[geos-commits] r2732 - in trunk/source: headers/geos/noding noding
svn_geos at osgeo.org
Thu Nov 19 16:30:01 EST 2009
Author: strk
Date: 2009-11-19 16:30:01 -0500 (Thu, 19 Nov 2009)
New Revision: 2732
trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
Don't heap-allocate std::vector in MCIndexSegmentSetMutualIntersector
Modified: trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h 2009-11-19 21:06:16 UTC (rev 2731)
+++ trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h 2009-11-19 21:30:01 UTC (rev 2732)
@@ -56,7 +56,7 @@
~MCIndexSegmentSetMutualIntersector();
- std::vector<index::chain::MonotoneChain *>* getMonotoneChains()
+ std::vector<index::chain::MonotoneChain *>& getMonotoneChains()
return monoChains;
@@ -89,7 +89,8 @@
private:
- std::vector<index::chain::MonotoneChain *> * monoChains;
+ typedef std::vector<index::chain::MonotoneChain *> MonoChains;
+ MonoChains monoChains;
* The {@link SpatialIndex} used should be something that supports
Modified: trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp
--- trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp 2009-11-19 21:06:16 UTC (rev 2731)
+++ trunk/source/noding/MCIndexSegmentSetMutualIntersector.cpp 2009-11-19 21:30:01 UTC (rev 2732)
@@ -54,9 +54,9 @@
MCIndexSegmentSetMutualIntersector::SegmentOverlapAction overlapAction( *segInt);
- for (std::size_t i = 0, ni = monoChains->size(); i < ni; i++)
+ for (MonoChains::size_type i = 0, ni = monoChains.size(); i < ni; ++i)
- MonotoneChain * queryChain = (MonotoneChain *)((*monoChains)[i]);
+ MonotoneChain * queryChain = (MonotoneChain *)monoChains[i];
std::vector<void*> overlapChains;
index->query( &(queryChain->getEnvelope()), overlapChains);
@@ -76,16 +76,16 @@
void
MCIndexSegmentSetMutualIntersector::addToMonoChains(SegmentString* segStr)
- std::vector<MonotoneChain*>* segChains = 0;
- segChains = MonotoneChainBuilder::getChains(segStr->getCoordinates(), segStr);
+ MonoChains* segChains =
+ MonotoneChainBuilder::getChains(segStr->getCoordinates(), segStr);
chainStore.push_back(segChains);
- for (std::size_t i = 0, ni = segChains->size(); i < ni; i++)
+ for (MonoChains::size_type i = 0, ni = segChains->size(); i < ni; i++)
MonotoneChain* mc = (*segChains)[i];
mc->setId( processCounter++ );
- monoChains->push_back(mc);
+ monoChains.push_back(mc);
@@ -94,7 +94,7 @@
MCIndexSegmentSetMutualIntersector::MCIndexSegmentSetMutualIntersector()
-: monoChains( new std::vector<index::chain::MonotoneChain *>()),
+: monoChains(),
index(new geos::index::strtree::STRtree()),
indexCounter(0),
processCounter(0),
@@ -105,7 +105,6 @@
MCIndexSegmentSetMutualIntersector::~MCIndexSegmentSetMutualIntersector()
delete index;
- delete monoChains;
chainstore_mm_type::iterator end = chainStore.end();
for (chainstore_mm_type::iterator it = chainStore.begin(); it != end; ++it)
@@ -138,7 +137,7 @@
processCounter = indexCounter + 1;
nOverlaps = 0;
- monoChains->clear();
+ monoChains.clear();
for (std::size_t i = 0, n = segStrings->size(); i < n; i++)
More information about the geos-commits
