[geos-commits] r2533 - in trunk: . tests/bigtest
svn_geos at osgeo.org
Thu May 28 10:38:40 EDT 2009
Author: mloskot
Date: 2009-05-28 10:38:40 -0400 (Thu, 28 May 2009)
New Revision: 2533
trunk/configure.in
trunk/tests/bigtest/
Fixed aclocal warnings for mixing cache-id's in configure.in.
Modified: trunk/configure.in
--- trunk/configure.in 2009-05-27 19:11:05 UTC (rev 2532)
+++ trunk/configure.in 2009-05-28 14:38:40 UTC (rev 2533)
@@ -125,14 +125,14 @@
# -pedantic: ISO does not support long long
# we add -Wno-long-long to avoid those messages
WARNFLAGS=""
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_no_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_no_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
# To make numerical computation more stable, we use --ffloat-store
NUMERICFLAGS=""
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS}"
Property changes on: trunk/tests/bigtest
___________________________________________________________________
- TestSweepLineSpeed
Makefile
Makefile.in
.deps
.libs
+ bug234
TestSweepLineSpeed
Makefile
Makefile.in
.deps
.libs
More information about the geos-commits
