[geos-commits] r2453 - in trunk/tests/xmltester: . tests
tests/general
svn_geos at osgeo.org
Sat May 2 05:25:36 EDT 2009
Author: strk
Date: 2009-05-02 05:25:36 -0400 (Sat, 02 May 2009)
New Revision: 2453
Added:
trunk/tests/xmltester/tests/general/TestWithinDistance.xml
trunk/tests/xmltester/Makefile.am
trunk/tests/xmltester/tests/testLeaksBig.xml
Copy TestWithinDistance.xml test, drop duplicates from testLeaksBig.xml
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-05-02 09:20:26 UTC (rev 2452)
+++ trunk/tests/xmltester/Makefile.am 2009-05-02 09:25:36 UTC (rev 2453)
@@ -32,10 +32,6 @@
$(srcdir)/tests/general/TestFunctionPL.xml \
$(srcdir)/tests/general/TestFunctionPP.xml \
$(srcdir)/tests/general/TestInteriorPoint.xml \
- $(srcdir)/tests/general/TestSimple.xml \
- $(srcdir)/tests/general/TestValid.xml \
- $(srcdir)/tests/general/TestValid2.xml \
- $(srcdir)/tests/general/TestValid2-big.xml \
$(srcdir)/tests/general/TestRelateAA.xml \
$(srcdir)/tests/general/TestRelateLA.xml \
$(srcdir)/tests/general/TestRelateLL.xml \
@@ -44,6 +40,11 @@
$(srcdir)/tests/general/TestRelateLC.xml \
$(srcdir)/tests/general/TestRelatePA.xml \
$(srcdir)/tests/general/TestRelatePP.xml \
+ $(srcdir)/tests/general/TestSimple.xml \
+ $(srcdir)/tests/general/TestValid.xml \
+ $(srcdir)/tests/general/TestValid2.xml \
+ $(srcdir)/tests/general/TestValid2-big.xml \
+ $(srcdir)/tests/general/TestWithinDistance.xml \
$(srcdir)/tests/stmlf/stmlf-cases-20061020.xml \
$(srcdir)/tests/stmlf/stmlf-cases-20070119.xml \
$(srcdir)/tests/robust/TestRobustOverlayFixed.xml \
Added: trunk/tests/xmltester/tests/general/TestWithinDistance.xml
--- trunk/tests/xmltester/tests/general/TestWithinDistance.xml (rev 0)
+++ trunk/tests/xmltester/tests/general/TestWithinDistance.xml 2009-05-02 09:25:36 UTC (rev 2453)
@@ -0,0 +1,92 @@
+<run>
+ <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
+<case>
+ <desc>PP - disjoint points</desc>
+ <a> POINT(10 10) </a>
+ <b> POINT(100 100) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="200"> true </op></test>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="100"> false </op></test>
+</case>
+<case>
+ <desc>PP - overlapping points</desc>
+ <b> POINT(10 10) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="0"> true </op></test>
+</case>
+<case>
+ <desc>PL - point on linestring</desc>
+ <a> POINT (340 200) </a>
+ <b> LINESTRING (80 280, 340 200, 80 80) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="10"> true </op></test>
+</case>
+<case>
+ <desc>PL - point not on linestring</desc>
+ <a> LINESTRING (100 100, 200 100, 200 200, 100 200, 100 100) </a>
+ <b> POINT (10 10) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="128"> true </op></test>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="127"> false </op></test>
+</case>
+<case>
+ <desc>PA - point inside polygon</desc>
+ <a> POINT (240 160) </a>
+ <b> POLYGON ((100 260, 340 180, 100 60, 180 160, 100 260)) </b>
+</case>
+<case>
+ <desc>mPA - points outside polygon</desc>
+ <a> POLYGON ((200 180, 60 140, 60 260, 200 180)) </a>
+ <b> MULTIPOINT ((140 280), (140 320)) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="60"> true </op></test>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="57"> false </op></test>
+</case>
+<case>
+ <desc>LL - disjoint linestrings</desc>
+ <a> LINESTRING (40 300, 240 260, 60 160, 140 60) </a>
+ <b> LINESTRING (140 360, 260 280, 240 120, 120 160) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="18"> true </op></test>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="17"> false </op></test>
+</case>
+<case>
+ <desc>LL - crossing linestrings</desc>
+ <a> LINESTRING (40 300, 280 220, 60 160, 140 60) </a>
+</case>
+<case>
+ <desc>AA - overlapping polygons</desc>
+ <a> POLYGON ((60 260, 260 180, 100 60, 60 160, 60 260)) </a>
+ <b> POLYGON ((220 280, 120 160, 300 60, 360 220, 220 280)) </b>
+</case>
+<case>
+ <desc>AA - disjoint polygons</desc>
+ <a> POLYGON ((100 320, 60 120, 240 180, 200 260, 100 320)) </a>
+ <b> POLYGON ((420 320, 280 260, 400 100, 420 320)) </b>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="72"> true </op></test>
+<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="71"> false </op></test>
+</case>
+<case>
+ <desc>mAmA - overlapping multipolygons</desc>
+ <a> MULTIPOLYGON (((40 240, 160 320, 40 380, 40 240)), ((100 240, 240 60, 40 40, 100 240))) </a>
+ <b> MULTIPOLYGON (((220 280, 120 160, 300 60, 360 220, 220 280)), ((240 380, 280 300, 420 340, 240 380))) </b>
+</case>
+</run>
Modified: trunk/tests/xmltester/tests/testLeaksBig.xml
--- trunk/tests/xmltester/tests/testLeaksBig.xml 2009-05-02 09:20:26 UTC (rev 2452)
+++ trunk/tests/xmltester/tests/testLeaksBig.xml 2009-05-02 09:25:36 UTC (rev 2453)
@@ -10285,94 +10285,6 @@
</case>
<case>
- <desc>PP - disjoint points</desc>
- <a> POINT(10 10) </a>
- <b> POINT(100 100) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="200">true</op></test>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="100">false</op></test>
-</case>
-<case>
- <desc>PP - overlapping points</desc>
- <b> POINT(10 10) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="0">true</op></test>
-</case>
-<case>
- <desc>PL - point on linestring</desc>
- <a> POINT (340 200) </a>
- <b> LINESTRING (80 280, 340 200, 80 80) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="10">true</op></test>
-</case>
-<case>
- <desc>PL - point not on linestring</desc>
- <a> LINESTRING (100 100, 200 100, 200 200, 100 200, 100 100) </a>
- <b> POINT (10 10) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="128">true</op></test>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="127">false</op></test>
-</case>
-<case>
- <desc>PA - point inside polygon</desc>
- <a> POINT (240 160) </a>
- <b> POLYGON ((100 260, 340 180, 100 60, 180 160, 100 260)) </b>
-</case>
-<case>
- <desc>mPA - points outside polygon</desc>
- <a> POLYGON ((200 180, 60 140, 60 260, 200 180)) </a>
- <b> MULTIPOINT (140 280, 140 320) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="60">true</op></test>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="57">false</op></test>
-</case>
-<case>
- <desc>LL - disjoint linestrings</desc>
- <a> LINESTRING (40 300, 240 260, 60 160, 140 60) </a>
- <b> LINESTRING (140 360, 260 280, 240 120, 120 160) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="18">true</op></test>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="17">false</op></test>
-</case>
-<case>
- <desc>LL - crossing linestrings</desc>
- <a> LINESTRING (40 300, 280 220, 60 160, 140 60) </a>
-</case>
-<case>
- <desc>AA - overlapping polygons</desc>
- <a> POLYGON ((60 260, 260 180, 100 60, 60 160, 60 260)) </a>
- <b> POLYGON ((220 280, 120 160, 300 60, 360 220, 220 280)) </b>
-</case>
-<case>
- <desc>AA - disjoint polygons</desc>
- <a> POLYGON ((100 320, 60 120, 240 180, 200 260, 100 320)) </a>
- <b> POLYGON ((420 320, 280 260, 400 100, 420 320)) </b>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="72">true</op></test>
-<test><op name="isWithinDistance" arg1="A" arg2="B" arg3="71">false</op></test>
-</case>
-<case>
- <desc>mAmA - overlapping multipolygons</desc>
- <a> MULTIPOLYGON (((40 240, 160 320, 40 380, 40 240)), ((100 240, 240 60, 40 40, 100 240))) </a>
- <b> MULTIPOLYGON (((220 280, 120 160, 300 60, 360 220, 220 280)), ((240 380, 280 300, 420 340, 240 380))) </b>
-</case>
-<case>
<desc>Multipoint buffer</desc>
<a>
MULTIPOINT(0 0, 5 5)
More information about the geos-commits
