[geos-commits] r3097 - trunk/tests/xmltester
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Aug 27 09:00:16 EDT 2010
Author: strk
Date: 2010-08-27 13:00:16 +0000 (Fri, 27 Aug 2010)
New Revision: 3097
   trunk/tests/xmltester/XMLTester.cpp
   trunk/tests/xmltester/XMLTester.h
Have --test-valid-output influence test results
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp	2010-08-27 10:22:26 UTC (rev 3096)
+++ trunk/tests/xmltester/XMLTester.cpp	2010-08-27 13:00:16 UTC (rev 3097)
@@ -492,25 +492,22 @@
-void
+bool
 XMLTester::testValid(const geom::Geometry* g, const std::string& label)
 	operation::valid::IsValidOp ivo(g);
-	bool result;
-	result = ivo.isValid();
-	if ( result == 0 )
+	bool valid = ivo.isValid();
+	if ( ! valid )
 		operation::valid::TopologyValidationError *err = ivo.getValidationError();
-		if ( err ) {
-			std::cerr << *curr_file << ":"
-			          << " case" << caseCount << ":"
-			          << " test" << testCount << ": "
-				  << opSignature << ": "
-			          << " invalid geometry (" << label
-			          << "): " << err->toString() << std::endl;
+		std::cerr << *curr_file << ":"
+			  << " case" << caseCount << ":"
+			  << " test" << testCount << ": "
+			  << opSignature << ": "
+			  << " invalid geometry (" << label
+			  << "): " << err->toString() << std::endl;
-	//return result;
+	return valid;
@@ -797,12 +794,11 @@
 			if (gRes->compareTo(gRealRes.get())==0) success=1;
-			if ( testValidOutput )
-				testValid(gRealRes.get(), "result");
 			actual_result=printGeom(gRealRes.get());
 			expected_result=printGeom(gRes.get());
+			if ( testValidOutput )
+				success &= testValid(gRealRes.get(), "result");
 		else if (opName=="union")
@@ -820,11 +816,11 @@
 		else if (opName=="difference")
@@ -843,12 +839,11 @@
 		else if (opName=="symdifference")
@@ -866,12 +861,11 @@
 		else if (opName=="intersects")
@@ -942,12 +936,11 @@
 		else if (opName=="getcentroid")
@@ -966,12 +959,11 @@
 		else if (opName=="issimple")
@@ -999,12 +991,11 @@
 		else if (opName=="buffer")
@@ -1037,11 +1028,11 @@
 			// Validate the buffer operation
 			success = checkBufferSuccess(*gRes, *gRealRes, dist);
 		else if (opName=="buffersinglesided")
@@ -1082,11 +1073,11 @@
 			success = checkSingleSidedBufferSuccess(*gRes,
 					*gRealRes, dist);
 		else if (opName=="buffermitredjoin")
@@ -1120,11 +1111,11 @@
@@ -1142,12 +1133,11 @@
 		else if (opName=="iswithindistance")
@@ -1185,12 +1175,11 @@
 		else if (opName=="linemerge")
@@ -1213,18 +1202,19 @@
 		else if (opName=="areatest")
 			char* rest;
 			double toleratedDiff = std::strtod(opRes.c_str(), &rest);
+			int validOut = 1;
 			if ( rest == opRes.c_str() )
 				throw std::runtime_error("malformed testcase: missing tolerated area difference in 'areatest' op");
@@ -1243,7 +1233,7 @@
-				testValid(gI.get(), "areatest intersection");
+				validOut &= testValid(gI.get(), "areatest intersection");
 			if ( verbose > 1 )
@@ -1258,6 +1248,11 @@
 					overlayOp(OverlayOp::opDIFFERENCE));
 #endif
+				validOut &= testValid(gI.get(), "areatest difference(a,b)");
 			if ( verbose > 1 )
 		std::cerr << "Running difference(B,A) for areatest" << std::endl;
@@ -1272,7 +1267,7 @@
-				testValid(gI.get(), "areatest difference");
+				validOut &= testValid(gI.get(), "areatest difference(b,a)");
 			if ( verbose > 1 )
@@ -1287,6 +1282,11 @@
 					overlayOp(OverlayOp::opSYMDIFFERENCE));
 #endif
+				validOut &= testValid(gI.get(), "areatest symdifference");
 			if ( verbose > 1 )
 		std::cerr << "Running union for areatest" << std::endl;
@@ -1345,7 +1345,7 @@
 			if ( maxdiff <= toleratedDiff )
-				success=1;
+				success = 1 && validOut;
 			std::stringstream tmp;
Modified: trunk/tests/xmltester/XMLTester.h
--- trunk/tests/xmltester/XMLTester.h	2010-08-27 10:22:26 UTC (rev 3096)
+++ trunk/tests/xmltester/XMLTester.h	2010-08-27 13:00:16 UTC (rev 3097)
@@ -78,7 +78,7 @@
 	bool sqlOutput;
 	bool HEXWKB_output;
-	void testValid(const geom::Geometry* g, const std::string& label);
+	bool testValid(const geom::Geometry* g, const std::string& label);
 public:
 	XMLTester();
More information about the geos-commits mailing list
