[geos-commits] r2699 - in trunk/source: headers/geos/linearref
linearref
svn_geos at osgeo.org
Fri Oct 23 08:58:49 EDT 2009
Author: strk
Date: 2009-10-23 08:58:48 -0400 (Fri, 23 Oct 2009)
New Revision: 2699
trunk/source/headers/geos/linearref/LinearLocation.h
trunk/source/linearref/LinearLocation.cpp
Fix port info, add standard protection notes
Modified: trunk/source/headers/geos/linearref/LinearLocation.h
--- trunk/source/headers/geos/linearref/LinearLocation.h 2009-10-23 10:21:15 UTC (rev 2698)
+++ trunk/source/headers/geos/linearref/LinearLocation.h 2009-10-23 12:58:48 UTC (rev 2699)
@@ -27,14 +27,13 @@
#include <geos/geom/Geometry.h>
#include <geos/geom/LineSegment.h>
-namespace geos
-namespace linearref // geos::linearref
+namespace geos {
+namespace linearref { // geos::linearref
+/** \brief
* Represents a location along a {@link LineString} or {@link MultiLineString}.
* The referenced geometry is not maintained within
* this location, but must be provided for operations which require it.
* Various methods are provided to manipulate the location value
@@ -71,8 +70,8 @@
* point of the segment is returned.
* If the fraction is less than or equal to 0.0 the first point
* of the segment is returned.
- * The Z ordinate is interpolated from the Z-ordinates of the given points,
- * if they are specified.
+ * The Z ordinate is interpolated from the Z-ordinates of
+ * the given points, if they are specified.
* @param p0 the first point of the line segment
* @param p1 the last point of the line segment
@@ -85,7 +84,6 @@
* Creates a location referring to the start of a linear geometry
LinearLocation(unsigned int segmentIndex = 0, double segmentFraction = 0.0);
LinearLocation(unsigned int componentIndex, unsigned int segmentIndex, double segmentFraction);
@@ -115,6 +113,7 @@
* @return the length of the segment
double getSegmentLength(const geom::Geometry* linearGeom) const;
* Sets the value of this location to
* refer the end of a linear geometry
@@ -232,7 +231,7 @@
+} // namespace geos.linearref
#endif
Modified: trunk/source/linearref/LinearLocation.cpp
--- trunk/source/linearref/LinearLocation.cpp 2009-10-23 10:21:15 UTC (rev 2698)
+++ trunk/source/linearref/LinearLocation.cpp 2009-10-23 12:58:48 UTC (rev 2699)
@@ -14,7 +14,7 @@
- * Last port: linearref/LinearLocation.java rev. 1.35
+ * Last port: linearref/LinearLocation.java rev. 1.10
@@ -27,12 +27,12 @@
using namespace geos::geom;
-namespace geos
-namespace linearref // geos.linearref
+namespace geos {
-LinearLocation LinearLocation::getEndLocation(const Geometry* linear)
+/* public static */
+LinearLocation
+LinearLocation::getEndLocation(const Geometry* linear)
// assert: linear is LineString or MultiLineString
LinearLocation loc;
@@ -40,7 +40,9 @@
return loc;
-Coordinate LinearLocation::pointAlongSegmentByFraction(const Coordinate& p0, const Coordinate& p1, double frac)
+Coordinate
+LinearLocation::pointAlongSegmentByFraction(const Coordinate& p0, const Coordinate& p1, double frac)
if (frac <= 0.0) return p0;
if (frac >= 1.0) return p1;
@@ -52,17 +54,30 @@
return Coordinate(x, y, z);
-LinearLocation::LinearLocation(unsigned int segmentIndex, double segmentFraction) :
- componentIndex(0), segmentIndex(segmentIndex), segmentFraction(segmentFraction) {}
+/* public */
+LinearLocation::LinearLocation(unsigned int segmentIndex,
+ double segmentFraction)
+ componentIndex(0),
+ segmentIndex(segmentIndex),
+ segmentFraction(segmentFraction)
-LinearLocation::LinearLocation(unsigned int componentIndex, unsigned int segmentIndex, double segmentFraction):
- componentIndex(componentIndex), segmentIndex(segmentIndex), segmentFraction(segmentFraction)
+/* public */
+LinearLocation::LinearLocation(unsigned int componentIndex,
+ unsigned int segmentIndex, double segmentFraction)
+ componentIndex(componentIndex),
normalize();
-void LinearLocation::normalize()
+/* private */
+void
+LinearLocation::normalize()
if (segmentFraction < 0.0)
@@ -91,9 +106,9 @@
-void LinearLocation::clamp(const Geometry* linear)
+/* public */
+void
+LinearLocation::clamp(const Geometry* linear)
if (componentIndex >= linear->getNumGeometries())
@@ -108,7 +123,9 @@
-void LinearLocation::snapToVertex(const Geometry* linearGeom, double minDistance)
+/* public */
+void
+LinearLocation::snapToVertex(const Geometry* linearGeom, double minDistance)
if (segmentFraction <= 0.0 || segmentFraction >= 1.0)
return;
@@ -125,7 +142,9 @@
-double LinearLocation::getSegmentLength(const Geometry* linearGeom) const
+/* public */
+double
+LinearLocation::getSegmentLength(const Geometry* linearGeom) const
const LineString* lineComp = dynamic_cast<const LineString*> (linearGeom->getGeometryN(componentIndex));
@@ -139,7 +158,9 @@
return p0.distance(p1);
-void LinearLocation::setToEnd(const Geometry* linear)
+/* public */
+void
+LinearLocation::setToEnd(const Geometry* linear)
componentIndex = linear->getNumGeometries() - 1;
const LineString* lastLine = dynamic_cast<const LineString*>(linear->getGeometryN(componentIndex));
@@ -147,27 +168,37 @@
segmentFraction = 1.0;
-unsigned int LinearLocation::getComponentIndex() const
+/* public */
+unsigned int
+LinearLocation::getComponentIndex() const
return componentIndex;
-unsigned int LinearLocation::getSegmentIndex() const
+/* public */
+unsigned int
+LinearLocation::getSegmentIndex() const
return segmentIndex;
-double LinearLocation::getSegmentFraction() const
+/* public */
+double
+LinearLocation::getSegmentFraction() const
return segmentFraction;
-bool LinearLocation::isVertex() const
+/* public */
+bool
+LinearLocation::isVertex() const
return segmentFraction <= 0.0 || segmentFraction >= 1.0;
-Coordinate LinearLocation::getCoordinate(const Geometry* linearGeom) const
+/* public */
+Coordinate
+LinearLocation::getCoordinate(const Geometry* linearGeom) const
const LineString* lineComp = dynamic_cast<const LineString *> (linearGeom->getGeometryN(componentIndex));
Coordinate p0 = lineComp->getCoordinateN(segmentIndex);
@@ -177,7 +208,9 @@
return pointAlongSegmentByFraction(p0, p1, segmentFraction);
-LineSegment* LinearLocation::getSegment(const Geometry* linearGeom) const
+/* public */
+LineSegment*
+LinearLocation::getSegment(const Geometry* linearGeom) const
@@ -191,8 +224,9 @@
return new LineSegment(p0, p1);
-bool LinearLocation::isValid(const Geometry* linearGeom) const
+/* public */
+bool
+LinearLocation::isValid(const Geometry* linearGeom) const
if (componentIndex < 0 || componentIndex >= linearGeom->getNumGeometries())
return false;
@@ -208,8 +242,9 @@
return true;
-int LinearLocation::compareTo(const LinearLocation& other) const
+/* public */
+int
+LinearLocation::compareTo(const LinearLocation& other) const
// compare component indices
if (componentIndex < other.componentIndex) return -1;
@@ -224,8 +259,10 @@
return 0;
-int LinearLocation::compareLocationValues(unsigned int componentIndex1, unsigned int segmentIndex1, double segmentFraction1) const
+/* public */
+int
+LinearLocation::compareLocationValues(unsigned int componentIndex1,
+ unsigned int segmentIndex1, double segmentFraction1) const
if (componentIndex < componentIndex1) return -1;
@@ -241,9 +278,13 @@
- unsigned int componentIndex0, unsigned int segmentIndex0, double segmentFraction0,
- unsigned int componentIndex1, unsigned int segmentIndex1, double segmentFraction1)
+/* public */
+int
+ unsigned int componentIndex0, unsigned int segmentIndex0,
+ double segmentFraction0,
+ unsigned int componentIndex1, unsigned int segmentIndex1,
+ double segmentFraction1)
if (componentIndex0 < componentIndex1) return -1;
@@ -259,7 +300,9 @@
-bool LinearLocation::isOnSameSegment(const LinearLocation& loc) const
+/* public */
+bool
+LinearLocation::isOnSameSegment(const LinearLocation& loc) const
if (componentIndex != loc.componentIndex) return false;
if (segmentIndex == loc.segmentIndex) return true;
@@ -279,6 +322,6 @@
obj.segmentIndex << ", " << obj.segmentFraction << ")";
More information about the geos-commits
