[geos-commits] r2488 - in trunk/tests/xmltester: . tests
svn_geos at osgeo.org
Thu May 7 11:36:56 EDT 2009
Author: strk
Date: 2009-05-07 11:36:51 -0400 (Thu, 07 May 2009)
New Revision: 2488
Added:
trunk/tests/xmltester/tests/bug188.xml
trunk/tests/xmltester/Makefile.am
Add XML testcase for bug 188
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2009-05-07 15:36:30 UTC (rev 2487)
+++ trunk/tests/xmltester/Makefile.am 2009-05-07 15:36:51 UTC (rev 2488)
@@ -15,6 +15,7 @@
$(srcdir)/tests/linemerge.xml \
$(srcdir)/tests/TestIsValid.xml \
$(srcdir)/tests/robustness.xml \
+ $(srcdir)/tests/bug188.xml \
$(srcdir)/tests/general/TestBoundary.xml \
$(srcdir)/tests/general/TestBuffer.xml \
$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Added: trunk/tests/xmltester/tests/bug188.xml
--- trunk/tests/xmltester/tests/bug188.xml (rev 0)
+++ trunk/tests/xmltester/tests/bug188.xml 2009-05-07 15:36:51 UTC (rev 2488)
@@ -0,0 +1,22 @@
+<run>
+ <desc>
+http://trac.osgeo.org/geos/ticket/188
+ </desc>
+ <precisionModel type="FLOATING" />
+ <resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+ Caused crash in RightmostEdgeFinder creating BufferSubgraphs
+ </desc>
+ <a>
+0103000000010000000B000000713D0AD7C3F9C3403D0AD7A3E8B01441295C8FC255FBC340C3F5285C0BB1144153BB8CF8AD01C44092DD2F29FEB0144148E17A14AE01C4408FC2F528FEB0144148E17A146E01C440A4703D0AF0B014411F85EB517801C44085EB51B8EFB014419A999999B9FFC34066666666CBB0144133333333F3FCC340CDCCCCCCC9B01441295C8FC2F5FBC3408FC2F528CAB014413D0AD7A3F0FBC340CDCCCCCCC9B01441713D0AD7C3F9C3403D0AD7A3E8B01441
+ </a>
+<test>
+ <op name='buffer' arg1='A' arg2='-5.0000000000000004e-006' arg3='3'>
+0103000000010000000F000000693B38D7C3F9C340F428D7A3E8B0144168CCA9C255FBC3400F64275C0BB11441F72C82F8AD01C440D4982E29FEB01441501A4C14AE01C4402CC9F428FEB01441FB5951146E01C440B39F3D0AF0B01441E41853146E01C44058063D0AF0B01441C8385D146E01C44060833C0AF0B01441AA97BA517801C440699851B8EFB0144145027C99B9FFC340C0A56766CBB01441F3A43233F3FCC340E51CCECCC9B01441B94391C2F5FBC340C211F728CAB014412A4F79C2F5FBC340FDDFF628CAB014412F0869C2F5FBC340D64AF628CAB01441FD95D2A3F0FBC340CFB6CFCCC9B01441693B38D7C3F9C340F428D7A3E8B01441
+ </op>
+</test>
+</case>
+</run>
More information about the geos-commits
