[geos-commits] r2725 - in trunk/source:
headers/geos/operation/polygonize operation/polygonize
svn_geos at osgeo.org
Thu Nov 19 14:06:55 EST 2009
Author: strk
Date: 2009-11-19 14:06:53 -0500 (Thu, 19 Nov 2009)
New Revision: 2725
trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h
trunk/source/operation/polygonize/PolygonizeGraph.cpp
Do not heap-allocate vector of Node when finding intersections
Modified: trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h
--- trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h 2009-11-19 18:52:45 UTC (rev 2724)
+++ trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h 2009-11-19 19:06:53 UTC (rev 2725)
@@ -141,24 +141,25 @@
* @param ringEdges
* the list of start edges for the edgeRings to convert.
+ * TODO: take ringEdges by ref
void convertMaximalToMinimalEdgeRings(
std::vector<PolygonizeDirectedEdge*> *ringEdges);
* \brief
- * Finds all nodes in a maximal edgering which are self-intersection
- * nodes
+ * Finds all nodes in a maximal edgering
+ * which are self-intersection nodes
* @param startDE
* @param label
- * @return the list of intersection nodes found,
- * or <code>null</code> if no intersection nodes were found.
- * Ownership of returned vector goes to caller.
+ * @param intNodes : intersection nodes found will be pushed here
+ * the vector won't be cleared before pushing.
- static std::vector<planargraph::Node*>* findIntersectionNodes(
- PolygonizeDirectedEdge *startDE,
- long label);
+ static void findIntersectionNodes( PolygonizeDirectedEdge *startDE,
+ long label, std::vector<planargraph::Node*>& intNodes
* @param dirEdges a List of the DirectedEdges in the graph
@@ -195,11 +196,11 @@
EdgeRing* findEdgeRing(PolygonizeDirectedEdge *startDE);
/* Tese are for memory management */
- std::vector<planargraph::Edge *>newEdges;
- std::vector<planargraph::DirectedEdge *>newDirEdges;
- std::vector<planargraph::Node *>newNodes;
- std::vector<EdgeRing *>newEdgeRings;
- std::vector<geom::CoordinateSequence *>newCoords;
+ std::vector<planargraph::Edge *> newEdges;
+ std::vector<planargraph::DirectedEdge *> newDirEdges;
+ std::vector<planargraph::Node *> newNodes;
+ std::vector<EdgeRing *> newEdgeRings;
+ std::vector<geom::CoordinateSequence *> newCoords;
} // namespace geos::operation::polygonize
Modified: trunk/source/operation/polygonize/PolygonizeGraph.cpp
--- trunk/source/operation/polygonize/PolygonizeGraph.cpp 2009-11-19 18:52:45 UTC (rev 2724)
+++ trunk/source/operation/polygonize/PolygonizeGraph.cpp 2009-11-19 19:06:53 UTC (rev 2725)
@@ -168,61 +168,49 @@
delete pns;
- * Convert the maximal edge rings found by the initial graph traversal
- * into the minimal edge rings required by JTS polygon topology rules.
- * @param ringEdges the list of start edges for the edgeRings to convert.
+/* private */
void
-PolygonizeGraph::convertMaximalToMinimalEdgeRings(std::vector<PolygonizeDirectedEdge*> *ringEdges)
+PolygonizeGraph::convertMaximalToMinimalEdgeRings(
+ std::vector<PolygonizeDirectedEdge*> *ringEdges)
- for(int i=0;i<(int)ringEdges->size();i++)
+ typedef std::vector<Node*> IntersectionNodes;
+ typedef std::vector<PolygonizeDirectedEdge*> RingEdges;
+ IntersectionNodes intNodes;
+ for(RingEdges::size_type i=0, in=ringEdges->size();
+ i<in; ++i)
PolygonizeDirectedEdge *de=(*ringEdges)[i];
long label=de->getLabel();
- std::vector<Node*> *intNodes=findIntersectionNodes(de, label);
- if (intNodes==NULL) continue;
+ findIntersectionNodes(de, label, intNodes);
- // flip the next pointers on the intersection nodes to
- // create minimal edge rings
- //std::vector<Node*> *pns=getNodes();
// set the next pointers for the edges around each node
- for(int j=0;j<(int)intNodes->size();j++) {
- Node *node=(*intNodes)[j];
+ for(IntersectionNodes::size_type j=0, jn=intNodes.size();
+ j<jn; ++j)
+ Node *node=intNodes[j];
computeNextCCWEdges(node, label);
- delete intNodes;
+ intNodes.clear();
- * Finds all nodes in a maximal edgering which are self-intersection nodes
- * @param startDE
- * @param label
- * or <code>NULL</code> if no intersection nodes were found.
- * Ownership of returned object goes to caller.
-std::vector<Node*>*
-PolygonizeGraph::findIntersectionNodes(PolygonizeDirectedEdge *startDE, long label)
+/* private static */
+void
+PolygonizeGraph::findIntersectionNodes(PolygonizeDirectedEdge *startDE,
+ long label, std::vector<Node*>& intNodes)
PolygonizeDirectedEdge *de=startDE;
- std::vector<Node*> *intNodes=NULL;
do {
Node *node=de->getFromNode();
if (getDegree(node, label) > 1) {
- intNodes=new std::vector<Node*>();
- intNodes->push_back(node);
+ intNodes.push_back(node);
de=de->getNext();
assert(de!=NULL); // found NULL DE in ring
assert(de==startDE || !de->isInRing()); // found DE already in ring
} while (de!=startDE);
- return intNodes;
More information about the geos-commits
