[geos-commits] r2975 - in branches/3.2: . capi source/headers/geos
tests/unit
svn_geos at osgeo.org
Sat Apr 17 17:55:55 EDT 2010
Author: strk
Date: 2010-04-17 17:55:53 -0400 (Sat, 17 Apr 2010)
New Revision: 2975
branches/3.2/NEWS
branches/3.2/capi/geos_c.cpp
branches/3.2/capi/geos_c.h.in
branches/3.2/capi/geos_ts_c.cpp
branches/3.2/configure.in
branches/3.2/source/headers/geos/version.h.vc
branches/3.2/tests/unit/Makefile.am
Back-port fix of GEOS-context leakage
Modified: branches/3.2/NEWS
--- branches/3.2/NEWS 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/NEWS 2010-04-17 21:55:53 UTC (rev 2975)
@@ -1,3 +1,8 @@
+Changes in 3.2.2-svn
+- Bug fixes:
+ - CAPI: do not leak contexts when using the non-reentrant interface
Changes in 3.2.1
- Bug fixes:
Modified: branches/3.2/capi/geos_c.cpp
--- branches/3.2/capi/geos_c.cpp 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/capi/geos_c.cpp 2010-04-17 21:55:53 UTC (rev 2975)
@@ -85,10 +85,23 @@
extern "C" {
+GEOSMessageHandler
+GEOSContext_setNoticeHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf);
+GEOSMessageHandler
+GEOSContext_setErrorHandler_r(GEOSContextHandle_t extHandle, GEOSMessageHandler nf);
void
initGEOS (GEOSMessageHandler nf, GEOSMessageHandler ef)
- handle = initGEOS_r( nf, ef );
+ if ( ! handle )
+ handle = initGEOS_r( nf, ef );
+ else
+ GEOSContext_setNoticeHandler_r(handle, nf);
+ GEOSContext_setErrorHandler_r(handle, ef);
void
Modified: branches/3.2/capi/geos_c.h.in
--- branches/3.2/capi/geos_c.h.in 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/capi/geos_c.h.in 2010-04-17 21:55:53 UTC (rev 2975)
@@ -55,8 +55,8 @@
#include <geos/version.h>
#define GEOS_CAPI_VERSION_MAJOR 1
#define GEOS_CAPI_VERSION_MINOR 6
-#define GEOS_CAPI_VERSION_PATCH 1
-#define GEOS_CAPI_VERSION "3.2.1-CAPI-1.6.1"
+#define GEOS_CAPI_VERSION_PATCH 2
+#define GEOS_CAPI_VERSION "3.2.2-CAPI-1.6.2"
#else
#ifndef GEOS_VERSION_MAJOR
#define GEOS_VERSION_MAJOR @VERSION_MAJOR@
Modified: branches/3.2/capi/geos_ts_c.cpp
--- branches/3.2/capi/geos_ts_c.cpp 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/capi/geos_ts_c.cpp 2010-04-17 21:55:53 UTC (rev 2975)
@@ -4,6 +4,7 @@
* C-Wrapper for GEOS library
+ * Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2006 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -182,6 +183,40 @@
return static_cast<GEOSContextHandle_t>(extHandle);
+GEOSMessageHandler
+ GEOSMessageHandler f;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return NULL;
+ f = handle->NOTICE_MESSAGE;
+ handle->NOTICE_MESSAGE = nf;
+ return f;
+GEOSMessageHandler
+ return NULL;
+ f = handle->ERROR_MESSAGE;
+ handle->ERROR_MESSAGE = nf;
+ return f;
void
finishGEOS_r(GEOSContextHandle_t extHandle)
Modified: branches/3.2/configure.in
--- branches/3.2/configure.in 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/configure.in 2010-04-17 21:55:53 UTC (rev 2975)
@@ -16,7 +16,7 @@
dnl -- Version info for the CAPI
CAPI_INTERFACE_CURRENT=7
-CAPI_INTERFACE_REVISION=1
+CAPI_INTERFACE_REVISION=2
CAPI_INTERFACE_AGE=6
dnl
@@ -25,7 +25,7 @@
dnl
VERSION_MAJOR=3
VERSION_MINOR=2
-VERSION_PATCH=1
+VERSION_PATCH=2
VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
dnl CAPI_VERSION_MAJOR=$(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE))
Modified: branches/3.2/source/headers/geos/version.h.vc
--- branches/3.2/source/headers/geos/version.h.vc 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/source/headers/geos/version.h.vc 2010-04-17 21:55:53 UTC (rev 2975)
@@ -35,11 +35,11 @@
#endif
#ifndef GEOS_VERSION_PATCH
-#define GEOS_VERSION_PATCH 1
+#define GEOS_VERSION_PATCH 2
#endif
-#define GEOS_VERSION "3.2.1"
+#define GEOS_VERSION "3.2.2"
#endif
#ifndef GEOS_JTS_PORT
Modified: branches/3.2/tests/unit/Makefile.am
--- branches/3.2/tests/unit/Makefile.am 2010-04-17 15:34:55 UTC (rev 2974)
+++ branches/3.2/tests/unit/Makefile.am 2010-04-17 21:55:53 UTC (rev 2975)
@@ -90,6 +90,7 @@
capi/GEOSSimplifyTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
capi/GEOSPolygonizer_getCutEdgesTest.cpp \
+ capi/GEOSGetCentroidTest.cpp \
capi/GEOSBufferTest.cpp
noinst_HEADERS = \
More information about the geos-commits
