[geos-commits] r2675 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Oct 14 16:42:57 EDT 2009
Author: strk
Date: 2009-10-14 16:42:56 -0400 (Wed, 14 Oct 2009)
New Revision: 2675
   trunk/ChangeLog
regenerate ChangeLog
Modified: trunk/ChangeLog
--- trunk/ChangeLog	2009-10-14 15:32:06 UTC (rev 2674)
+++ trunk/ChangeLog	2009-10-14 20:42:56 UTC (rev 2675)
@@ -1,9 +1,65 @@
-2009-10-13  Frank Warmerdam  <warmerdam at pobox.com>
+2009-10-14 15:32  Mateusz Loskot <mateusz at loskot.net>
-	* r[2670] Fix nmake DLL export and test linking (#280)
+	* [r2674] build/msvc90/geos_unit/geos_unit.vcproj,
+	  build/msvc90/geos_xmltester/geos_xmltester.vcproj,
+	  tests/xmltester/XMLTester.cpp, tests/xmltester/makefile.vc: *
+	  Optional use of GEOS_DEBUG_MSVC_USE_VLD in XMLTester.cpp
+	  * Added xmltester/makefile.vc as port of testrunner.sh for
+	  Windows to be able to run all tests in batch:
+	  ** nmake /f makefile.vc XMLTESTER=C:\path\to\xmltester.exe
-	* [r2669] Add new directory and source to nmakefiles (#288)
+2009-10-14 12:05  Mateusz Loskot <mateusz at loskot.net>
+	* [r2673] build/msvc90/geos.sln, build/msvc90/geos_xmltester,
+	  build/msvc90/geos_xmltester/geos_xmltester.vcproj: Added
+	  msvc90/geos_xmltester to solution for Visual Studio 2008.
+2009-10-14 12:03  Mateusz Loskot <mateusz at loskot.net>
+	* [r2672] tests/xmltester/XMLTester.cpp: Enable use of Stalkwalker
+	  only if building with Visual C++ and GEOS_TEST_USE_STACKWALKER is
+	  defined.
+2009-10-13 16:25  Mateusz Loskot <mateusz at loskot.net>
+	* [r2671] build/msvc90/geos_lib/geos_lib.vcproj: build/msvc90:
+	  added missing sources of linearref package. Builds with Visual
+	  C++ 9.0 (using both project and makefiles).
+2009-10-13 14:20  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2670] ChangeLog, capi/geos_c.h.in, nmake.opt,
+	  source/Makefile.vc: fix nmake dll export, and link test programs
+	  (#288)
+2009-10-08 12:51  Frank Warmerdam <warmerdam at pobox.com>
+	* [r2669] source/Makefile.vc, source/dirlist.mk: add new
+	  directories and source (#288)
+2009-10-08 08:56  Sandro Santilli <strk at keybit.net>
+	* [r2668] ChangeLog: regenerate ChangeLog now that we have all
+	  names in
+2009-10-08 08:47  Sandro Santilli <strk at keybit.net>
+	* [r2667] authors.svn: Add other missing names/addresses
+2009-10-08 08:40  Sandro Santilli <strk at keybit.net>
+	* [r2666] ChangeLog, ChangeLog.svn, Makefile.am: Automatically
+	  generate the ChangeLog file, forget ChangeLog.svn.
+2009-10-08 08:38  Sandro Santilli <strk at keybit.net>
+	* [r2665] source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp:
+	  Don't signal topology exception when it triggers snapping
+2009-10-08 08:37  Sandro Santilli <strk at keybit.net>
+	* [r2664] authors.svn: Add yury, fernando and sean
 2009-10-08 08:17  Sandro Santilli <strk at keybit.net>
 	* [r2663] tests/unit/Makefile.am: Distribute all of TUT
More information about the geos-commits mailing list
