[geos-commits] r2968 - trunk
svn_geos at osgeo.org
Wed Apr 7 09:24:09 EDT 2010
Author: mloskot
Date: 2010-04-07 09:24:09 -0400 (Wed, 07 Apr 2010)
New Revision: 2968
trunk/nmake.opt
Added ENABLE_INLINE=YES|NO option to nmake.opt for Visual C++ builds using NMake. The ENABLE_INLINE=YES does not link for me - to be fixed
Modified: trunk/nmake.opt
--- trunk/nmake.opt 2010-04-07 13:22:56 UTC (rev 2967)
+++ trunk/nmake.opt 2010-04-07 13:24:09 UTC (rev 2968)
@@ -28,6 +28,16 @@
!MESSAGE *** Setting BUILD_DEBUG $(BUILD_DEBUG)
+# Set ENABLE_INLINE to YES if you want to make debug build
+# and to prepare not optimized binaries.
+!IFNDEF ENABLE_INLINE
+ENABLE_INLINE = NO
+!ENDIF
+!MESSAGE *** Setting ENABLE_INLINE $(ENABLE_INLINE)
# Set BUILD_BATCH to YES if you want feed compiler with all
# source .c and .cpp files in single batch.
@@ -106,7 +116,7 @@
!IF "$(BUILD_DEBUG)" == "YES"
BUILD_PREFIX=_d
GEOS_CFLAGS = /nologo /MDd /GR /Od /W4 /Zi
-GEOS_CPPFLAGS = /D "NDEBUG" $(GEOS_CPPFLAGS)
+GEOS_CPPFLAGS = /D "DEBUG" /D "_DEBUG" $(GEOS_CPPFLAGS)
!ELSE
GEOS_CFLAGS = /nologo /MD /GR /O2 /W3
@@ -128,6 +138,10 @@
!ENDIF
!ENDIF
+!IF "$(ENABLE_INLINE)" == "YES"
+GEOS_CFLAGS = /D "GEOS_INLINE"
+!ENDIF
!MESSAGE *** Using CFLAGS $(GEOS_CFLAGS)
!MESSAGE *** Using CPPFLAGS $(GEOS_CPPFLAGS)
More information about the geos-commits
