[geos-commits] r2642 - trunk/source/operation/buffer
svn_geos at osgeo.org
Thu Oct 1 02:33:43 EDT 2009
Author: strk
Date: 2009-10-01 02:33:41 -0400 (Thu, 01 Oct 2009)
New Revision: 2642
trunk/source/operation/buffer/BufferBuilder.cpp
Use snapped intersection between full buffer boundary and single-sided offset curves
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp 2009-09-30 22:18:38 UTC (rev 2641)
+++ trunk/source/operation/buffer/BufferBuilder.cpp 2009-10-01 06:33:41 UTC (rev 2642)
@@ -19,8 +19,6 @@
-#include <geos/operation/overlay/PolygonBuilder.h>
-#include <geos/operation/overlay/OverlayNodeFactory.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Location.h>
#include <geos/geom/Geometry.h>
@@ -34,6 +32,9 @@
#include <geos/operation/buffer/BufferSubgraph.h>
#include <geos/operation/buffer/SubgraphDepthLocater.h>
#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/operation/overlay/snap/SnapOverlayOp.h>
+#include <geos/operation/overlay/PolygonBuilder.h>
+#include <geos/operation/overlay/OverlayNodeFactory.h>
#include <geos/operation/linemerge/LineMerger.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/noding/IntersectionAdder.h>
@@ -137,7 +138,7 @@
#ifdef GEOS_DEBUG_SSB
std::cerr << "input|" << *l << std::endl;
- std::cerr << "fullBufferBoundary|" << *buf << std::endl;
+ std::cerr << "buffer|" << *bufLineString << std::endl;
#endif
// Then, get the raw (i.e. unnoded) single sided offset curve.
@@ -167,18 +168,23 @@
Geometry* tmp = geomFact->createLineString(
( *nodedEdges )[i]->getCoordinates() );
-#ifdef GEOS_DEBUG_SSB
- std::cerr << "nodedEdge" << i << "|" << *tmp << std::endl;
-#endif
singleSidedNodedEdges->push_back( tmp );
Geometry* singleSided = geomFact->createMultiLineString(
singleSidedNodedEdges );
+#ifdef GEOS_DEBUG_SSB
+ std::cerr << "edges|" << *singleSided << std::endl;
+#endif
// Use the boolean operation intersect to obtain the line segments lying
// on both the butt-cap buffer and this multi-line.
- Geometry* intersectedLines = singleSided->intersection( bufLineString );
+ //Geometry* intersectedLines = singleSided->intersection( bufLineString );
+ // NOTE: we use Snapped overlay because the actual buffer boundary might
+ // diverge from original offset curves due to the addition of
+ // intersections with caps and joins curves
+ using geos::operation::overlay::snap::SnapOverlayOp;
+ Geometry* intersectedLines = SnapOverlayOp::overlayOp(*singleSided, *bufLineString, OverlayOp::opINTERSECTION).release();
std::cerr << "intersection" << "|" << *intersectedLines << std::endl;
More information about the geos-commits
