[geos-commits] r3145 - trunk/capi
svn_geos at osgeo.org
Thu Dec 2 09:52:20 EST 2010
Author: strk
Date: 2010-12-02 06:52:20 -0800 (Thu, 02 Dec 2010)
New Revision: 3145
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
Expose snapping to the C-API
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2010-12-02 14:29:32 UTC (rev 3144)
+++ trunk/capi/geos_c.cpp 2010-12-02 14:52:20 UTC (rev 3145)
@@ -1100,7 +1100,10 @@
return GEOSSharedPaths_r(handle, g1, g2);
-extern GEOSGeometry GEOS_DLL *GEOSSharedPaths_r(GEOSContextHandle_t handle,
- const GEOSGeometry* g1, const GEOSGeometry* g2);
+GEOSGeometry *
+GEOSSnap(const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance)
+ return GEOSSnap(handle, g1, g2);
} /* extern "C" */
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-12-02 14:29:32 UTC (rev 3144)
+++ trunk/capi/geos_c.h.in 2010-12-02 14:52:20 UTC (rev 3145)
@@ -613,6 +613,15 @@
+ * Snap first geometry on to second with given tolerance
+ * Returns a newly allocated geometry, or NULL on exception
+extern GEOSGeometry GEOS_DLL *GEOSSnap(const GEOSGeometry* g1,
+ const GEOSGeometry* g2, double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSSnap_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance);
* Binary predicates - return 2 on exception, 1 on true, 0 on false
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-12-02 14:29:32 UTC (rev 3144)
+++ trunk/capi/geos_ts_c.cpp 2010-12-02 14:52:20 UTC (rev 3145)
@@ -5402,5 +5402,33 @@
+GEOSGeometry *
+GEOSSnap_r(GEOSContextHandle_t handle, const GEOSGeometry* g1,
+ using namespace geos::operation::overlay::snap;
+ if ( 0 == extHandle ) return 0;
+ GEOSContextHandleInternal_t *handle =
+ reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( handle->initialized == 0 ) return 0;
+ try{
+ GeometrySnapper snapper( g1 );
+ std::auto_ptr<Geometry*> ret = snapper.snapTo(*g2, tolerance);
+ return ret.release();
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ return 0;
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 0;
} /* extern "C" */
More information about the geos-commits
