[geos-commits] r3152 - in trunk: include/geos/operation/overlay/snap
src/operation/overlay/snap
svn_geos at osgeo.org
Fri Dec 3 05:49:49 EST 2010
Author: strk
Date: 2010-12-03 02:49:49 -0800 (Fri, 03 Dec 2010)
New Revision: 3152
trunk/include/geos/operation/overlay/snap/LineStringSnapper.h
trunk/src/operation/overlay/snap/LineStringSnapper.cpp
Take the allowSnappingToSourceVertices support in
Modified: trunk/include/geos/operation/overlay/snap/LineStringSnapper.h
--- trunk/include/geos/operation/overlay/snap/LineStringSnapper.h 2010-12-03 08:36:38 UTC (rev 3151)
+++ trunk/include/geos/operation/overlay/snap/LineStringSnapper.h 2010-12-03 10:49:49 UTC (rev 3152)
@@ -64,7 +64,8 @@
double nSnapTol)
srcPts(nSrcPts),
- snapTolerance(nSnapTol)
+ snapTolerance(nSnapTol),
+ allowSnappingToSourceVertices(false)
size_t s = srcPts.size();
isClosed = s < 2 ? false : srcPts[0].equals2D(srcPts[s-1]);
@@ -73,12 +74,17 @@
// Snap points are assumed to be all distinct points (a set would be better, uh ?)
std::auto_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
+ void setAllowSnappingToSourceVertices(bool allow) {
+ allowSnappingToSourceVertices = allow;
private:
const geom::Coordinate::Vect& srcPts;
double snapTolerance;
+ bool allowSnappingToSourceVertices;
bool isClosed;
@@ -91,20 +97,39 @@
geom::Coordinate::ConstVect::const_iterator findSnapForVertex(const geom::Coordinate& pt,
- // Modifies first arg
- void snapSegments(geom::CoordinateList& srcCoords,
- const geom::Coordinate::ConstVect& snapPts);
+ /** \brief
+ * Snap segments of the source to nearby snap vertices.
+ * Source segments are "cracked" at a snap vertex.
+ * A single input segment may be snapped several times
+ * to different snap vertices.
+ * For each distinct snap vertex, at most one source segment
+ * is snapped to. This prevents "cracking" multiple segments
+ * at the same point, which would likely cause
+ * topology collapse when being used on polygonal linework.
+ * @param srcCoords the coordinates of the source linestring to be snapped
+ * the object will be modified (coords snapped)
+ * @param snapPts the target snap vertices */
+ void snapSegments(geom::CoordinateList& srcCoords,
+ const geom::Coordinate::ConstVect& snapPts);
/// \brief
/// Finds a src segment which snaps to (is close to) the given snap
/// point.
- /// Only one segment is determined - this is to prevent
- /// snapping to multiple segments, which would almost certainly cause
- /// invalid geometry to be created.
- /// (The heuristic approach of snapping is really only appropriate
- /// when snap pts snap to a unique spot on the src geometry.)
+ /// Only a single segment is selected for snapping.
+ /// This prevents multiple segments snapping to the same snap vertex,
+ /// which would almost certainly cause invalid geometry
+ /// to be created.
+ /// (The heuristic approach to snapping used here
+ /// is really only appropriate when
+ /// snap pts snap to a unique spot on the src geometry.)
+ /// Also, if the snap vertex occurs as a vertex in the src
+ /// coordinate list, no snapping is performed (may be changed
+ /// using setAllowSnappingToSourceVertices).
/// @param from
/// an iterator to first point of first segment to be checked
@@ -112,9 +137,10 @@
/// @param too_far
/// an iterator to last point of last segment to be checked
- /// @returns too_far if no segment needs snapping
+ /// @returns an iterator to the snapped segment or
+ /// too_far if no segment needs snapping
/// (either none within snapTol distance,
- /// or one fond on the snapPt)
+ /// or one found on the snapPt)
geom::CoordinateList::iterator findSegmentToSnap(
const geom::Coordinate& snapPt,
Modified: trunk/src/operation/overlay/snap/LineStringSnapper.cpp
--- trunk/src/operation/overlay/snap/LineStringSnapper.cpp 2010-12-03 08:36:38 UTC (rev 3151)
+++ trunk/src/operation/overlay/snap/LineStringSnapper.cpp 2010-12-03 10:49:49 UTC (rev 3152)
@@ -209,6 +209,7 @@
/*private*/
+/* NOTE: this is called findSegmentIndexToSnap in JTS */
LineStringSnapper::findSegmentToSnap(
const Coordinate& snapPt,
@@ -238,9 +239,11 @@
#if GEOS_DEBUG
cerr << " One of segment endpoints equal snap point, returning too_far" << endl;
#endif
- // If the snap pt is already in the src list,
- // don't snap
- return too_far;
+ if (allowSnappingToSourceVertices) {
+ continue;
+ } else {
+ return too_far;
double dist = seg.distance(snapPt);
More information about the geos-commits
