[geos-commits] r2754 - in trunk: build/msvc90/geos_c_dll
build/msvc90/geos_lib build/msvc90/geos_unit
build/msvc90/geos_xmltester source/geom
source/headers/geos/simplify source/io source/linearref
svn_geos at osgeo.org
Mon Nov 30 08:55:15 EST 2009
Author: mloskot
Date: 2009-11-30 08:55:12 -0500 (Mon, 30 Nov 2009)
New Revision: 2754
trunk/build/msvc90/geos_c_dll/geos_c_dll.vcproj
trunk/build/msvc90/geos_lib/geos_lib.vcproj
trunk/build/msvc90/geos_unit/geos_unit.vcproj
trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj
trunk/source/geom/GeometryCollection.cpp
trunk/source/headers/geos/simplify/TopologyPreservingSimplifier.h
trunk/source/io/WKTReader.cpp
trunk/source/linearref/ExtractLineByLocation.cpp
* Fixed incomplete types Geometry and TaggedLinesSimplifier in TopologyPreservingSimplifier.h - required by std::auto_ptr
* Removed unreachable code.
* Removed /Wp64 option from Visual Studio 2008 projects.
Modified: trunk/build/msvc90/geos_c_dll/geos_c_dll.vcproj
--- trunk/build/msvc90/geos_c_dll/geos_c_dll.vcproj 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/build/msvc90/geos_c_dll/geos_c_dll.vcproj 2009-11-30 13:55:12 UTC (rev 2754)
@@ -48,7 +48,7 @@
RuntimeLibrary="3"
UsePrecompiledHeader="0"
WarningLevel="3"
- Detect64BitPortabilityProblems="true"
+ Detect64BitPortabilityProblems="false"
DebugInformationFormat="4"
<Tool
@@ -123,7 +123,7 @@
RuntimeLibrary="2"
WarningLevel="3"
DebugInformationFormat="3"
<Tool
Modified: trunk/build/msvc90/geos_lib/geos_lib.vcproj
--- trunk/build/msvc90/geos_lib/geos_lib.vcproj 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/build/msvc90/geos_lib/geos_lib.vcproj 2009-11-30 13:55:12 UTC (rev 2754)
@@ -51,7 +51,7 @@
BrowseInformation="0"
WarningLevel="4"
<Tool
@@ -113,7 +113,7 @@
RuntimeLibrary="2"
WarningLevel="3"
DebugInformationFormat="0"
<Tool
Modified: trunk/build/msvc90/geos_unit/geos_unit.vcproj
--- trunk/build/msvc90/geos_unit/geos_unit.vcproj 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/build/msvc90/geos_unit/geos_unit.vcproj 2009-11-30 13:55:12 UTC (rev 2754)
@@ -48,7 +48,7 @@
RuntimeLibrary="3"
WarningLevel="3"
<Tool
@@ -125,7 +125,7 @@
RuntimeLibrary="2"
WarningLevel="3"
<Tool
Modified: trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj
--- trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj 2009-11-30 13:55:12 UTC (rev 2754)
@@ -48,7 +48,7 @@
RuntimeLibrary="3"
WarningLevel="3"
<Tool
@@ -124,7 +124,7 @@
RuntimeLibrary="2"
WarningLevel="3"
<Tool
Modified: trunk/source/geom/GeometryCollection.cpp
--- trunk/source/geom/GeometryCollection.cpp 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/source/geom/GeometryCollection.cpp 2009-11-30 13:55:12 UTC (rev 2754)
@@ -160,9 +160,6 @@
GeometryCollection::getBoundary() const
throw util::IllegalArgumentException("Operation not supported by GeometryCollection\n");
- checkNotGeometryCollection(this);
- abort(); // never reached...
- return false;
bool
Modified: trunk/source/headers/geos/simplify/TopologyPreservingSimplifier.h
--- trunk/source/headers/geos/simplify/TopologyPreservingSimplifier.h 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/source/headers/geos/simplify/TopologyPreservingSimplifier.h 2009-11-30 13:55:12 UTC (rev 2754)
@@ -25,20 +25,12 @@
#define _GEOS_SIMPLIFY_TOPOLOGYPRESERVINGSIMPLIFIER_H_
#include <geos/export.h>
+#include <geos/geom/Geometry.h>
+#include <geos/simplify/TaggedLinesSimplifier.h>
#include <memory> // for auto_ptr
#include <map>
-// Forward declarations
namespace geos {
- namespace simplify {
- class TaggedLinesSimplifier;
- namespace geom {
- class Geometry;
-namespace geos {
namespace simplify { // geos::simplify
/** \brief
Modified: trunk/source/io/WKTReader.cpp
--- trunk/source/io/WKTReader.cpp 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/source/io/WKTReader.cpp 2009-11-30 13:55:12 UTC (rev 2754)
@@ -332,7 +332,6 @@
err << endl;
throw ParseException(err.str());
- return NULL;
Modified: trunk/source/linearref/ExtractLineByLocation.cpp
--- trunk/source/linearref/ExtractLineByLocation.cpp 2009-11-30 12:25:26 UTC (rev 2753)
+++ trunk/source/linearref/ExtractLineByLocation.cpp 2009-11-30 13:55:12 UTC (rev 2754)
@@ -81,6 +81,7 @@
else
assert(!"non-linear geometry encountered");
+ return 0;
More information about the geos-commits
