[geos-commits] r2689 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Thu Oct 22 14:18:38 EDT 2009
Author: strk
Date: 2009-10-22 14:18:38 -0400 (Thu, 22 Oct 2009)
New Revision: 2689
Removed:
   trunk/tests/xmltester/tests/buffer_snapround.xml
   trunk/tests/xmltester/tests/buffer.xml
Merge buffer_snapround.xml into buffer.xml
Modified: trunk/tests/xmltester/tests/buffer.xml
--- trunk/tests/xmltester/tests/buffer.xml	2009-10-22 17:13:19 UTC (rev 2688)
+++ trunk/tests/xmltester/tests/buffer.xml	2009-10-22 18:18:38 UTC (rev 2689)
@@ -317,4 +317,47 @@
 </op>
 </test>
 </case>
+<case><desc>Case #32 (previously in buffer_snapround.xml)</desc>
+<a>
+MULTILINESTRING (
+( 85.5939933259177 234.65406006674084, 251 233, 344.3694502052736 126.0884157954882 ),
+( 344.3694502052736 126.0884157954882, 382 83 ))
+</a>
+<test>
+<op name="buffer" arg1="A" arg2="30">
+POLYGON ((251.2999850011249 262.9985001124906, 257.5681863594468
+262.27215277268783, 263.54579707741004 260.25074266313584,
+268.9683548466559 257.0237012990225, 273.5959540907721 252.733799905941,
+366.9654042960458 145.8222157014292, 366.96540429604596
+145.822215701429, 404.5959540907721 102.73379990594101,
+408.01165254714834 97.94636851433921, 410.42773778364045
+92.58455656275139,
+    411.75136099956626 86.85441547753827, 411.93165609703425
+80.97615136710445, 410.9616944365593 75.17566262464543,
+408.8787511007927 69.67585877958233, 405.762872434 64.6880942093554,
+401.733799905941 60.40404590922786, 396.9463685143392 56.98834745285165,
+391.5845565627514 54.57226221635955, 385.8544154775383
+53.24863900043373, 379.9761513671045 53.068343902965765,
+    374.17566262464544 54.0383055634407, 368.6758587795823
+56.12124889920727, 363.68809420935537 59.23712756600002,
+359.4040459092279 63.26620009405899, 321.77349611450177
+106.35461588954689, 321.7734961145014 106.35461588954719,
+237.25109687130038 203.1359890687851, 85.29400832479278
+204.6555599542502, 85.29400832479277 204.6555599542502,
+79.44735540552597 205.29049689270485,
+    73.83691433446558 207.05385909666174, 68.67829121560081
+209.87788154552774, 64.16972904240048 213.654038640323, 60.4844893307499
+218.23721478158777, 57.764193776061546 223.45128108048806,
+56.11338181094277 229.09586389323925, 55.59549321342706
+234.95404506786576, 56.230430151881706 240.80069798713257,
+57.99379235583859 246.41113905819296, 60.81781480470461
+251.56976217705773,
+    64.59397189949983 256.0783243502581, 69.1771480407646
+259.7635640619086, 74.39121433966491 262.483859616597, 80.03579715241607
+264.13467158171574, 85.89397832704257 264.65256017923144,
+85.8939783270426 264.65256017923144, 251.2999850011249
+262.9985001124906))
+</op>
+</test>
+</case>
 </run>
Deleted: trunk/tests/xmltester/tests/buffer_snapround.xml
--- trunk/tests/xmltester/tests/buffer_snapround.xml	2009-10-22 17:13:19 UTC (rev 2688)
+++ trunk/tests/xmltester/tests/buffer_snapround.xml	2009-10-22 18:18:38 UTC (rev 2689)
@@ -1,46 +0,0 @@
-<run>
-<precisionModel type="FLOATING" />
-<case><desc>Case #</desc>
-<a>
-MULTILINESTRING (
-( 85.5939933259177 234.65406006674084, 251 233, 344.3694502052736 126.0884157954882 ),
-( 344.3694502052736 126.0884157954882, 382 83 ))
-</a>
-<test>
-<op name="buffer" arg1="A" arg2="30">
-POLYGON ((251.2999850011249 262.9985001124906, 257.5681863594468
-262.27215277268783, 263.54579707741004 260.25074266313584,
-268.9683548466559 257.0237012990225, 273.5959540907721 252.733799905941,
-366.9654042960458 145.8222157014292, 366.96540429604596
-145.822215701429, 404.5959540907721 102.73379990594101,
-408.01165254714834 97.94636851433921, 410.42773778364045
-92.58455656275139,
-    411.75136099956626 86.85441547753827, 411.93165609703425
-80.97615136710445, 410.9616944365593 75.17566262464543,
-408.8787511007927 69.67585877958233, 405.762872434 64.6880942093554,
-401.733799905941 60.40404590922786, 396.9463685143392 56.98834745285165,
-391.5845565627514 54.57226221635955, 385.8544154775383
-53.24863900043373, 379.9761513671045 53.068343902965765,
-    374.17566262464544 54.0383055634407, 368.6758587795823
-56.12124889920727, 363.68809420935537 59.23712756600002,
-359.4040459092279 63.26620009405899, 321.77349611450177
-106.35461588954689, 321.7734961145014 106.35461588954719,
-237.25109687130038 203.1359890687851, 85.29400832479278
-204.6555599542502, 85.29400832479277 204.6555599542502,
-79.44735540552597 205.29049689270485,
-    73.83691433446558 207.05385909666174, 68.67829121560081
-209.87788154552774, 64.16972904240048 213.654038640323, 60.4844893307499
-218.23721478158777, 57.764193776061546 223.45128108048806,
-56.11338181094277 229.09586389323925, 55.59549321342706
-234.95404506786576, 56.230430151881706 240.80069798713257,
-57.99379235583859 246.41113905819296, 60.81781480470461
-251.56976217705773,
-    64.59397189949983 256.0783243502581, 69.1771480407646
-259.7635640619086, 74.39121433966491 262.483859616597, 80.03579715241607
-264.13467158171574, 85.89397832704257 264.65256017923144,
-85.8939783270426 264.65256017923144, 251.2999850011249
-262.9985001124906))
-</op>
-</test>
-</case>
-</run>
More information about the geos-commits mailing list
