[geos-commits] r2486 - in trunk/source: geom headers/geos/geom
svn_geos at osgeo.org
Thu May 7 04:52:45 EDT 2009
Author: strk
Date: 2009-05-07 04:52:44 -0400 (Thu, 07 May 2009)
New Revision: 2486
trunk/source/geom/CoordinateSequenceFactory.cpp
trunk/source/headers/geos/geom/CoordinateSequenceFactory.h
Port info, doxygen cleanups
Modified: trunk/source/geom/CoordinateSequenceFactory.cpp
--- trunk/source/geom/CoordinateSequenceFactory.cpp 2009-05-07 08:45:47 UTC (rev 2485)
+++ trunk/source/geom/CoordinateSequenceFactory.cpp 2009-05-07 08:52:44 UTC (rev 2486)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: geom/CoordinateSequenceFactory.java rev 1.14 (JTS-1.10)
#include <geos/geom/CoordinateSequenceFactory.h>
Modified: trunk/source/headers/geos/geom/CoordinateSequenceFactory.h
--- trunk/source/headers/geos/geom/CoordinateSequenceFactory.h 2009-05-07 08:45:47 UTC (rev 2485)
+++ trunk/source/headers/geos/geom/CoordinateSequenceFactory.h 2009-05-07 08:52:44 UTC (rev 2486)
@@ -11,6 +11,10 @@
#ifndef GEOS_GEOM_COORDINATESEQUENCEFACTORY_H
@@ -35,26 +39,34 @@
* \brief
- * An object that knows how to build a particular implementation of
- * CoordinateSequence from an array of Coordinates.
+ * A factory to create concrete instances of {@link CoordinateSequence}s.
+ * Used to configure {@link GeometryFactory}s
+ * to provide specific kinds of CoordinateSequences.
class CoordinateSequenceFactory {
public:
/** \brief
* Returns a CoordinateSequence based on the given array.
- * Whether or not the vector is copied is implementation-dependent,
- * for this reason caller does give up ownership of it.
+ * Whether the array is copied or simply referenced
+ * is implementation-dependent.
+ * For this reason caller does give up ownership of it.
* Implementations that will not copy it will need take care
* of deleting it.
- * Note that a NULL value is allowed as coordinates, and will
- * create an empty CoordinateSequence.
+ * This method must handle null arguments by creating
+ * an empty sequence.
+ * @param coordinates the coordinates
virtual CoordinateSequence *create(
std::vector<Coordinate> *coordinates) const=0;
/** \brief
* Creates a CoordinateSequence of the specified size and dimension.
* For this to be useful, the CoordinateSequence implementation must
* be mutable.
More information about the geos-commits
