[geos-commits] r2684 - in trunk: . build/msvc90/geos_xmltester
tests/xmltester/tests
svn_geos at osgeo.org
Mon Oct 19 09:38:37 EDT 2009
Author: mloskot
Date: 2009-10-19 09:38:36 -0400 (Mon, 19 Oct 2009)
New Revision: 2684
trunk/ChangeLog
trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj
trunk/tests/xmltester/tests/buffer_snapround.xml
tests/xmltester/tests/buffer_snapround.xml: not well-formed XML, fixed missing attribute.
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2009-10-17 14:47:00 UTC (rev 2683)
+++ trunk/ChangeLog 2009-10-19 13:38:36 UTC (rev 2684)
@@ -1,3 +1,8 @@
+2009-10-19 14:47 Mateusz Loskot <mateusz at loskot.net>
+ * [r2684] tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
+ fixed missing attribute.
2009-10-16 15:27 Mateusz Loskot <mateusz at loskot.net>
* [r2676] tests/xmltester/tests/fme.xml: xmltester/tests: missing
Modified: trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj
--- trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj 2009-10-17 14:47:00 UTC (rev 2683)
+++ trunk/build/msvc90/geos_xmltester/geos_xmltester.vcproj 2009-10-19 13:38:36 UTC (rev 2684)
@@ -91,7 +91,6 @@
<Tool
Name="VCPostBuildEventTool"
- Description=""
CommandLine=""
</Configuration>
@@ -168,7 +167,6 @@
<Tool
- Description=""
CommandLine=""
</Configuration>
@@ -493,10 +491,6 @@
</File>
<File
- RelativePath="..\..\..\tests\xmltester\testrunner.bat"
- </File>
- <File
RelativePath="..\..\..\tests\xmltester\XMLTester.cpp"
</File>
Modified: trunk/tests/xmltester/tests/buffer_snapround.xml
--- trunk/tests/xmltester/tests/buffer_snapround.xml 2009-10-17 14:47:00 UTC (rev 2683)
+++ trunk/tests/xmltester/tests/buffer_snapround.xml 2009-10-19 13:38:36 UTC (rev 2684)
@@ -1,5 +1,5 @@
<run>
-<precisionModel FLOATING />
+<precisionModel type="FLOATING" />
<case><desc>Case #</desc>
<a>
MULTILINESTRING (
More information about the geos-commits
