[geos-commits] r2465 - in trunk/source: geom headers/geos/geom
svn_geos at osgeo.org
Mon May 4 19:23:10 EDT 2009
Author: strk
Date: 2009-05-04 19:23:10 -0400 (Mon, 04 May 2009)
New Revision: 2465
trunk/source/geom/Geometry.cpp
trunk/source/headers/geos/geom/Geometry.h
trunk/source/headers/geos/geom/Geometry.inl
Geometry up to 1.112 with a minor bugfix and performance improvement in Geometry::covers
Modified: trunk/source/geom/Geometry.cpp
--- trunk/source/geom/Geometry.cpp 2009-05-04 23:04:13 UTC (rev 2464)
+++ trunk/source/geom/Geometry.cpp 2009-05-04 23:23:10 UTC (rev 2465)
@@ -15,7 +15,7 @@
- * Last port: geom/Geometry.java rev. 1.106
+ * Last port: geom/Geometry.java rev. 1.112
@@ -380,12 +380,15 @@
#ifdef SHORTCIRCUIT_PREDICATES
// short-circuit test
- if (! getEnvelopeInternal()->contains(g->getEnvelopeInternal()))
+ if (! getEnvelopeInternal()->covers(g->getEnvelopeInternal()))
return false;
#endif
// optimization for rectangle arguments
if (isRectangle()) {
- return getEnvelopeInternal()->contains(g->getEnvelopeInternal());
+ // since we have already tested that the test envelope
+ // is covered
+ return true;
auto_ptr<IntersectionMatrix> im(relate(g));
Modified: trunk/source/headers/geos/geom/Geometry.h
--- trunk/source/headers/geos/geom/Geometry.h 2009-05-04 23:04:13 UTC (rev 2464)
+++ trunk/source/headers/geos/geom/Geometry.h 2009-05-04 23:23:10 UTC (rev 2465)
@@ -15,7 +15,7 @@
@@ -328,9 +328,20 @@
virtual const Envelope* getEnvelopeInternal() const;
- * \brief
- * Returns true if the DE-9IM intersection matrix for the
- * two Geometrys is FF*FF****.
+ * Tests whether this geometry is disjoint from the specified geometry.
+ * The <code>disjoint</code> predicate has the following equivalent
+ * definitions:
+ * - The two geometries have no point in common
+ * - The DE-9IM Intersection Matrix for the two geometries matches
+ * <code>[FF*FF****]</code>
+ * - <code>! g.intersects(this)</code>
+ * (<code>disjoint</code> is the inverse of <code>intersects</code>)
+ * @param g the Geometry with which to compare this Geometry
+ * @return true if the two <code>Geometry</code>s are disjoint
+ * @see Geometry::intersects
virtual bool disjoint(const Geometry *other) const;
@@ -344,10 +355,26 @@
virtual bool intersects(const Geometry *g) const;
- * \brief
- * Returns true if the DE-9IM intersection matrix for the two
- * Geometrys is T*T****** (for a point and a curve, a point and
- * an area or a line and an area) 0******** (for two curves).
+ * Tests whether this geometry crosses the specified geometry.
+ * The <code>crosses</code> predicate has the following equivalent
+ * definitions:
+ * - The geometries have some but not all interior points in common.
+ * - <code>[T*T******]</code> (for P/L, P/A, and L/A situations)
+ * - <code>[T*****T**]</code> (for L/P, A/P, and A/L situations)
+ * - <code>[0********]</code> (for L/L situations)
+ * For any other combination of dimensions this predicate returns
+ * <code>false</code>.
+ * The SFS defined this predicate only for P/L, P/A, L/L, and L/A
+ * situations.
+ * JTS extends the definition to apply to L/P, A/P and A/L situations
+ * as well, in order to make the relation symmetric.
+ * @param g the <code>Geometry</code> with which to compare this
+ * <code>Geometry</code>
+ *@return <code>true</code> if the two <code>Geometry</code>s cross.
virtual bool crosses(const Geometry *g) const;
@@ -416,14 +443,15 @@
* or <code>***T**FF*</code>
* or <code>****T*FF*</code>
* - <code>g.coveredBy(this)</code>
- * (<code>covers</code> is the inverse of <code>coverdBy</code>)
+ * (<code>covers</code> is the inverse of <code>coveredBy</code>)
- * Note the difference between <code>covers</code> and
- * <code>contains</code>
- * - <code>covers</code> is a more inclusive relation.
- * In particular, unlike <code>contains</code> it does not
- * distinguish between points in the boundary and in the interior
- * of geometries.
+ * If either geometry is empty, the value of this predicate
+ * is <tt>false</tt>.
+ * This predicate is similar to {@link #contains},
+ * but is more inclusive (i.e. returns <tt>true</tt> for more cases).
+ * In particular, unlike <code>contains</code> it does not distinguish
+ * between points in the boundary and in the interior of geometries.
* For most situations, <code>covers</code> should be used in
* preference to <code>contains</code>.
* As an added benefit, <code>covers</code> is more amenable to
@@ -434,7 +462,7 @@
* @return <code>true</code> if this <code>Geometry</code>
- * covers <code>g</code>
+ * covers <code>g</code>
* @see Geometry::contains
* @see Geometry::coveredBy
@@ -442,30 +470,34 @@
bool covers(const Geometry* g) const;
/** \brief
- * Returns <code>true</code> if this geometry is covered by the
+ * Tests whether this geometry is covered by the
* specified geometry.
+ * The <code>coveredBy</code> predicate has the following
+ * equivalent definitions:
+ * - Every point of this geometry is a point of the other geometry.
+ * <code>[T*F**F***]</code>
+ * or <code>[*TF**F***]</code>
+ * or <code>[**FT*F***]</code>
+ * or <code>[**F*TF***]</code>
+ * - <code>g.covers(this)</code>
+ * (<code>coveredBy</code> is the converse of <code>covers</code>)
- * - Every point of this geometry is a point of the other geometry.
- * - The DE-9IM Intersection Matrix for the two geometries is
- * <code>T*F**F***</code>
- * or <code>*TF**F***</code>
- * or <code>**FT*F***</code>
- * or <code>**F*TF***</code>
- * - <code>g.covers(this)</code>
- * (<code>coveredBy</code> is the inverse of <code>covers</code>)
- * Note the difference between <code>coveredBy</code> and
- * <code>within</code>
- * - <code>coveredBy</code> is a more inclusive relation.
+ * This predicate is similar to {@link #within},
- * @param g
- * the <code>Geometry</code> with which to compare this
- * <code>Geometry</code>
- * @return <code>true</code> if this <code>Geometry</code> is
- * covered by <code>g</code>
+ * this <code>Geometry</code>
+ * @return <code>true</code> if this <code>Geometry</code>
+ * is covered by <code>g</code>
- * @see Geometry::within
- * @see Geometry::covers
+ * @see Geometry#within
+ * @see Geometry#covers
bool coveredBy(const Geometry* g) const {
return g->covers(this);
Modified: trunk/source/headers/geos/geom/Geometry.inl
--- trunk/source/headers/geos/geom/Geometry.inl 2009-05-04 23:04:13 UTC (rev 2464)
+++ trunk/source/headers/geos/geom/Geometry.inl 2009-05-04 23:23:10 UTC (rev 2465)
@@ -14,7 +14,7 @@
More information about the geos-commits
