[geos-commits] r2455 - trunk/tests/xmltester/tests
svn_geos at osgeo.org
Sat May 2 05:42:20 EDT 2009
Author: strk
Date: 2009-05-02 05:42:20 -0400 (Sat, 02 May 2009)
New Revision: 2455
trunk/tests/xmltester/tests/testLeaksBig.xml
Drop test also found in TestFunctionPLPrec.xml
Modified: trunk/tests/xmltester/tests/testLeaksBig.xml
--- trunk/tests/xmltester/tests/testLeaksBig.xml 2009-05-02 09:40:10 UTC (rev 2454)
+++ trunk/tests/xmltester/tests/testLeaksBig.xml 2009-05-02 09:42:20 UTC (rev 2455)
@@ -3181,18 +3181,6 @@
</op>
</test>
</case>
-<case>
- <desc>PP - Point just off line. Causes non-robust algorithms to fail.</desc>
- <a>
- LINESTRING(-123456789 -40, 381039468754763 123456789)
- </a>
- <b>
- POINT(0 0)
- </b>
-<test>
- <op name="intersects">false</op>
-</test>
-</case>
<case>
<desc>A/A-1-1: same polygons [dim(2){A.A.Int = B.A.Int}, dim(1){A.A.Bdy.SP-EP = B.A.Bdy.SP-EP}]</desc>
More information about the geos-commits
