[geos-commits] r2720 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Nov 18 13:57:50 EST 2009
Author: pramsey
Date: 2009-11-18 13:57:49 -0500 (Wed, 18 Nov 2009)
New Revision: 2720
   trunk/HOWTO_RELEASE
Reverse the upgrade process a bit, bump up revision numbers *after* release so that the repo version is always one higher than the release version. (#287)
Modified: trunk/HOWTO_RELEASE
--- trunk/HOWTO_RELEASE	2009-11-18 18:18:34 UTC (rev 2719)
+++ trunk/HOWTO_RELEASE	2009-11-18 18:57:49 UTC (rev 2720)
@@ -1,12 +1,39 @@
+1: Verify that the versions currently set (see 10 and 11 below) make
+   sense for this release.
-1: Increment CAPI_INTERFACE_X in configure.in
+2: Run 'make distcheck', fix any problem with it.
+3: Generate the ChangeLog by running 'make cl'
+4: Update the NEWS file (extract most important things from the ChangeLog)
+5. Commit the new ChangeLog and NEWS files.
+6: Tag the release:
+   $ base=http://svn.osgeo.org/geos/
+   $ svn copy -m "Tagged release MAJOR.MINOR.PATCH" \
+		$base/trunk $base/tags/MAJOR.MINOR.PATCH
+7: Export the tag and 'make dist'. Un-gzip the tarball and bzip2 it
+   instead.
+   $ svn export http://svn.osgeo.org/geos/tags/MAJOR.MINOR.PATCH
+   $ cd MAJOR.MINOR.PATCH
+   $ ./autogen ; ./configure ; make dist
+   $ gzip -d geos-MAJOR.MINOR-PATCH.tar.gz
+   $ bzip2 geos-MAJOR.MINOR-PATCH.tar
+8: Copy the tarball to upload.osgeo.org:/download_data/download/geos
+9: Increment all the version numbers for the next release, as below.
+10: Increment CAPI_INTERFACE_X in configure.in
    - For a release with no interface changes just bump REVISION.
      [ Even if *nothing* changed in CAPI ]
    - Adding interfaces, bump CURRENT/AGE, set REVISION to 0.
    - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
      [ THIS MUST BE CAREFULLY AVOIDED ]
-2: Increment release version:
+11: Increment release version:
    - In configure.in
    - In source/headers/geos/version.h.vc
    - In capi/geos_c.h.in
@@ -15,15 +42,3 @@
      - VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
-3: Run 'make distcheck', fix any problem with it.
-4: Generate the ChangeLog by running 'make cl'
-5: Update the NEWS file (extract most important things from the ChangeLog)
-6. Commit the new ChangeLog and NEWS files.
-7: Tag the release:
-   $ base=http://svn.osgeo.org/geos/
-   $ svn copy -m "Tagged release MAJOR.MINOR.PATCH" \
-		$base/trunk $base/tags/MAJOR.MINOR.PATCH
More information about the geos-commits mailing list
