[geos-commits] r3155 - in trunk: include/geos/geom tests/unit/geom
svn_geos at osgeo.org
Fri Dec 3 08:57:00 EST 2010
Author: strk
Date: 2010-12-03 05:57:00 -0800 (Fri, 03 Dec 2010)
New Revision: 3155
trunk/include/geos/geom/CoordinateList.h
trunk/tests/unit/geom/CoordinateListTest.cpp
Add method to insert coordinats into a CoordinateList w/out allowing duplicates (fixes issue #387)
Modified: trunk/include/geos/geom/CoordinateList.h
--- trunk/include/geos/geom/CoordinateList.h 2010-12-03 10:58:22 UTC (rev 3154)
+++ trunk/include/geos/geom/CoordinateList.h 2010-12-03 13:57:00 UTC (rev 3155)
@@ -11,6 +11,10 @@
* by the Free Software Foundation.
* See the COPYING file for more information.
+ * Last port: geom/CoordinateList.java ?? (never been in complete sync)
#ifndef GEOS_GEOM_COORDINATELIST_H
@@ -34,8 +38,9 @@
namespace geos {
namespace geom { // geos::geom
- * A list of {@link Coordinate}s.
+/** \brief
+ * A list of {@link Coordinate}s, which may
+ * be set to prevent repeated coordinates from occuring in the list.
* Use this class when fast insertions and removal at arbitrary
* position is needed.
@@ -53,6 +58,15 @@
friend std::ostream& operator<< (std::ostream& os,
const CoordinateList& cl);
+ /** \brief
+ * Constructs a new list from an array of Coordinates, allowing
+ * repeated points.
+ * (I.e. this constructor produces a {@link CoordinateList} with
+ * exactly the same set of points as the input array.)
+ * @param v the initial coordinates
CoordinateList(const std::vector<Coordinate>& v)
coords(v.begin(), v.end())
@@ -90,6 +104,28 @@
return coords.end();
+ /** \brief
+ * Inserts the specified coordinate at the specified position in this list.
+ * @param pos the position at which to insert
+ * @param coord the coordinate to insert
+ * @param allowRepeated if set to false, repeated coordinates are collapsed
+ * @return an iterator to the newly installed coordinate
+ * (or previous, if equal and repeated are not allowed)
+ * NOTE: when allowRepeated is false _next_ point is not checked
+ * this matches JTS behavior
+ iterator insert(iterator pos, const Coordinate& c, bool allowRepeated)
+ if ( !allowRepeated && pos != coords.begin() ) {
+ iterator prev = pos; --prev;
+ if ( c.equals2D(*prev) ) return prev;
+ return coords.insert(pos, c);
iterator insert(iterator pos, const Coordinate& c)
Modified: trunk/tests/unit/geom/CoordinateListTest.cpp
--- trunk/tests/unit/geom/CoordinateListTest.cpp 2010-12-03 10:58:22 UTC (rev 3154)
+++ trunk/tests/unit/geom/CoordinateListTest.cpp 2010-12-03 13:57:00 UTC (rev 3155)
@@ -103,5 +103,33 @@
+ // Test insert with and without duplicates
+ template<>
+ template<>
+ void object::test<2>()
+ using geos::geom::Coordinate;
+ geos::geom::CoordinateList clist;
+ ensure_equals( clist.size(), 0u );
+ clist.insert(clist.end(), Coordinate(0, 0));
+ ensure_equals( clist.size(), 1u );
+ clist.insert(clist.end(), Coordinate(0, 0), false);
+ clist.insert(clist.end(), Coordinate(0, 0), true);
+ ensure_equals( clist.size(), 2u );
+ clist.insert(clist.end(), Coordinate(1, 1), true);
+ ensure_equals( clist.size(), 3u );
+ geos::geom::CoordinateList::iterator it = clist.end();
+ --it;
+ clist.insert(it, Coordinate(0, 0), false);
} // namespace tut
More information about the geos-commits
