[geos-commits] r2624 - trunk/capi
svn_geos at osgeo.org
Fri Sep 11 14:47:34 EDT 2009
Author: pramsey
Date: 2009-09-11 14:47:32 -0400 (Fri, 11 Sep 2009)
New Revision: 2624
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
Patch for #285, C api for project and interpolate, from David Turner (novalis)
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2009-08-21 09:54:58 UTC (rev 2623)
+++ trunk/capi/geos_c.cpp 2009-09-11 18:47:32 UTC (rev 2624)
@@ -883,4 +883,33 @@
GEOSSTRtree_destroy_r( handle, tree );
+double
+GEOSProject (const geos::geom::Geometry *g,
+ const geos::geom::Geometry *p)
+ return GEOSProject_r (handle, g, p);
+geos::geom::Geometry *
+GEOSInterpolate (const geos::geom::Geometry *g,
+ double d)
+ return GEOSInterpolate_r(handle, g, d);
+double
+GEOSProjectNormalized (const geos::geom::Geometry *g,
+ return GEOSProjectNormalized_r (handle, g, p);
+GEOSInterpolateNormalized (const geos::geom::Geometry *g,
+ double d)
+ return GEOSInterpolateNormalized_r(handle, g, d);
} /* extern "C" */
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2009-08-21 09:54:58 UTC (rev 2623)
+++ trunk/capi/geos_c.h.in 2009-09-11 18:47:32 UTC (rev 2624)
@@ -319,6 +319,43 @@
+ * Linearref functions -- there are more, but these two are probably
+ * sufficient for most purposes
+ * GEOSGeometry ownership is retained by caller
+extern double GEOS_DLL GEOSProject(const GEOSGeometry *g,
+ const GEOSGeometry* p);
+extern double GEOS_DLL GEOSProject_r(GEOSContextHandle_t handle,
+ const GEOSGeometry *g,
+ const GEOSGeometry *p);
+extern GEOSGeometry* GEOS_DLL GEOSInterpolate(const GEOSGeometry *g,
+ double d);
+extern GEOSGeometry* GEOS_DLL GEOSInterpolate_r(GEOSContextHandle_t handle,
+ double d);
+extern double GEOS_DLL GEOSProjectNormalized(const GEOSGeometry *g,
+extern double GEOS_DLL GEOSProjectNormalized_r(GEOSContextHandle_t handle,
+extern GEOSGeometry* GEOS_DLL GEOSInterpolateNormalized(const GEOSGeometry *g,
+ double d);
+extern GEOSGeometry* GEOS_DLL GEOSInterpolateNormalized_r(
+ GEOSContextHandle_t handle,
+ double d);
* Buffer related functions
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-08-21 09:54:58 UTC (rev 2623)
+++ trunk/capi/geos_ts_c.cpp 2009-09-11 18:47:32 UTC (rev 2624)
@@ -48,6 +48,7 @@
#include <geos/operation/union/CascadedPolygonUnion.h>
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/buffer/BufferParameters.h>
+#include <geos/linearref/LengthIndexedLine.h>
#include <geos/geom/BinaryOp.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/version.h>
@@ -4299,5 +4300,64 @@
+double
+GEOSProject_r(GEOSContextHandle_t extHandle,
+ const Geometry *g,
+ const Geometry *p)
+ const geos::geom::Point* point = dynamic_cast<const geos::geom::Point*>(p);
+ if (!point) {
+ if ( 0 == extHandle )
+ return -1.0;
+ GEOSContextHandleInternal_t *handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return -1.0;
+ handle->ERROR_MESSAGE("third argument of GEOSProject_r must be Point*");
+ return -1.0;
+ const geos::geom::Coordinate* inputPt = p->getCoordinate();
+ return geos::linearref::LengthIndexedLine(g).project(*inputPt);
+Geometry*
+GEOSInterpolate_r(GEOSContextHandle_t extHandle, const Geometry *g, double d)
+ geos::linearref::LengthIndexedLine lil(g);
+ geos::geom::Coordinate coord = lil.extractPoint(d);
+ const GeometryFactory *gf = handle->geomFactory;
+ Geometry* point = gf->createPoint(coord);
+ return point;
+double
+GEOSProjectNormalized_r(GEOSContextHandle_t extHandle, const Geometry *g,
+ double length;
+ GEOSLength_r(extHandle, g, &length);
+ return GEOSProject_r(extHandle, g, p) / length;
+Geometry*
+GEOSInterpolateNormalized_r(GEOSContextHandle_t extHandle, const Geometry *g,
+ double d)
+ double length;
+ return GEOSInterpolate_r(extHandle, g, d * length);
} /* extern "C" */
More information about the geos-commits
