[geos-commits] r2509 - in branches/3.1: . capi
svn_geos at osgeo.org
Wed May 13 08:35:01 EDT 2009
Author: warmerdam
Date: 2009-05-13 08:35:00 -0400 (Wed, 13 May 2009)
New Revision: 2509
branches/3.1/ChangeLog
branches/3.1/capi/geos_c.cpp
branches/3.1/capi/geos_c.h.in
branches/3.1/capi/geos_ts_c.cpp
added GEOSFree() and GEOSFree_r() (#249)
Modified: branches/3.1/ChangeLog
--- branches/3.1/ChangeLog 2009-05-13 11:29:55 UTC (rev 2508)
+++ branches/3.1/ChangeLog 2009-05-13 12:35:00 UTC (rev 2509)
@@ -1,3 +1,8 @@
+2009-05-13 Frank Warmerdam <warmerdam at pobox.com>
+ * capi/geos_ts_c.cpp, capi/geos_c.cpp, capi/geos_c.h.in: Added
+ GEOSFree() and GEOSFree_r() functions (#249).
2009-02-07 23:29 pramsey
* source/headers/geos/precision/Makefile.am: Include
Modified: branches/3.1/capi/geos_c.cpp
--- branches/3.1/capi/geos_c.cpp 2009-05-13 11:29:55 UTC (rev 2508)
+++ branches/3.1/capi/geos_c.cpp 2009-05-13 12:35:00 UTC (rev 2509)
@@ -85,6 +85,12 @@
finishGEOS_r( handle );
+void
+GEOSFree (void* buffer)
+ GEOSFree_r( handle, buffer );
** relate()-related functions
** return 0 = false, 1 = true, 2 = error occured
Modified: branches/3.1/capi/geos_c.h.in
--- branches/3.1/capi/geos_c.h.in 2009-05-13 11:29:55 UTC (rev 2508)
+++ branches/3.1/capi/geos_c.h.in 2009-05-13 12:35:00 UTC (rev 2509)
@@ -21,9 +21,8 @@
* functions, and call finishGEOS() when done.
* - Currently you have to explicitly GEOSGeom_destroy() all
- * GEOSGeom objects to avoid memory leaks, and to free()
- * all returned char * (unless const). This might change
- * before first release to ensure greater API stability.
+ * GEOSGeom objects to avoid memory leaks, and to GEOSFree()
+ * all returned char * (unless const).
@@ -820,6 +819,12 @@
GEOSWKBWriter* writer, const char writeSRID);
+ * Free buffers returned by stuff like GEOSWKBWriter_write(),
+ * GEOSWKBWriter_writeHEX() and GEOSWKTWriter_write().
+extern void GEOS_DLL GEOSFree( void *buffer );
+extern void GEOS_DLL GEOSFree_r( GEOSContextHandle_t handle, void *buffer );
#ifdef __cplusplus
} // extern "C"
Modified: branches/3.1/capi/geos_ts_c.cpp
--- branches/3.1/capi/geos_ts_c.cpp 2009-05-13 11:29:55 UTC (rev 2508)
+++ branches/3.1/capi/geos_ts_c.cpp 2009-05-13 12:35:00 UTC (rev 2509)
@@ -152,6 +152,12 @@
extHandle = NULL;
+void
+GEOSFree_r (GEOSContextHandle_t extHandle, void* buffer)
+ std::free(buffer);
// relate()-related functions
// return 0 = false, 1 = true, 2 = error occured
More information about the geos-commits
