[geos-commits] r2672 - trunk/tests/xmltester
svn_geos at osgeo.org
Wed Oct 14 08:03:38 EDT 2009
Author: mloskot
Date: 2009-10-14 08:03:37 -0400 (Wed, 14 Oct 2009)
New Revision: 2672
trunk/tests/xmltester/XMLTester.cpp
Enable use of Stalkwalker only if building with Visual C++ and GEOS_TEST_USE_STACKWALKER is defined.
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-10-13 16:25:42 UTC (rev 2671)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-10-14 12:03:37 UTC (rev 2672)
@@ -63,7 +63,7 @@
#include <cmath>
#include <stdexcept>
-#ifdef _MSC_VER
+#if defined(_MSC_VER) && defined(GEOS_TEST_USE_STACKWALKER)
#include <windows.h>
#include "Stackwalker.h"
#endif
@@ -1404,7 +1404,7 @@
int verbose=0;
bool sql_output=false;
-#ifdef _MSC_VER
InitAllocCheck();
#endif
@@ -1457,7 +1457,7 @@
return tester.getFailuresCount();
-#ifdef _MSC_VER
DeInitAllocCheck();
#endif
More information about the geos-commits
