ trunk/tests/xmltester/tests/stmlf-cases-20061020.xml 2009-05-02 08:44:52 UTC (rev 2447)
@@ -1,335 +0,0 @@
- The test cases have been taken from the robustness improvement project
- funded by the Bavarian State Ministry of Agriculture and Forestry
- (StMLF) and the State Survey of Bavaria (LVG). Written permission
- to use the data for tests has been given by email on the 22 Nov 2006.
- <run><precisionModel type="FLOATING"/>
- <case><desc>966094 - 2025063
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -12 </desc>
-<a>
-010600000001000000010300000001000000080000009CF43774FF0951412374234411E95441BF77617BFF095141190A467611E9544188E1D28E040A51410F26D5D00FE95441B63AEC27040A5141850B95540EE954417AE0F580030A51410B25BEB20CE95441F07D6BC4010A5141D66A6B2F05E9544100000010010A5141A4703D5A01E954419CF43774FF0951412374234411E95441
-</a>
-<b>
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
-</b>
-<test><op name="areatest">5</op></test>
-</case>
- <case><desc>99455 - 3082006
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -9 </desc>
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>275046 - 3361837
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -7 </desc>
-<a>
-0106000000010000000103000000010000000D000000B81E850BBF2D514152B81E858F3C5441E17A145EBE2D51419A9999295F3C5441CDCCCC4CBA2D5141E17A148E5B3C54410AD7A300B92D5141000000105C3C54417B14AE97B92D51418FC2F5F87B3C5441713D0A17BA2D5141AE47E16A963C5441D7A3704DBA2D5141EC51B84EA23C5441AE47E1DABA2D514148E17A54BD3C5441E17A14DEBA2D51419A9999E9BD3C54418FC2F5D8BA2D51411F85EB81BE3C54410AD7A3C0BE2D5141EC51B8FEC23C5441000000C0BF2D5141000000F0C13C5441B81E850BBF2D514152B81E858F3C5441
-</a>
-<b>
-0106000000010000000103000000010000000D0000008FC2F5D8BA2D51411F85EB81BE3C54410AD7A3C0BE2D5141EC51B8FEC23C5441000000C0BF2D5141000000F0C13C5441B81E850BBF2D514152B81E858F3C5441E17A145EBE2D51419A9999295F3C5441CDCCCC4CBA2D5141E17A148E5B3C54410AD7A300B92D5141000000105C3C54415287AC97B92D514144D9A1F87B3C544136AB1718BA2D5141DA9CC4A5963C54414BDDE007B92D5141DFAC7E33953C5441028739EAB92D514174B3776DBD3C5441D8EE8E24BA2D5141CE1FC8B2BD3C54418FC2F5D8BA2D51411F85EB81BE3C5441
-</b>
-</case>
- <case><desc>984559 - 984543
-abs( area(A) - difference(A,B) - intersection(A,B) ) = 3 </desc>
-<a>
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
-</a>
-<b>
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
-</b>
-<test><op name="areatest">1</op></test>
-</case>
- <case><desc>982104 - 1320680
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -4 </desc>
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>720830 - 32827
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -2 </desc>
-<a>
-0106000000010000000103000000010000000900000085EB512855C550419A9999A9703955410000004055C550419A9999196A395541B81E853B43C55041AE47E1AA6D395541000000403DC55041B81E85BB6E395541295C8F022AC55041F6285CAF75395541295C8F722DC55041333333A3843955417B14AEB738C550418FC2F55882395541C3F5284C4DC55041333333137239554185EB512855C550419A9999A970395541
-</a>
-<b>
-0106000000010000000103000000010000000A0000009B74AFA82AC550419DA4F981783955411FF4C0C12AC5504165E17AE178395541DCDE5F772DC55041C7C238A2843955410E087AE22EC55041D3007158843955416AD06EF02DC55041C01F2D6E803955416D85C44F2EC55041C16D7D6B7B39554121826EA22DC55041206F787176395541656754762DC550412108017074395541E0698F022AC55041A0645CAF753955419B74AFA82AC550419DA4F98178395541
-</b>
-</case>
- <case><desc>11503 - 422581
-<a>
-0106000000010000000103000000010000000600000085EB511885D95041295C8F62F58B54417B14AE8733D9504152B81E85E68B54413333336334D95041D7A3706DEE8B5441CDCCCCEC87D950419A9999A9FD8B54410AD7A32088D9504148E17AF4FB8B544185EB511885D95041295C8F62F58B5441
-</a>
-<b>
-010600000001000000010300000001000000080000000EBCBD6683D95041B3AF66D6FC8B54410CCCE3C083D950419081D7E6FC8B5441B067BACF83D9504133458CE9FC8B54410DDFC4E287D950415DEEFE9CFD8B5441C1AC0C1888D95041315BB61AFC8B54410193290685D9504126B26A64F58B5441FBD8957381D95041F05692B8F48B54410EBCBD6683D95041B3AF66D6FC8B5441
-</b>
-</case>
- <case><desc>35309 - 21138
-abs( area(A) - difference(A,B) - intersection(A,B) ) = 2 </desc>
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>189022 - 7822
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -3 </desc>
-<a>
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
-</a>
-<b>
-0106000000010000000103000000010000001C0000004F9D43E684E650415AE8839B892C5541CB4447E684E65041FFCAC59B892C5541852155E684E65041DFB9BF9C892C554192BB5FE684E65041E5DF7E9D892C5541133B4FE784E65041EF303AA6892C5541C0050AEA84E65041781F10BC892C5541B17ABDEA84E65041E5B012C3892C5541DA8D61EB84E6504159707BC9892C5541DA8D61EB84E65041958A3ACC892C5541C5238E0685E6504189ACDAC98A2C55415E58D90D85E65041D2A4FBD68A2C55413A54801085E6504191D0C1DB8A2C5541307DDC1F85E65041010ECCF28A2C5541CC78813E85E65041D99CBA238B2C554191A5E4B185E650412AEAA7888B2C5541690E5CC386E65041ABCDA25F8B2C5541F981CC498AE65041B5FCE1AD8A2C55412870C0958CE6504167B06FC5892C5541F4E202AB8EE65041400F1CD3892C55411998ECA490E65041A28ACD098A2C5541497C15ED91E650410F35BE8E892C55414886E0F092E65041AEAF4154882C554122D1F6F690E650416063CF6B872C55416AC6FD818EE650415634901D882C55411193AA8C86E650418E51C3B7892C55417E3D9B1186E65041B6F216AA892C5541A6D4230085E65041400F1CD3892C55414F9D43E684E650415AE8839B892C5541
-</b>
-</case>
- <case><desc>191097 - 2916437
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>256271 - 367713
-abs( area(A) - difference(A,B) - intersection(A,B) ) = 5 </desc>
-<a>
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
-</a>
-<b>
-01060000000100000001030000000100000009000000713D0A2757C05041CDCCCCEC512A5441677A56726CC05041AD55058D502A5441146EC3B16BC05041F16159044E2A5441306B52721CC05041453D8A60532A5441088679DB16C05041486A9979542A5441F502C4F513C0504166605F25562A54410AD7A34025C0504152B81E25552A54413D0AD7333EC050418FC2F588532A5441713D0A2757C05041CDCCCCEC512A5441
-</b>
-</case>
- <case><desc>275129 - 384120
-<a>
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
-</a>
-<b>
-01060000000100000001030000000100000007000000ABEA7DD0B02B5141547E90CE86375441D17118A9B02B514194AF78D586375441899E0EA3B02B5141FBCB70FE893754416B2DEBC4B02B514182FB9C008A375441C3F5283CB92B51419A9999D989375441EC51B82EB92B5141AE47E1BA86375441ABEA7DD0B02B5141547E90CE86375441
-</b>
-</case>
- <case><desc>275562 - 3361837
-<a>
-0106000000010000000103000000010000000E000000AE47E1DABA2D514148E17A54BD3C5441D7A3704DBA2D5141EC51B84EA23C5441713D0A17BA2D5141AE47E16A963C5441E17A149EB82D5141B81E85EB943C5441CDCCCC8CAB2D51413D0AD7A3873C544166666686A42D514100000080803C5441A4703D8A9B2D5141333333338A3C5441EC51B81E952D51419A9999B9903C5441E17A147E912D51419A999919943C54410AD7A3D0A52D5141F6285C5FAB3C5441EC51B83EB92D5141AE47E1AABC3C54418FC2F5D8BA2D51411F85EB81BE3C5441E17A14DEBA2D51419A9999E9BD3C5441AE47E1DABA2D514148E17A54BD3C5441
-</a>
-<b>
-</b>
-</case>
- <case><desc>466188 - 3072591
-<a>
-0106000000010000000103000000010000000A000000F6285C8F26A5504114AE47111D1F55419A9999C926A55041295C8FC21B1F5541C3F528AC0BA55041AE47E13AF81E554152B81EF5F6A45041000000C0D61E5541F6285C0FF5A45041EC51B88ED51E5541295C8FE2E7A45041C3F5285CD41E55418FC2F568E6A450417B14AE77D41E55411F85EB2101A5504152B81E55001F5541A4703D1A1CA550415C8FC2A5231F5541F6285C8F26A5504114AE47111D1F5541
-</a>
-<b>
-0106000000010000000103000000010000000800000081649D95F3A4504145CEA078D81E5541D85D39BAF4A45041D8E5536BD81E5541D0D78DD0F6A450412D5F379ED81E5541C5A26F08F7A450418E1238DFD61E5541A77AF94EF5A450419AF7B2B6D51E5541F270E2E5F4A450418941F38AD51E5541FA48048EF3A450417808B26BD51E554181649D95F3A4504145CEA078D81E5541
-</b>
-</case>
- <case><desc>415163 - 3180189
-abs( area(A) - difference(A,B) - intersection(A,B) ) = -5 </desc>
-<a>
-010600000001000000010300000001000000110000007B14AE5706C250419A9999A9F63E54413D0AD7C3DBC150418FC2F568F53E544148E17AE4DBC15041000000C0283F54419A99993913C2504185EB51A82A3F5441C3F5288C11C25041D7A3705D123F5441EC51B82E11C25041713D0A47063F5441E17A14DE10C25041000000C0F83E5441713D0A370FC25041E17A142EF73E5441B81E855B0EC25041AE47E16AF83E5441EC51B83E0EC25041C3F5286CFB3E54419A9999A90FC25041D7A3707DFB3E5441EC51B89E0FC25041F6285CDFFC3E54419A9999D906C25041713D0A77FC3E54413D0AD7E306C25041B81E850BFB3E54417B14AE3708C25041AE47E10AFB3E5441713D0A4708C2504114AE47F1F63E54417B14AE5706C250419A9999A9F63E5441
-</a>
-<b>
-0106000000010000000103000000010000000600000020B8CE7FE1C15041DA0A7BF1283F5441BD752992DCC150417E633D060C3F5441FCF373D3DBC15041BA5A41B4FA3E5441AE91B8C6DBC15041122208F1F93E544148E17AE4DBC15041000000C0283F544120B8CE7FE1C15041DA0A7BF1283F5441
-</b>
-</case>
- <case><desc>401167 - 3148390
-<a>
-0106000000010000000103000000010000000C0000003D0AD733E561504152B81EF5B0295541AE47E10AE76150419A9999F9B32955410AD7A360E8615041F6285C3FB42955419A99999908625041EC51B80E9D295541A4703DBA02625041000000E09C29554152B81E3500625041713D0AE79C29554133333393F561504148E17A049D295541C3F5281CF1615041666666B69D29554166666636EC61504148E17AE49E2955419A9999A9E8615041C3F5281CA02955415C8FC255E6615041295C8F72AB2955413D0AD733E561504152B81EF5B0295541
-</a>
-<b>
-0106000000010000000103000000010000000500000013C6A342F86150410B730BFD9C2955411D116A24FA615041396A8855A0295541446AAD4D006250419CA2C5E69C29554152B81E3500625041713D0AE79C29554113C6A342F86150410B730BFD9C295541
-</b>
-</case>
- <case><desc>164313 - 164648
-<a>
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
-</a>
-<b>
-0106000000010000000103000000010000000E000000EC51B82ECD3751410AD7A3001C09554166666666CC3751411F85EBD119095541EC51B8EECB375141AE47E11A18095541C3F528DCCB3751416666667616095541CDCCCC5CCC375141EC51B8AE1409554166666676CC375141295C8FC21209554148E17A84C937514152B81E751209554152B81E05C937514185EB51681209554133333313C93751419A9999A914095541F6285CAFC83751419A9999D91C095541D7A3708DCD375141F6285C6F1F095541B81E855BCE37514152B81EC51F0955411F85EBD1CD3751417B14AEB71D095541EC51B82ECD3751410AD7A3001C095541
-</b>
-</case>
- <case><desc>464026 - 6704
-<a>
-0106000000010000000103000000010000000E000000A4703DEAC9F35041000000607AA35441A4703DAAE5F35041EC51B83E76A35441AE47E16AEAF350418FC2F58875A3544100000070E7F35041666666A661A35441C3F5289CE4F35041A4703DCA4EA35441666666A6E0F35041E17A145E34A35441EC51B88EDFF350415C8FC2152DA354415C8FC235CCF350410AD7A3D02FA354415C8FC245CDF35041F6285C7F37A354417B14AE97AEF350413D0AD7733CA3544166666646AEF35041B81E858B3CA3544148E17A04AFF35041295C8F8241A3544114AE47F1B7F35041CDCCCC0C7DA35441A4703DEAC9F35041000000607AA35441
-</a>
-<b>
-010600000001000000010300000001000000050000002957BC1AADF35041CAD27BBD34A3544126CEE97FAEF35041FF981A0C3EA35441DE66C3D9AFF35041923ED48B3DA3544120E0FAE1AEF3504180A4C27B34A354412957BC1AADF35041CAD27BBD34A35441
-</b>
-</case>
- <case><desc>469351 - 5219716
-<a>
-0106000000010000000103000000010000000A000000295C8FD220AB5041666666D6F52D5541B81E85CB20AB50417B14AE87F52D5541A4703D2AD1AA5041666666D6F42D554114AE4711DAAA50415C8FC2E5FB2D55413D0AD7C3E7AA5041C3F528BC072E554152B81E75F6AA50419A9999B90A2E55416666660603AB5041CDCCCCBC0E2E5541E17A14EE09AB504148E17A04112E5541AE47E19A1BAB5041C3F528FC102E5541295C8FD220AB5041666666D6F52D5541
-</a>
-<b>
-01060000000100000001030000000100000006000000295C8FD220AB5041666666D6F52D5541B81E85CB20AB50417B14AE87F52D5541437244AFFDAA504143908339F52D5541313017541FAB50414293A393FA2D554139DEBAD41FAB504162741EFFFA2D5541295C8FD220AB5041666666D6F52D5541
-</b>
-</case>
- <case><desc>975328 - 1755529
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>525923 - 45230
-<a>
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
-</a>
-<b>
-010600000001000000010300000001000000060000002EADC44C73C950417962AD3CFF2E544148A8F87175C95041EF284218FC2E5441934291FB73C9504179222545F82E54418DC0104D6FC95041E26A30C6F52E5441B3C1B42471C95041AA411ECCFA2E54412EADC44C73C950417962AD3CFF2E5441
-</b>
-</case>
- <case><desc>532351 - 3180577
-<a>
-0106000000050000000103000000010000000F0000007B14AE47B91E51417B14AE27B47A5441E17A145EB71E5141C3F528ECB47A544114AE4751B61E514152B81EF5B57A5441D7A370ADB31E514152B81E05B67A5441F6285C1FAD1E5141B81E85ABB77A5441333333B3B61E5141CDCCCCFCB87A54411F85EB11B91E514114AE4791B87A544166666676BA1E51418FC2F5C8B77A54417B14AE67BB1E5141CDCCCCACB67A5441F6285C0FBC1E5141AE47E1CAB57A5441AE47E1BABB1E514152B81E95B57A544114AE47F1BB1E5141D7A3700DB47A5441AE47E1BABB1E5141D7A3709DB37A54418FC2F5B8BA1E51410AD7A3A0B37A54417B14AE47B91E51417B14AE27B47A54410103000000010000000A000000E17A142EA51E51411F85EBE1B17A544100000090A11E514148E17AA4B17A544152B81E15A11E5141E17A141EB67A5441B81E857BAA1E5141EC51B84EB77A544152B81ED5B31E514166666616B57A5441D7A370BDB31E5141713D0AA7B47A544152B81EB5AE1E514185EB5108B47A544148E17AA4AE1E5141713D0A37B37A54413D0AD763AA1E5141CDCCCC7CB27A5441E17A142EA51E51411F85EBE1B17A5441010300000002000000160000001F85EB71EC1E5141C3F5281CB17A544185EB5128EB1E51418FC2F588AF7A54418FC2F5A8E91E5141713D0AA7B17A5441CDCCCC4CDF1E51411F85EBE1AF7A544166666676DF1E5141EC51B82EAF7A5441F6285CBFE81E514114AE4721AF7A54411F85EB51E91E5141295C8F42AE7A54419A999939D21E5141F6285C5FAB7A54417B14AEA7C61E5141D7A370CDA97A5441B81E851BC51E514114AE4731AA7A54418FC2F5C8C41E51413D0AD743AB7A5441C3F528CCC41E514133333353AD7A54417B14AED7C71E5141A4703DDAAD7A54417B14AE17C91E514152B81EA5AE7A54419A999989C91E51419A999989AF7A544152B81EE5C91E51415C8FC295AF7A54418FC2F5D8C91E51410AD7A3C0AF7A5441A4703D7AD11E5141AE47E1AAB07A544100000090EB1E51419A999959B57A5441666666C6EB1E51410AD7A320B47A544148E17A04EC1E5141F6285CDFB17A54411F85EB71EC1E5141C3F5281CB17A544105000000713D0A97D91E514100000040AD7A5441000000F0D81E5141E17A142EAD7A5441AE47E1FAD81E51418FC2F5C8AC7A5441295C8FA2D91E5141B81E85DBAC7A5441713D0A97D91E514100000040AD7A54410103000000010000000E00000052B81ED5111F5141F6285CDFB97A5441295C8FC20D1F514152B81E15B77A54413D0AD7E3071F5141A4703D0AB57A544148E17A94FD1E5141666666F6B17A5441EC51B8AEF51E5141A4703D0AB17A5441E17A140EF11E5141C3F5282CAF7A5441A4703DCAEF1E5141D7A3702DB07A5441C3F528ECED1E5141F6285CBFB47A54415C8FC285FB1E514166666686B77A54411F85EB51071F5141AE47E1CABA7A5441D7A3702D101F514166666626BE7A54419A999929121F5141F6285C4FBF7A54410AD7A360151F51418FC2F538BC7A544152B81ED5111F5141F6285CDFB97A54410103000000010000000F000000EC51B89EA21E514114AE47D1A77A544100000080A21E5141000000F0A87A544100000030A21E514185EB51D8AB7A544152B81E45AF1E51413D0AD773AB7A544185EB51A8B01E51415C8FC2B5A97A544133333383B91E514114AE4731AA7A544152B81EF5C11E5141666666F6A87A5441D7A370DDC01E514133333323A87A5441D7A3706DBF1E51418FC2F5E8A77A5441D7A3700DBC1E5141E17A146EA77A54411F85EBE1B81E5141295C8F62A77A54410AD7A310B81E514152B81E45A77A544166666606B51E5141000000B0A77A544185EB5198AF1E5141E17A143EA77A5441EC51B89EA21E514114AE47D1A77A5441
-</a>
-<b>
-0106000000010000000103000000010000000D000000665A6437A21E514171778B93AB7A544159DB026DA21E51410F537DD6AB7A5441AB6A7D34AF1E514169C45674AB7A5441F2CD22B5B01E5141035575B6A97A54415139B88CB91E514148BBE42FAA7A5441E6B49FA5C11E514107F7D6E7A87A5441330EEEBAC01E5141ED07BD1DA87A54418E7E8C1FBC1E51417676D7E4A77A5441DA182420B81E51411EF24C47A77A54410B5B86FCB41E514148D230AFA77A54415F0943B7AF1E5141DDA19D40A77A5441C163F0C0A21E51410478C3CFA77A5441665A6437A21E514171778B93AB7A5441
-</b>
-</case>
- <case><desc>587497 - 409926
-<a>
-0106000000010000000103000000010000000A00000052B81E457B3C51410AD7A3F04967544148E17A047A3C51416666665626675441A4703D8A773C5141A4703D1A2567544152B81E95733C51413D0AD79321675441000000F0743C5141E17A14DE46675441AE47E19A753C5141B81E851B5967544152B81E35783C5141AE47E1DA58675441713D0AC7783C51419A9999A96B67544152B81E857C3C5141AE47E18A6D67544152B81E457B3C51410AD7A3F049675441
-</a>
-<b>
-01060000000100000001030000000100000014000000C2DD97B2733C514113B1F3BE24675441FECDBCF2703C514192B37A8E21675441491ADF3F6F3C5141B86C9815206754418F63E1226F3C51411F6C98152067544157AEF33A6E3C514198DCB3B91E675441537C342F6D3C514120D49C221E675441458C0A196D3C5141D594C10B1E67544153A4A14F683C5141E51737911D67544168F79A09693C51411FD40A1741675441A1F938B6693C5141D133374A6367544110AD838A6F3C514179EC79676367544101E6B76D6F3C51419D8376C7636754410199958B6F3C51412B60D8ED6667544152B81EE56F3C5141B81E851B676754413AD5EC0B763C51415493273E6A675441088E89EE753C51419D2EDE3B686754414FA0B527763C514133F1EE5468675441AE47E19A753C5141B81E851B59675441000000F0743C5141E17A14DE46675441C2DD97B2733C514113B1F3BE24675441
-</b>
-</case>
- <case><desc>589978 - 39794
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
- <case><desc>671968 - 1396084
-<a>
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
-</a>
-<b>
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
-</b>
-</case>
-</run>
Deleted: trunk/tests/xmltester/tests/stmlf-cases-20070119.xml
--- trunk/tests/xmltester/tests/stmlf-cases-20070119.xml 2009-05-02 08:37:08 UTC (rev 2446)
+++ trunk/tests/xmltester/tests/stmlf-cases-20070119.xml 2009-05-02 08:44:52 UTC (rev 2447)
@@ -1,22 +0,0 @@
- <case><desc>3440675 - 39440
-<a>
-01060000000100000001030000000100000010000000ABE5901B9F04514172F97207369854418AE1115E9B0451413A1E1606379854412FC8508A96045141574FB94E38985441D7A3701D940451413D0AD7F3389854419A99995994045141333333F33A985441EC51B81E94045141000000003F985441713D0A6799045141666666763F985441CDCCCCEC9D045141F6285C1F3F9854419A9999C9A3045141EC51B8DE3D985441666666E6AE0451411F85EBB13A985441E17A142EB8045141AE47E1CA36985441333333A3B50451419A999909309854411948A539AD045141A264514632985441BAB6FD20A904514187AD325D33985441B88E923AA6045141C428A32234985441ABE5901B9F04514172F9720736985441
-</a>
-<b>
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
-</b>
-</case>
-</run>
More information about the geos-commits
