[geos-commits] r2711 - trunk
svn_geos at osgeo.org
Tue Nov 10 17:58:37 EST 2009
Author: strk
Date: 2009-11-10 17:58:36 -0500 (Tue, 10 Nov 2009)
New Revision: 2711
trunk/ChangeLog
trunk/HOWTO_RELEASE
trunk/NEWS
Package stuff for release
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2009-10-29 21:06:35 UTC (rev 2710)
+++ trunk/ChangeLog 2009-11-10 22:58:36 UTC (rev 2711)
@@ -1,44 +1,210 @@
-2009-10-29 20:45 Mateusz Loskot <mateusz at loskot.net>
+2009-10-29 21:06 Mateusz Loskot <mateusz at loskot.net>
- * [r2707] tests/unit/operation/buffer/BufferOpTest.cpp: missing include
- of BufferParameters.h header
+ * [r2710] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
+ linker problem with DEFAULT_QUADRANT_SEGMENT constant
-2009-10-29 16:25 Mateusz Loskot <mateusz at loskot.net>
+2009-10-29 20:58 Mateusz Loskot <mateusz at loskot.net>
- * [r2706] tests/unit/operation/buffer/BufferOpTest.cpp: Added more test
- cases for buffer calculation based on A (input) geometries from
- XMLTester's buffer.xml and TestBufferExternal2.xml tests.
+ * [r2709] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
-2009-10-29 15:15 Mateusz Loskot <mateusz at loskot.net>
+2009-10-29 20:55 Mateusz Loskot <mateusz at loskot.net>
- * [r2705] tests/unit/operation/buffer/BufferOpTest.cpp: Added test case
- for buffer of multipolygon from XMLTester's buffer.xml, case #25 but
- with custom quadrant segments
+ * [r2708] tests/unit/operation/buffer/BufferOpTest.cpp: Fixed CRLF
+ to LF in BufferOpTest.cpp
-2009-10-29 14:25 Mateusz Loskot <mateusz at loskot.net>
+2009-10-29 20:47 Mateusz Loskot <mateusz at loskot.net>
- * [r2704] tests/unit/operation/buffer/BufferOpTest.cpp: Added test case
- for buffer of POINT(0 0) with distance 1.0 and 32 quadrant segments.
-2009-10-29 12:30 Mateusz Loskot <mateusz at loskot.net>
+ * [r2707] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Missing include of BufferParameters.h header in BufferOpTest.cpp
+ unit suite
- * [r2703] tests/unit/operation/buffer: added unit test case for BufferOp,
- tests/unit/Makefile.am: added new test case source to Makefile,
- build/msvc90/geos_unit/geos_unit.vcproj: updated Visual C++ project.
+2009-10-29 16:20 Mateusz Loskot <mateusz at loskot.net>
-2009-10-28 12:10 Mateusz Loskot <mateusz at loskot.net>
+ * [r2706] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added more test cases for buffer calculation based on A (input)
+ geometries from XMLTester's buffer.xml and
+ TestBufferExternal2.xml tests.
- * [r2702] tests/xmltester/XMLTester.cpp: declare checkBufferSuccess function
- to take geometries by refernece to const.
+2009-10-29 15:11 Mateusz Loskot <mateusz at loskot.net>
-2009-10-25 18:47 Mateusz Loskot <mateusz at loskot.net>
- * Fixed typo in getCentroid function comment in Geometry.h
+ * [r2705] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added test case for buffer of multipolygon from XMLTester's
+ buffer.xml, case #25 but with custom quadrant segments
-2009-10-19 14:47 Mateusz Loskot <mateusz at loskot.net>
+2009-10-29 14:24 Mateusz Loskot <mateusz at loskot.net>
- * [r2684] tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
+ * [r2704] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added test case for buffer of POINT(0 0) with distance 1.0 and 32
+ quadrant segments.
+2009-10-29 12:33 Mateusz Loskot <mateusz at loskot.net>
+ * [r2703] ChangeLog, build/msvc90/geos_unit/geos_unit.vcproj,
+ tests/unit/Makefile.am, tests/unit/operation/buffer,
+ tests/unit/operation/buffer/BufferOpTest.cpp: *
+ tests/unit/operation/buffer: added unit test case for BufferOp,
+ * tests/unit/Makefile.am: added new test case source to Makefile,
+ * build/msvc90/geos_unit/geos_unit.vcproj: updated Visual C++
+ project.
+2009-10-28 12:09 Mateusz Loskot <mateusz at loskot.net>
+ * [r2702] ChangeLog, build/msvc90/geos.sln,
+ tests/xmltester/XMLTester.cpp: tests/xmltester/XMLTester.cpp:
+ declare checkBufferSuccess function to take geometries by
+ refernece to const
+2009-10-25 18:48 Mateusz Loskot <mateusz at loskot.net>
+ * [r2701] ChangeLog, source/headers/geos/geom/Geometry.h: Fixed
+ typo in getCentroid function comment in Geometry.h.
+2009-10-23 13:04 Sandro Santilli <strk at keybit.net>
+ * [r2700] source/headers/geos/linearref/LinearLocation.h,
+ source/linearref/LinearLocation.cpp: Have
+ LinearLocation::getSegment return by auto_ptr to encode ownership
+ transfer. Fixes leak reported in #296.
+2009-10-23 12:58 Sandro Santilli <strk at keybit.net>
+ * [r2699] source/headers/geos/linearref/LinearLocation.h,
+ source/linearref/LinearLocation.cpp: Fix port info, add standard
+ protection notes
+2009-10-23 10:21 Sandro Santilli <strk at keybit.net>
+ * [r2698] source/headers/geos/linearref/LinearGeometryBuilder.h,
+ source/linearref/LinearGeometryBuilder.cpp: Add destructor to
+ LinearGeometryBuilder fixing memory leaks there.
+2009-10-23 10:13 Sandro Santilli <strk at keybit.net>
+ * [r2697] source/linearref/LinearGeometryBuilder.cpp: Fix memory
+ access error (#283)
+2009-10-23 10:03 Sandro Santilli <strk at keybit.net>
+ * [r2696] source/headers/geos/linearref/LinearGeometryBuilder.h,
+ source/linearref/LinearGeometryBuilder.cpp: Fix port info for
+2009-10-23 09:53 Sandro Santilli <strk at keybit.net>
+ * [r2695] source/headers/geos/linearref/LinearGeometryBuilder.h,
+ source/linearref/LinearGeometryBuilder.cpp: Cleanup
+ LinearGeometrybuilder defs and impl to match common code style,
+ add note about suspicious things (not written but noted that the
+ class seems to lack a destructor..)
+2009-10-23 09:43 Sandro Santilli <strk at keybit.net>
+ * [r2694] source/headers/geos/linearref/LocationIndexOfLine.h,
+ source/linearref/LengthIndexedLine.cpp,
+ source/linearref/LocationIndexOfLine.cpp,
+ tests/unit/linearref/LengthIndexedLineTest.cpp: Document
+ ownership of return from LocationIndexOfLine::indicesOf, fix
+ mismatch delete/delete[] in core and unit test
+2009-10-23 09:34 Sandro Santilli <strk at keybit.net>
+ * [r2693] source/headers/geos/algorithm/BoundaryNodeRule.h: Add
+ virtual dtor to virtual class
+2009-10-23 09:33 Sandro Santilli <strk at keybit.net>
+ * [r2692] tests/xmltester/tinyxml/tinyxmlparser.cpp: add some
+ parens to hush gcc warning
+2009-10-23 09:00 Sandro Santilli <strk at keybit.net>
+ * [r2691] tests/unit/Makefile.am: Fix static building of C-api
+ demo/tests
+2009-10-23 08:34 Sandro Santilli <strk at keybit.net>
+ * [r2690] tests/xmltester/Makefile.am: Run the last
+ available-but-no-automatically-run test: test.xml
+2009-10-22 18:18 Sandro Santilli <strk at keybit.net>
+ * [r2689] tests/xmltester/tests/buffer.xml,
+ tests/xmltester/tests/buffer_snapround.xml: Merge
+ buffer_snapround.xml into buffer.xml
+2009-10-22 17:13 Sandro Santilli <strk at keybit.net>
+ * [r2688] tests/xmltester/Makefile.am: A quick check reveals that
+ the tests in buffer.xml are not really duplicated elsewhere so we
+ run that test too now as part of make check
+2009-10-22 17:07 Sandro Santilli <strk at keybit.net>
+ * [r2687] tests/xmltester/tests/buffer.xml: Give buffer.xml cases a
+ somewhat more helpful description, fix 4 expected results after
+ eye-checking. This is still not automatically run case it might
+ contain duplicated tests from elsewhere (to be checked).
+2009-10-22 16:30 Sandro Santilli <strk at keybit.net>
+ * [r2686] tests/xmltester/XMLTester.cpp: Don't segfault on EOF
+ inside <op> tag
+2009-10-20 16:59 Sandro Santilli <strk at keybit.net>
+ * [r2685] source/headers/geos/index/strtree/AbstractSTRtree.h,
+ source/index/strtree/STRtree.cpp: Commit MingW bug workaround
+ provided by sanak in ticket #293
+2009-10-19 13:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r2684] ChangeLog,
+ build/msvc90/geos_xmltester/geos_xmltester.vcproj,
+ tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
fixed missing attribute.
+2009-10-17 14:47 Sandro Santilli <strk at keybit.net>
+ * [r2683] ChangeLog: updated
+2009-10-17 14:43 Sandro Santilli <strk at keybit.net>
+ * [r2682] NEWS: updated
+2009-10-17 14:35 Sandro Santilli <strk at keybit.net>
+ * [r2681] source/algorithm/distance/DistanceToPoint.cpp: Half the
+ calls to the virtual CoordinateSequence::getAt when computing
+ line distances
+2009-10-17 13:40 Sandro Santilli <strk at keybit.net>
+ * [r2680] source/geom/CoordinateArraySequence.cpp: Drop pointless
+ asserts. We'd abort anyway if vector is null. For the
+ out-of-range case the GNU c++ lib helps debugging with an
+ environment variable
+2009-10-17 13:04 Sandro Santilli <strk at keybit.net>
+ * [r2679] source/noding/OrientedCoordinateArray.cpp: Add note of
+ private/static nature of implemented methods
+2009-10-17 12:28 Sandro Santilli <strk at keybit.net>
+ * [r2678] source/geom/CoordinateArraySequence.cpp,
+ source/geom/Polygon.cpp,
+ source/headers/geos/geom/CoordinateArraySequence.h,
+ source/headers/geos/geom/CoordinateSequence.h: Expose a usable
+ toVector method for CoordinateSequence (ie: no memory management
+ issues). Use it from Polygon::getCoordinates.
+2009-10-17 12:02 Sandro Santilli <strk at keybit.net>
+ * [r2677] source/geom/Polygon.cpp: Don't allocate too much space
+ for polygon points vector. Fixes bug #294.
2009-10-16 15:27 Mateusz Loskot <mateusz at loskot.net>
* [r2676] tests/xmltester/tests/fme.xml: xmltester/tests: missing
Modified: trunk/HOWTO_RELEASE
--- trunk/HOWTO_RELEASE 2009-10-29 21:06:35 UTC (rev 2710)
+++ trunk/HOWTO_RELEASE 2009-11-10 22:58:36 UTC (rev 2711)
@@ -15,7 +15,7 @@
- VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
[ THIS MUST BE CAREFULLY AVOIDED ]
-3: Update the ChangeLog by running svn2cl. Commit the new ChangeLog
+3: Run make ChangeLog. Commit the new ChangeLog.
4: Update the NEWS file (extract most important things from the ChangeLog)
Modified: trunk/NEWS
--- trunk/NEWS 2009-10-29 21:06:35 UTC (rev 2710)
+++ trunk/NEWS 2009-11-10 22:58:36 UTC (rev 2711)
@@ -12,7 +12,8 @@
(earlier exit)
- MultiPolygon::getBoundary always return MultiLineString, also
when the result is the EMPTY geometry.
-- Various bug fixes and optimizations
+- Various bug and leak fixes, optimizations
+- Replace MarkupSTL with tinyXML
Changes in 3.1.0
More information about the geos-commits
