[geos-commits] r2653 - trunk/source/operation/buffer
svn_geos at osgeo.org
Mon Oct 5 12:58:39 EDT 2009
Author: strk
Date: 2009-10-05 12:58:38 -0400 (Mon, 05 Oct 2009)
New Revision: 2653
trunk/source/operation/buffer/BufferBuilder.cpp
Plug some memory leaks in single sided buffering implementation
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp 2009-10-05 16:44:39 UTC (rev 2652)
+++ trunk/source/operation/buffer/BufferBuilder.cpp 2009-10-05 16:58:38 UTC (rev 2653)
@@ -154,8 +154,11 @@
// Then, get the raw (i.e. unnoded) single sided offset curve.
OffsetCurveBuilder curveBuilder( precisionModel, modParams );
std::vector< CoordinateSequence* > lineList;
- curveBuilder.getSingleSidedLineCurve( g->getCoordinates(), distance,
+ std::auto_ptr< CoordinateSequence > coords ( g->getCoordinates() );
+ curveBuilder.getSingleSidedLineCurve( coords.get(), distance,
lineList, leftSide, !leftSide );
+ coords.reset();
// Create a SegmentString from these coordinates.
SegmentString::NonConstVect curveList;
@@ -168,18 +171,19 @@
// Node these SegmentStrings.
Noder* noder = getNoder( precisionModel );
noder->computeNodes( &curveList );
- SegmentString::NonConstVect* nodedEdges = noder->getNodedSubstrings();
+ std::auto_ptr< SegmentString::NonConstVect > nodedEdges ( noder->getNodedSubstrings() );
// Create a geometry out of the noded substrings.
std::vector< Geometry* >* singleSidedNodedEdges =
new std::vector< Geometry * >();
- for ( unsigned int i = 0; i < nodedEdges->size(); ++i )
+ for ( unsigned int i = 0, n = nodedEdges->size(); i < n; ++i )
Geometry* tmp = geomFact->createLineString(
( *nodedEdges )[i]->getCoordinates() );
singleSidedNodedEdges->push_back( tmp );
+ nodedEdges.reset();
Geometry* singleSided = geomFact->createMultiLineString(
singleSidedNodedEdges );
@@ -203,7 +207,8 @@
// Merge result lines together.
LineMerger lineMerge;
lineMerge.add( intersectedLines );
- std::vector< LineString* >* mergedLines = lineMerge.getMergedLineStrings();
+ std::auto_ptr< std::vector< LineString* > > mergedLines (
+ lineMerge.getMergedLineStrings() );
// Convert the result into a std::vector< Geometry* >.
std::vector< Geometry* >* mergedLinesGeom = new std::vector< Geometry* >();
More information about the geos-commits
