[geos-commits] r2729 - in trunk/source:
headers/geos/operation/polygonize operation/polygonize
svn_geos at osgeo.org
Thu Nov 19 15:20:32 EST 2009
Author: strk
Date: 2009-11-19 15:20:29 -0500 (Thu, 19 Nov 2009)
New Revision: 2729
trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h
trunk/source/operation/polygonize/PolygonizeGraph.cpp
don't heap-allocate vectors in findLabeledEdgeRings
Modified: trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h
--- trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h 2009-11-19 19:57:36 UTC (rev 2728)
+++ trunk/source/headers/geos/operation/polygonize/PolygonizeGraph.h 2009-11-19 20:20:29 UTC (rev 2729)
@@ -197,10 +197,11 @@
* from the graph, so that there is always a next dirEdge.
* @param startDE the DirectedEdge to start traversing at
- * @return a List of DirectedEdges that form a ring
+ * @param edgesInRing : the DirectedEdges that form a ring will
+ * be pushed here.
- static std::vector<planargraph::DirectedEdge*>* findDirEdgesInRing(
- PolygonizeDirectedEdge *startDE);
+ static void findDirEdgesInRing(PolygonizeDirectedEdge *startDE,
+ std::vector<planargraph::DirectedEdge*>& edgesInRing);
EdgeRing* findEdgeRing(PolygonizeDirectedEdge *startDE);
Modified: trunk/source/operation/polygonize/PolygonizeGraph.cpp
--- trunk/source/operation/polygonize/PolygonizeGraph.cpp 2009-11-19 19:57:36 UTC (rev 2728)
+++ trunk/source/operation/polygonize/PolygonizeGraph.cpp 2009-11-19 20:20:29 UTC (rev 2729)
@@ -248,17 +248,28 @@
PolygonizeGraph::findLabeledEdgeRings(std::vector<DirectedEdge*> &dirEdges,
std::vector<PolygonizeDirectedEdge*> &edgeRingStarts)
+ typedef std::vector<DirectedEdge*> Edges;
+ Edges edges;
// label the edge rings formed
long currLabel=1;
- for(unsigned int i=0; i<dirEdges.size(); ++i)
+ for(Edges::size_type i=0, n=dirEdges.size(); i<n; ++i)
- PolygonizeDirectedEdge *de=(PolygonizeDirectedEdge*)dirEdges[i];
+#ifdef GEOS_CAST_PARANOIA
+ assert(dynamic_cast<PolygonizeDirectedEdge*>(dirEdges[i]));
+#endif
+ PolygonizeDirectedEdge *de =
+ static_cast<PolygonizeDirectedEdge*>(dirEdges[i]);
if (de->isMarked()) continue;
if (de->getLabel() >= 0) continue;
edgeRingStarts.push_back(de);
- std::vector<DirectedEdge*> *edges=findDirEdgesInRing(de);
- label(*edges, currLabel);
- delete edges;
+ findDirEdgesInRing(de, edges);
+ label(edges, currLabel);
+ edges.clear();
++currLabel;
@@ -398,26 +409,18 @@
- * Traverse a ring of DirectedEdges, accumulating them into a list.
- * This assumes that all dangling directed edges have been removed
- * from the graph, so that there is always a next dirEdge.
- * @param startDE the DirectedEdge to start traversing at
-std::vector<DirectedEdge*>*
-PolygonizeGraph::findDirEdgesInRing(PolygonizeDirectedEdge *startDE)
+/* static private */
+void
+PolygonizeGraph::findDirEdgesInRing(PolygonizeDirectedEdge *startDE,
+ std::vector<DirectedEdge*>& edges)
PolygonizeDirectedEdge *de=startDE;
- std::vector<DirectedEdge*> *edges=new std::vector<DirectedEdge*>();
do {
- edges->push_back(de);
+ edges.push_back(de);
de=de->getNext();
assert(de != NULL); // found NULL DE in ring
assert(de==startDE || !de->isInRing()); // found DE already in ring
} while (de != startDE);
- return edges;
EdgeRing *
More information about the geos-commits
