[geos-commits] r2467 - trunk/source/geom/util
svn_geos at osgeo.org
Mon May 4 20:04:34 EDT 2009
Author: strk
Date: 2009-05-04 20:04:34 -0400 (Mon, 04 May 2009)
New Revision: 2467
trunk/source/geom/util/GeometryTransformer.cpp
Fix memory leak on exception
Modified: trunk/source/geom/util/GeometryTransformer.cpp
--- trunk/source/geom/util/GeometryTransformer.cpp 2009-05-04 23:43:26 UTC (rev 2466)
+++ trunk/source/geom/util/GeometryTransformer.cpp 2009-05-05 00:04:34 UTC (rev 2467)
@@ -328,7 +328,7 @@
std::cerr << "GeometryTransformer::transformMultiPolygon(MultiPolygon " << geom <<", Geometry " << parent << ");" << std::endl;
#endif
- vector<Geometry*>* transGeomList = new vector<Geometry*>();
+ auto_ptr< vector<Geometry*> > transGeomList( new vector<Geometry*>() );
for (unsigned int i=0, n=geom->getNumGeometries(); i<n; i++)
@@ -344,7 +344,7 @@
transGeomList->push_back(transformGeom.release());
- return Geometry::AutoPtr(factory->buildGeometry(transGeomList));
+ return Geometry::AutoPtr(factory->buildGeometry(transGeomList.release()));
More information about the geos-commits
