[geos-commits] r2655 - in trunk/source:
headers/geos/operation/buffer operation/buffer
svn_geos at osgeo.org
Mon Oct 5 14:40:13 EDT 2009
Author: strk
Date: 2009-10-05 14:40:11 -0400 (Mon, 05 Oct 2009)
New Revision: 2655
trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp
Document more memory management issues
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-10-05 17:20:45 UTC (rev 2654)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveBuilder.h 2009-10-05 18:40:11 UTC (rev 2655)
@@ -83,8 +83,9 @@
* Lines are assumed to <b>not</b> be closed (the function will not
* fail for closed lines, but will generate superfluous line caps).
- * @param lineList the std::vector to which CoordinateSequences will
- * be pushed_back
+ * @param lineList the std::vector to which the newly created
+ * CoordinateSequences will be pushed_back.
+ * Caller is responsible to delete these new elements.
void getLineCurve(const geom::CoordinateSequence* inputPts,
double distance,
Modified: trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
--- trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h 2009-10-05 17:20:45 UTC (rev 2654)
+++ trunk/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h 2009-10-05 18:40:11 UTC (rev 2655)
@@ -83,12 +83,14 @@
* Creates a noding::SegmentString for a coordinate list which is a raw
* offset curve, and adds it to the list of buffer curves.
- * The noding::SegmentString is tagged with a geomgraph::Label giving the topology
- * of the curve.
+ * The noding::SegmentString is tagged with a geomgraph::Label
+ * giving the topology of the curve.
* The curve may be oriented in either direction.
* If the curve is oriented CW, the locations will be:
* - Left: Location.EXTERIOR
* - Right: Location.INTERIOR
+ * @param coord is raw offset curve, ownership transferred here
void addCurve(geom::CoordinateSequence *coord, int leftLoc,
int rightLoc);
@@ -182,6 +184,10 @@
std::vector<noding::SegmentString*>& getCurves();
/// Add raw curves for a set of CoordinateSequences
+ /// @param lineList is a list of CoordinateSequence, ownership
+ /// of which is transferred here.
void addCurves(const std::vector<geom::CoordinateSequence*>& lineList,
int leftLoc, int rightLoc);
Modified: trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp 2009-10-05 17:20:45 UTC (rev 2654)
+++ trunk/source/operation/buffer/OffsetCurveSetBuilder.cpp 2009-10-05 18:40:11 UTC (rev 2655)
@@ -70,8 +70,9 @@
for (size_t i=0, n=curveList.size(); i<n; ++i)
- delete curveList[i]->getCoordinates();
- delete curveList[i];
+ SegmentString* ss = curveList[i];
+ delete ss->getCoordinates();
+ delete ss;
for (size_t i=0, n=newLabels.size(); i<n; ++i)
delete newLabels[i];
@@ -92,7 +93,7 @@
for (size_t i=0, n=lineList.size(); i<n; ++i)
- CoordinateSequence *coords=lineList[i];
+ CoordinateSequence *coords = lineList[i];
addCurve(coords, leftLoc, rightLoc);
More information about the geos-commits
