[geos-commits] r2484 - trunk/capi
svn_geos at osgeo.org
Wed May 6 16:47:39 EDT 2009
Author: strk
Date: 2009-05-06 16:47:39 -0400 (Wed, 06 May 2009)
New Revision: 2484
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
Fix bug #135, give an hint about GEOSGeom_getDimensions being related to GEOSCoordSeq_getDimensions, fix signed vs. unsigned compiler warning.
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2009-05-06 20:22:19 UTC (rev 2483)
+++ trunk/capi/geos_c.h.in 2009-05-06 20:47:39 UTC (rev 2484)
@@ -675,6 +675,7 @@
* Return 0 on exception (or empty geometry)
+ * See also GEOSCoordSeq_getDimensions
extern int GEOS_DLL GEOSGeom_getDimensions(const GEOSGeometry* g);
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-05-06 20:22:19 UTC (rev 2483)
+++ trunk/capi/geos_ts_c.cpp 2009-05-06 20:47:39 UTC (rev 2484)
@@ -2129,7 +2129,7 @@
#endif
std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
- for (int i = 0; i < lines->size(); ++i)
+ for (std::vector<Geometry *>::size_type i = 0; i < lines->size(); ++i)
(*geoms)[i] = (*lines)[i];
@@ -2841,6 +2841,11 @@
using geos::geom::Point;
using geos::geom::GeometryCollection;
+ if ( g->isEmpty() )
+ return 0;
std::size_t dim = 0;
const LineString *ls = dynamic_cast<const LineString *>(g);
if ( ls )
@@ -2865,10 +2870,6 @@
const GeometryCollection *coll = dynamic_cast<const GeometryCollection *>(g);
if ( coll )
- if ( coll->isEmpty() )
- return 0;
return GEOSGeom_getDimensions_r(extHandle, coll->getGeometryN(0));
More information about the geos-commits
